查看: 29085|回复: 5
[经验分享] 装zigbee2mqtt插件出现502: Bad Gateway
发表于 2021-3-27 00:54:44 | 显示全部楼层 |阅读模式
Zigbee2MQTT:error 2021-03-27 00:44:32: Error while starting zigbee-herdsmanZigbee2MQTT:error 2021-03-27 00:44:32: Failed to start zigbeeZigbee2MQTT:error 2021-03-27 00:44:32: Exiting...Zigbee2MQTT:error 2021-03-27 00:44:32: Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)    at ZStackAdapter.<anonymous> (/app/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:94:31)    at Generator.throw (<anonymous>)    at rejected (/app/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:25:65)npm ERR! code ELIFECYCLEnpm ERR! errno 1npm ERR! [email protected] start: `node index.js`npm ERR! Exit status 1npm ERR! npm ERR! Failed at the [email protected] start script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.npm ERR! A complete log of this run can be found in:npm ERR!     /root/.npm/_logs/2021-03-26T16_44_32_362Z-debug.log[00:44:33] INFO: Handing over control to Zigbee2mqtt Core ...> [email protected] start /app> node index.js
遇到了这个问题,查询说是npm版本问题,重装一下npm依旧不行。求大佬指导!!!
查了下
发表于 2021-3-27 08:53:51 | 显示全部楼层
应该是zigbee配置文件不对,没连接上mqtt
=========下面是我的配置================
data_path: /config/zigbee2mqtt
external_converters: []
devices: devices.yaml
groups: groups.yaml
homeassistant: true
permit_join: false
mqtt:
  base_topic: zigbee2mqtt
  server: 'mqtt://192.168.xx.xx:1883'
  user: ****    #用户名
  password: ******  #密码
serial:
  port: 'tcp://192.168.xx.xx:8880' ##端口看你自已的是多少有1024的
advanced:
  log_level: info
  pan_id: 6754
  channel: 11
  network_key:
    - 1
    - 3
    - 5
    - 7
    - 9
    - 11
    - 13
    - 15
    - 0
    - 2
    - 4
    - 6
    - 8
    - 10
    - 12
    - 13
  availability_blocklist: []
  availability_passlist: []
device_options: {}
blocklist: []
passlist: []
queue: {}
frontend:
  port: 8099
experimental: {}
socat:
  enabled: false
  master: 'pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777'
  slave: 'tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5'
  options: '-d -d'
  log: false
=====连接上小米插座的日志=====
Zigbee2MQTT:info 2021-03-27 08:50:13: MQTT publish: topic 'zigbee2mqtt/小米插座', payload '{"consumption":4.35,"energy":4.35,"linkquality":72,"power":0,"state":"ON","temperature":36}'
发表于 2021-6-17 16:13:36 来自手机 | 显示全部楼层
我的也是这问题,怎么解决啊
发表于 2021-6-21 21:27:42 | 显示全部楼层
祁连山路 发表于 2021-6-17 16:13
我的也是这问题,怎么解决啊
树莓派?你使用SSD?如果是这样把USB线加长,把CC253X插在加长的USB线应该就解决了。
发表于 2022-12-3 16:50:07 来自手机 | 显示全部楼层
楼主弄好了吗
发表于 2022-12-5 23:33:43 | 显示全部楼层
我的也是这问题,怎么解决啊
GMT+8, 2025-12-16 02:02 , Processed in 0.931077 second(s), 13 queries , MemCached On.
