查看: 7915|回复: 4
[已解决] HomeAssistant退出登录后无法登录了
发表于 2021-4-12 10:55:58 | 显示全部楼层 |阅读模式
不知道有没有遇到一样问题的
Image        homeassistant/raspberrypi4-homeassistant:2021.4.1
[aiohttp.server]
Error handling requestTraceback (most recent call last):  File "/usr/local/lib/python3.8/site-packages/aiohttp/web_protocol.py", line 422, in _handle_request    resp = await self._request_handler(request)  File "/usr/local/lib/python3.8/site-packages/aiohttp/web_app.py", line 499, in _handle    resp = await handler(request)  File "/usr/local/lib/python3.8/site-packages/aiohttp/web_middlewares.py", line 118, in impl    return await handler(request)  File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 56, in security_filter_middleware    return await handler(request)  File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 18, in request_context_middleware    return await handler(request)  File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 72, in ban_middleware    return await handler(request)  File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 129, in auth_middleware    return await handler(request)  File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 129, in handle    result = await result  File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 83, in handle_req    resp = await func(view, request, *args, **kwargs)  File "/usr/src/homeassistant/homeassistant/components/auth/__init__.py", line 255, in post    return await self._async_handle_auth_code(hass, data, request.remote)  File "/usr/src/homeassistant/homeassistant/components/auth/__init__.py", line 316, in _async_handle_auth_code    refresh_token = await hass.auth.async_create_refresh_token(  File "/usr/src/homeassistant/homeassistant/auth/__init__.py", line 423, in async_create_refresh_token    return await self._store.async_create_refresh_token(TypeError: async_create_refresh_token() takes from 1 to 6 positional arguments but 7 were given
因为第三方库未更新导致参数数量不一致,使用aligenie,或者xiaoai库的同学记得更新下
hass.auth._store.async_create_refresh_token = async_create_refresh_token
活跃会员教程狂人
发表于 2021-4-12 17:11:58 | 显示全部楼层
把configxxx.yaml 里面刻意修改一个正常的配置,重启会让系统进入安全模式,登陆之后,再改回去,重启HA,done!!!!
所有过往,皆为序章。
发表于 2021-4-12 23:38:49 | 显示全部楼层
咸味土豆 发表于 2021-4-12 17:11
把configxxx.yaml 里面刻意修改一个正常的配置,重启会让系统进入安全模式,登陆之后,再改回去,重启HA,d ...
谢谢大佬,又学到一招。我重装后还原回去,试了两天不行;直接重装从零开始了。
我不生产技术,我只是技术的搬运工。
活跃会员教程狂人
发表于 2021-4-13 08:26:58 | 显示全部楼层
zxyny1989 发表于 2021-4-12 23:38
谢谢大佬,又学到一招。我重装后还原回去,试了两天不行;直接重装从零开始了。 ...
我是重装完之后才发现可以这么搞,因为新版本HA对第三方插件做了很多限制,我感觉授权验证会因为加载这些不安全的插件而受到影响,所以安全模式就派上用场了
所有过往,皆为序章。
发表于 2025-1-4 14:57:16 | 显示全部楼层
怎么搞,大神门能具体点吗,我也遇到同样的问题。
GMT+8, 2025-12-18 03:37 , Processed in 1.326696 second(s), 12 queries , MemCached On.
