查看: 20766|回复: 11
[流程系列] 家里某一灯连续开灯超过xx小时提醒,这个自动化怎么写
发表于 2021-4-7 21:20:04 | 显示全部楼层 |阅读模式
灯具数量太多了,一个个写感觉累死人,有简单的写法么
发表于 2021-4-7 23:39:33 | 显示全部楼层
nodered  change+stoptime2节点,写出来一个,剩下的可以复制
发表于 2021-4-8 08:38:33 | 显示全部楼层
这个很有用,有没有复制流出来,感谢。
发表于 2021-4-8 10:35:36 | 显示全部楼层
lrving163 发表于 2021-4-8 08:38
这个很有用,有没有复制流出来,感谢。
是要把流复制出来吗
发表于 2021-4-8 11:00:55 | 显示全部楼层
Midnight 发表于 2021-4-8 10:35
是要把流复制出来吗
是的。感谢。菜鸟一个,没办法。
发表于 2021-4-8 11:06:49 | 显示全部楼层
如果时间统一的话自动化直接可以把所有项目加进去,不统一的话可以写一个blueprint然后对每个灯分别设置
佑桑
发表于 2021-4-8 13:25:16 | 显示全部楼层
1.建一個 Light Group
https://www.home-assistant.io/integrations/light.group/
2.直接使用這個 Light Group 做自動化
发表于 2021-4-8 20:26:01 | 显示全部楼层
lrving163 发表于 2021-4-8 11:00
是的。感谢。菜鸟一个,没办法。
[{"id":"d07a559b.55f3b8","type":"tab","label":"流程 1","disabled":false,"info":""},{"id":"95f9075d.a0f5d8","type":"inject","z":"d07a559b.55f3b8","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"on","payloadType":"str","x":90,"y":340,"wires":[["b0dd51e5.f87d7"]]},{"id":"29819cd7.c546b4","type":"debug","z":"d07a559b.55f3b8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":510,"y":340,"wires":[]},{"id":"ca8b74e.f6b8e88","type":"change","z":"d07a559b.55f3b8","name":"重置stoptimer2节点","rules":[{"t":"set","p":"payload","pt":"msg","to":"stop","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":250,"y":400,"wires":[["b0dd51e5.f87d7"]]},{"id":"60aa8c0a.e592c4","type":"inject","z":"d07a559b.55f3b8","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"off","payloadType":"str","x":90,"y":400,"wires":[["ca8b74e.f6b8e88"]]},{"id":"b0dd51e5.f87d7","type":"stoptimer2","z":"d07a559b.55f3b8","duration":"5","durationType":"num","units":"Second","payloadtype":"num","payloadval":"0","name":"超过的时间","x":320,"y":340,"wires":[["29819cd7.c546b4"],[]]}]
发表于 2021-4-14 19:23:13 | 显示全部楼层
流水无味
灌水之王
发表于 2022-1-13 13:28:20 | 显示全部楼层
收藏下 可以整小孩看电视
GMT+8, 2025-12-24 21:36 , Processed in 1.725272 second(s), 9 queries , MemCached On.
