查看: 15816|回复: 0
[流程系列] 请教大神可有云米浴霸控制方法-已解决
发表于 2021-4-3 10:01:32 | 显示全部楼层 |阅读模式
https://www.xiaomiyoupin.com/detail?gid=139764&spmref=YouPinPC.$SearchFilter$1.search_list.1.75591963
请教大神云米互联网浴霸Node-red控制方法,目前只能通过MIoT云控制浴霸灯,通过xiaomi_miio_raw获取状态以及温湿度
#云米浴霸
  - platform: xiaomi_miio_raw
    host: 192.168.*****
    token: ************
    default_properties:
      - power
      - humidity
      - temp
      - switch_state
      - wind_tem
      - off_time
  - platform: template
    sensors:
      bhwindtem:
        friendly_name: '设定温度'
        value_template: "{{ state_attr('sensor.yunmi_bat_heater','wind_tem') }}"
        unit_of_measurement: "°C"
      bhofftime:
        friendly_name: '延时关机时间'
        value_template: "{{ state_attr('sensor.yunmi_bat_heater','off_time') }}"
      bhhumidity:
        friendly_name: '浴霸湿度'
        value_template: "{{ state_attr('sensor.yunmi_bat_heater','humidity') }}"
        unit_of_measurement: "%"
      bhtemp:
        friendly_name: '浴霸温度'
        value_template: "{{ state_attr('sensor.yunmi_bat_heater','temp') }}"
      bhstatusname:
        friendly_name: '浴霸状态'
        value_template: >
          {% if state_attr('sensor.yunmi_bat_heater','switch_state') == 1 %}待机
          {% elif state_attr('sensor.yunmi_bat_heater','switch_state') == 4 %}换气
          {% elif state_attr('sensor.yunmi_bat_heater','switch_state') == 16 %}照明
          {% elif state_attr('sensor.yunmi_bat_heater','switch_state') == 16384 %}自然风
          {% elif state_attr('sensor.yunmi_bat_heater','switch_state') == 4096 %}暖风
          {% elif state_attr('sensor.yunmi_bat_heater','switch_state') == 256 %}自定义
          {% elif state_attr('sensor.yunmi_bat_heater','switch_state') == 20 %}照明&换气
          {% elif state_attr('sensor.yunmi_bat_heater','switch_state') == 16400 %}照明&自然风
          {% elif state_attr('sensor.yunmi_bat_heater','switch_state') == 4112 %}照明&暖风
          {% elif state_attr('sensor.yunmi_bat_heater','switch_state') == 272 %}照明&自定义
          {% elif state_attr('sensor.yunmi_bat_heater','switch_state') == 16388 %}换气&自然风
          {% elif state_attr('sensor.yunmi_bat_heater','switch_state') == 4100 %}换气&暖风
          {% elif state_attr('sensor.yunmi_bat_heater','switch_state') == 260 %}换气&自定义
          {% elif state_attr('sensor.yunmi_bat_heater','switch_state') == 16404 %}照明&换气&自然风
          {% elif state_attr('sensor.yunmi_bat_heater','switch_state') == 4116 %}照明&换气&暖风
          {% elif state_attr('sensor.yunmi_bat_heater','switch_state') == 276 %}照明&换气&自定义
          {% elif state_attr('sensor.yunmi_bat_heater','switch_state') == 68 %}延时&换气
          {% elif state_attr('sensor.yunmi_bat_heater','switch_state') == 80 %}延时&照明
          {% elif state_attr('sensor.yunmi_bat_heater','switch_state') == 16448 %}延时&自然风
          {% elif state_attr('sensor.yunmi_bat_heater','switch_state') == 4160 %}延时&暖风
          {% elif state_attr('sensor.yunmi_bat_heater','switch_state') == 320 %}延时&自定义
          {% elif state_attr('sensor.yunmi_bat_heater','switch_state') == 84 %}延时&照明&换气
          {% elif state_attr('sensor.yunmi_bat_heater','switch_state') == 16464 %}延时&照明&自然风
          {% elif state_attr('sensor.yunmi_bat_heater','switch_state') == 4176 %}延时&照明&暖风
          {% elif state_attr('sensor.yunmi_bat_heater','switch_state') == 336 %}延时&照明&自定义
          {% elif state_attr('sensor.yunmi_bat_heater','switch_state') == 16452 %}延时&换气&自然风
          {% elif state_attr('sensor.yunmi_bat_heater','switch_state') == 4164 %}延时&换气&暖风
          {% elif state_attr('sensor.yunmi_bat_heater','switch_state') == 324 %}延时&换气&自定义
          {% elif state_attr('sensor.yunmi_bat_heater','switch_state') == 16468 %}延时&照明&换气&自然风
