查看: 29713|回复: 10
[流程系列] 求助大神利用node-red让小爱音响整点报时-已解决
发表于 2021-3-15 11:17:51 | 显示全部楼层 |阅读模式
怎样利用node-red节点让小爱TTS整点报时?
[{"id":"16e7a784.c84a28","type":"tab","label":"小爱整点报时","disabled":false,"info":""},{"id":"2698434c.ff80ec","type":"inject","z":"16e7a784.c84a28","name":"整点报时","props":[],"repeat":"","crontab":"0 8-17 * * *","once":false,"onceDelay":0.1,"topic":"","x":100,"y":120,"wires":[["c16cac5b.7d20e"]]},{"id":"c16cac5b.7d20e","type":"api-current-state","z":"16e7a784.c84a28","name":"判断家中是否有人","server":"5d51d3bd.9c86fc","version":1,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"binary_sensor.54ef44e1ec2d_motion","state_type":"str","state_location":"","override_payload":"none","entity_location":"","override_data":"none","blockInputOverrides":false,"x":270,"y":120,"wires":[["123a2d82.25dac2"],[]]},{"id":"350dbd71.08ca92","type":"api-call-service","z":"16e7a784.c84a28","name":"整点报时","server":"5d51d3bd.9c86fc","version":1,"debugenabled":false,"service_domain":"hello_miai","service":"add2msgqueue","entityId":"","data":"","dataType":"json","mergecontext":"","output_location":"payload","output_location_type":"msg","mustacheAltTags":false,"x":580,"y":120,"wires":[[]]},{"id":"123a2d82.25dac2","type":"function","z":"16e7a784.c84a28","name":"播报内容","func":"var message = `现在时间${new Date().getHours()}点`;\nmsg.payload = {};\nmsg.payload.data = {"message":message};\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":440,"y":120,"wires":[["350dbd71.08ca92"]]},{"id":"5d51d3bd.9c86fc","type":"server","name":"金星中央城","legacy":false,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true}]
sdfd
发表于 2021-3-15 14:33:45 | 显示全部楼层
直接让小爱整体报时不行吗?为啥要绕一圈?
发表于 2021-3-15 21:53:04 来自手机 | 显示全部楼层
安装iob的xiaoai tts节点,拖出inject和小爱tts节点,配置一下,前者定时和设置参数,后者发声,就行了
 楼主| 发表于 2021-3-16 14:02:44 | 显示全部楼层
pikaq 发表于 2021-3-15 21:53
安装iob的xiaoai tts节点,拖出inject和小爱tts节点,配置一下,前者定时和设置参数,后者发声,就行了 ...
可以有具体步骤吗?小白一名
发表于 2021-3-16 17:02:31 | 显示全部楼层
小爱本来就有整点报时技能吧
发表于 2021-3-20 17:26:58 | 显示全部楼层
756641156 发表于 2021-3-16 14:02
可以有具体步骤吗?小白一名
[{"id":"2698434c.ff80ec","type":"inject","z":"1b6b56b6.0e6749","name":"","props":[],"repeat":"","crontab":"0 9-20 * * *","once":false,"onceDelay":0.1,"topic":"","payloadType":"str","x":160,"y":180,"wires":[["f711a018.1ad46"]]},{"id":"f711a018.1ad46","type":"function","z":"1b6b56b6.0e6749","name":"","func":"msg.payload = `北京时间${new Date().getHours()}点`\nreturn msg","outputs":1,"noerr":0,"initialize":"","finalize":"","x":290,"y":180,"wires":[["375483bf.73febc"]]},{"id":"375483bf.73febc","type":"xiaoai-tts","z":"1b6b56b6.0e6749","name":"","xiaoai":"56e3f67b.3f9a58","tts":"","device":"xxxxxxx","x":410,"y":180,"wires":[[],[]]},{"id":"56e3f67b.3f9a58","type":"xiaoai-tts-configurator","name":""}]
 楼主| 发表于 2021-3-20 20:48:58 | 显示全部楼层
多   谢
发表于 2021-5-24 21:03:23 | 显示全部楼层
大佬,如何播放下载下来的mp3。
发表于 2021-5-27 14:19:26 | 显示全部楼层
zjp0225 发表于 2021-5-24 21:03
大佬,如何播放下载下来的mp3。
我也小白一个,不知道回答的是否对。
貌似如果想让小爱播放mp3的话,必须小爱的版本需要支持dlna,配合daapd插件,来串流播放。但支持dlna的小爱只有特定型号才行。
其余的不支持dlna的小爱,貌似只能用插件实现tts语音播报。
发表于 2021-6-15 15:44:59 | 显示全部楼层
好像没必要绕圈吧,小爱本来就有整点报时的吧
GMT+8, 2025-12-24 21:37 , Processed in 0.830867 second(s), 12 queries , MemCached On.
