查看: 22316|回复: 1
[求助] n1的8123端口打不开,其它都可以打开,求教大佬
发表于 2021-4-3 15:40:10 | 显示全部楼层 |阅读模式
2021-04-03 14:53:21 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of safe_mode. Setup failed for dependencies: frontend
2021-04-03 14:53:21 ERROR (MainThread) [homeassistant.setup] Setup failed for safe_mode: Could not set up all dependencies.
2021-04-03 14:58:36 ERROR (MainThread) [aiohttp.server] Error handling request
  File "/usr/local/lib/python3.8/site-packages/aiohttp/web_protocol.py", line 314, in data_received
    messages, upgraded, tail = self._request_parser.feed_data(data)
  File "aiohttp/_http_parser.pyx", line 546, in aiohttp._http_parser.HttpParser.feed_data
aiohttp.http_exceptions.BadStatusLine: 400, message="Bad status line 'invalid HTTP method'"
发表于 2021-4-26 13:47:39 | 显示全部楼层
老哥,解决了吗,我也是这样的
GMT+8, 2025-12-22 17:16 , Processed in 1.235202 second(s), 10 queries , MemCached On.