          {% elif state_attr('sensor.yunmi_bat_heater','switch_state') == 4180 %}延时&照明&换气&暖风
          {% elif state_attr('sensor.yunmi_bat_heater','switch_state') == 340 %}延时&照明&换气&自定义
          {% endif %}
switch:
    switches:
      bh_ventilate:
        friendly_name: '换气'
        value_template: "{{ state_attr('sensor.yunmi_bat_heater','switch_state')|int|bitwise_and(4) > 0 }}"
        turn_on:
          service: xiaomi_miio_raw.sensor_raw_command
          data_template:
            entity_id: sensor.yunmi_bat_heater
            method: set_switch
            params: ["{{ state_attr('sensor.yunmi_bat_heater','switch_state')|int + 4 }}"]
        turn_off:
          data_template:
            method: set_switch
            params: >
                [{% if state_attr('sensor.yunmi_bat_heater','switch_state')|int - 4 > 0 %} {{ state_attr('sensor.yunmi_bat_heater','switch_state')|int - 4 }} {% else %} 1 {% endif %}]
      bh_lamp:
        friendly_name: '浴霸灯'
        value_template: "{{ state_attr('sensor.yunmi_bat_heater','switch_state')|int|bitwise_and(16) > 0 }}"
        turn_on:
          data_template:
            method: set_switch
            params: ["{{ state_attr('sensor.yunmi_bat_heater','switch_state')|int + 16 }}"]
        turn_off:
          data_template:
            method: set_switch
            params: >
                [{% if state_attr('sensor.yunmi_bat_heater','switch_state')|int - 16 > 0 %} {{ state_attr('sensor.yunmi_bat_heater','switch_state')|int - 16 }} {% else %} 1 {% endif %}]
      bh_customize:
        friendly_name: '自定义'
        value_template: "{{ state_attr('sensor.yunmi_bat_heater','switch_state')|int|bitwise_and(256) > 0 }}"
        turn_on:
          data_template:
            method: set_switch
            params: ["{{ state_attr('sensor.yunmi_bat_heater','switch_state')|int + 256 }}"]
        turn_off:
          data_template:
            method: set_switch
            params: >
                [{% if state_attr('sensor.yunmi_bat_heater','switch_state')|int - 256 > 0 %} {{ state_attr('sensor.yunmi_bat_heater','switch_state')|int - 256 }} {% else %} 1 {% endif %}]
      bh_heater:
        friendly_name: '暖风'
        value_template: "{{ state_attr('sensor.yunmi_bat_heater','switch_state')|int|bitwise_and(4096) > 0 }}"
        turn_on:
          data_template:
            method: set_switch
            params: ["{{ state_attr('sensor.yunmi_bat_heater','switch_state')|int + 4096 }}"]
        turn_off:
          data_template:
            method: set_switch
            params: >
                [{% if state_attr('sensor.yunmi_bat_heater','switch_state')|int - 4096 > 0 %} {{ state_attr('sensor.yunmi_bat_heater','switch_state')|int - 4096 }} {% else %} 1 {% endif %}]
      bh_blow:
        friendly_name: '自然风'
        value_template: "{{ state_attr('sensor.yunmi_bat_heater','switch_state')|int|bitwise_and(16384) > 0 }}"
        turn_on:
          data_template:
            method: set_switch
            params: ["{{ state_attr('sensor.yunmi_bat_heater','switch_state')|int + 16384 }}"]
        turn_off:
          data_template:
            method: set_switch
            params: >
                [{% if state_attr('sensor.yunmi_bat_heater','switch_state')|int - 16384 > 0 %} {{ state_attr('sensor.yunmi_bat_heater','switch_state')|int - 16384 }} {% else %} 1 {% endif %}]
      bh_idle:
        friendly_name: '待机'
        turn_on:
          data_template:
            method: set_switch
            params: [1]
        turn_off:
          data_template:
            method: set_switch
            params: [1]
温湿度及状态
温湿度及状态
浴霸灯控制
浴霸灯控制
GMT+8, 2025-12-24 17:32 , Processed in 0.970066 second(s), 7 queries , MemCached On.
