查看: 15027|回复: 4
[求助] 求助大神,博联黑豆通过smartir,点按钮没反应
发表于 2021-4-1 15:31:08 | 显示全部楼层 |阅读模式
卡片出来了,就是点按钮没反应,遥控灯也不亮,研究两天了
smartir:
  check_updates: false
media_player:
  - platform: smartir
    unique_id: living_room_tv
    device_code: 9999
    controller_data: 192.168.254.195
    power_sensor: binary_sensor.tv_power
climate:
  - platform: smartir
    unique_id: office_ac
    device_code: 1380
    temperature_sensor: sensor.doudou_drive_2_temperature #sensor.temperature
    humidity_sensor: sensor.doudou_drive_2_temperature #sensor.humidity
    power_sensor: binary_sensor.ac_power
我就是六神
活跃会员教程狂人灌水之王
发表于 2021-4-1 23:23:24 | 显示全部楼层
你那灯的配置呢?? 里面的码都配置好了吗???
发表于 2021-4-2 10:51:00 | 显示全部楼层
灯的配置在哪??
 楼主| 发表于 2021-4-2 10:56:57 | 显示全部楼层
遥控也学习过了,下图是目录,就是点按钮一点反应都没有
    "manufacturer": "Yamaha",
    "supportedModels": [
      "AX-380"
    "supportedController": "Broadlink",
    "commandsEncoding": "Base64",
    "commands": {
        "off": "JgBQAAABKZUSExIUETgSOBITExISOBIUETkRFBE5ERQRFBI4ETkSExITEjgRFBE5EhMRFBEVERMSOBITETkSExI4EjgTNxI4EwAFUgABKUkRAA0FAAAAAAAAAAA=",
        "on": "JgBQAAABKJYSExEUETkROREUEhMRORITETkRFBE5ERQSExE5EjgRFBEUETkSExI5ERMSExIUERMTNxMTETgSFBE5ETkRORE5EQAFUwABKUoRAA0FAAAAAAAAAAA=",
        "volumeDown": "JgBQAAABKZUSExITEjgSOBITEhMTNxITEjgSExI4EhMTEhM3EzcSFBEUEjgSOBE5ERQSExEUERQRORITERQSExE5ETkRORE5EgAFUgABKUkRAA0FAAAAAAAAAAA=",
        "volumeUp": "JgBQAAABKZUSExEUETkSOBITERQROREUEjgRFBE5ERQRFBE5ETkRFBI4ETkSExE5ERQRFBEUEhMRFBEUETkRFBI4ETkSOBE5EQAFUwABKUkRAA0FAAAAAAAAAAA=",
        "sources": {
            "Phono": "0000 006D 0022 0002 0156 00AB 0016 0015 0015 0040 0016 0015 0015 0040 0016 003F 0016 0040 0015 0040 0016 0015 0015 0040 0016 0015 0015 0040 0016 0015 0015 0015 0016 0015 0016 0015 0015 0040 0016 0015 0015 0015 0016 0040 0015 0015 0016 0040 0015 0015 0016 0015 0016 0015 0015 0040 0016 003F 0016 0015 0016
 楼主| 发表于 2021-4-2 11:01:27 | 显示全部楼层
zhizhi1991 发表于 2021-4-2 10:51
灯的配置在哪??
就是正常情况下红外信息发射,遥控上面的灯会亮一下,现在接入smartir点遥控上的灯不亮
GMT+8, 2025-11-7 02:51 , Processed in 0.998718 second(s), 11 queries , MemCached On.
