查看: 19601|回复: 2
[求助] 小白求助。HASS报错
发表于 2021-4-9 00:13:35 | 显示全部楼层 |阅读模式
[color=var(--error-color)]2021-04-08 15:25:20 ERROR (MainThread) [frontend.js.latest.202104071] http://192.168.2.42:8123/fronten ... 7f96ec18.js:75:1061 Uncaught SyntaxError: Unexpected token {
[color=var(--error-color)]2021-04-08 15:48:55 ERROR (MainThread) [homeassistant.components.system_health] Error fetching system info for cloud - can_reach_cloud
File "/usr/src/homeassistant/homeassistant/components/system_health/__init__.py", line 214, in async_check_can_reach_url
await session.get(url, timeout=5)
File "/usr/local/lib/python3.8/site-packages/aiohttp/client.py", line 544, in _request
await resp.start(conn)
File "/usr/local/lib/python3.8/site-packages/aiohttp/client_reqrep.py", line 905, in start
self._continue = None
File "/usr/local/lib/python3.8/site-packages/aiohttp/helpers.py", line 656, in __exit__
raise asyncio.TimeoutError from None
asyncio.exceptions.TimeoutError
设备:威联通 container station内安装
home assistant最新版本
然后我的集成里面找不到没有小米的MIOT以及getway3
jjcs 手机认证
发表于 2021-4-9 01:02:07 | 显示全部楼层
集成添加了没有
发表于 2021-5-30 17:25:00 来自手机 | 显示全部楼层
这个报错楼主解决啦吗?我的也是同样的问题
GMT+8, 2025-12-22 15:02 , Processed in 0.475057 second(s), 11 queries , MemCached On.
