查看: 2363|回复: 0
[技术探讨] 请问MQTT连接的设备该如何编写插件?
发表于 2021-3-12 18:40:27 | 显示全部楼层 |阅读模式
设备:海尔小管家吸顶灯
和之前发的帖子探讨的问题一样,在大佬的指引下用fiddler抓了官方网页控制端的包,发现疑似连接到www.doketled.net:8083/mqtt,但直接访问失败(bad request),请问实质上海尔智控是连接到他们的官方MQTT服务器进行统一调控吗?
代码如下,跪求大佬分析:
client = new Paho.MQTT.Client('www.dotekled.net', 8083, "user" + "oM_VjuB0oZKPuR9bINoLQBTo3sqo");
    client.onMessageArrived = onMessageArrived;
    client.connect({
        onSuccess: onConnect,
        onFailure: onFail,
        cleanSession: true
    function onConnect() {
        console.log("onConnect");
        $(".content ul li").each(function (i) {
            var deviceID = $(this).attr("id");
            console.log(deviceID);
            var topicOut = 'device/' + deviceID + '/out';
            var topicOnline = 'device/' + deviceID + '/online';
            var controllerUnbind = 'control/unbind';
            client.subscribe(topicOnline);
            client.subscribe(topicOut);
            client.subscribe(controllerUnbind);
            var topicIn = 'device/' + deviceID + '/in';
            message = new Paho.MQTT.Message("query");
            message.destinationName = topicIn;
            client.send(message);
    function onFail() {
        console.log('连接异常');
    function onMessageArrived(message) {
        console.log("onMessageArrived:" + message.payloadString + '-------' + message.destinationName);
        var t = message.destinationName.split("/");
        var dID = t[1];
        var state = t[2];
        var tID = "#" + dID;
        if (state == 'online') {
            $(".content ul").find(tID).each(function (i) {
                var olPl = message.payloadString;
                if (olPl == 1) {
                    $(this).find('.item-subtitle span').text('设备在线');
                    $(this).find('.item-title span').css("color", '#43F0FE');
                    $(this).find('.item-subtitle span').css("color", '#43F0FE');
                    $(this).find('.secIcon').attr('src','img/secureLog.png');
                    var topicIn = 'device/' + dID + '/in';
                } else {
                    $(this).find('.item-subtitle span').text('设备离线');
                    $(this).find('.item-title span').css("color", 'black');
                    $(this).find('.item-subtitle span').css("color", 'black');
                    $(this).find(".item-content").find(".item-media").find("img").attr("src", "img/lightOff.png");
                    $(this).css("background-color", "white");
                    $(this).find('.secIcon').attr('src','img/secureLogDark.png');
        if (state == 'out') {
                var switchState = message.payloadString.substring(1, 2);
                if (switchState == '0') {
                } else {
                    $(this).find(".item-content").find(".item-media").find("img").attr("src", "img/lightOn.png");
                    $(this).css("background-color", "lightcyan");
        if (message.destinationName == 'control/unbind' && message.payloadString) {
            window.location.href = updateUrl("http://dotekled.net/deviceList");
    // 0 点灯状态 , 1 编辑状态
    var editStatue = 0;
    $(".content ul li .item-inner").each(function (i) {
        $(this).click(function () {
            var olState = $(this).find('.item-subtitle span').text();
            var deviceID = $(this).parent().parent().attr("id");
            if (editStatue == 0) {
                var lightImg = $(this).parent().find('.item-media').find('img').attr("src");
                console.log("list " + i + " deviceID" + deviceID);
                console.log(lightImg);
                if(olState == '设备在线'){
                    var order = "";
                    if (lightImg == "img/lightOn.png") {
                        order = "10";
                        $(this).parent().find('.item-media').find('img').attr("src", "img/lightOff.png");
                        $(this).parent().parent().css("background-color", "white");
                    } else {
                        order = '11';
                        $(this).parent().find('.item-media').find('img').attr("src", "img/lightOn.png");
                        $(this).parent().parent().css("background-color", "lightcyan");
                    console.log("id");
                    message = new Paho.MQTT.Message(order);
            } else {
                var buttons1 = [
                        text: '修改名称',
                        onClick: function () {
                            var delBtn = $(".delBtn");
                            delBtn.css("display", "none");
                            $.prompt('请修改名称', function (value) {
//                                $.alert('Your name is "' + value + '". You clicked Ok button');
                                $.get("http://dotekled.net/api/changeDeviceName",
                                    {deviceID: deviceID, deviceName: value},
                                    function (data) {
                                        if (data == 'succ') {
                                            $.alert('修改名称成功', 'G+智能', function () {
                                        } else {
                                            $.alert('修改名称失败');
                        text: '分享控制权',
                            var url = "/shareDevice/" + deviceID;
                            location.href = url;
                        text: '用户信息',
                            var url = "/userMng/" + deviceID;
                        text: '设备详情',
                            var t1 = deviceID.replace('deviceid', '');
                            var t2 = '设备MAC:' + t1;
                            $.alert(t2);
                        text: '设备解绑',
                            $.get("http://dotekled.net/api/unbindDevice",
                                {ID: deviceID},
                                function (data) {
                                    if (data == 'OK') {
                                        $.alert('解绑成功', 'G+智能', function () {
                                    } else {
                                        $.alert(data);
//                        text: '取消',
//                        color: "danger",
//                        onClick: function () {
//                            editStatue = 0;
//                            var delBtn = $(".delBtn");
//                            delBtn.css("display", "none");
                var buttons2 = [
                        text: '取消',
//                        color: "danger",
                            editStatue = 0;
                var groups = [buttons1,buttons2];
                $.actions(groups);
    $(".content ul li .item-media").each(function (i) {
            var olState = $(this).parent().find('.item-subtitle span').text();
                var lightImg = $(this).attr("src");
                    var order = "";
                        order = "10";
                        $(this).attr("src", "img/lightOff.png");
                    } else {
                        order = '11';
                        $(this).attr("src", "img/lightOn.png");
                    console.log("id");
            } else {
                var buttons1 = [
                        text: '修改名称',
                                    function (data) {
                                        } else {
                                            $.alert('修改名称失败');
                        text: '分享控制权',
                        text: '用户信息',
                        text: '设备详情',
                            $.alert(t2);
                        text: '设备解绑',
                                {ID: deviceID},
                                function (data) {
                                    if (data == 'OK') {
                                    } else {
                                        $.alert(data);
//                        text: '取消',
//                        color: "danger",
//                            editStatue = 0;
                var buttons2 = [
                        text: '取消',
//                        color: "danger",
                            editStatue = 0;
                $.actions(groups);
    $(".content ul li .scIC").each(function (i) {
            var olState = $(this).parent().find('.item-inner .item-subtitle span').text();
                    var order = "";
                        order = "10";
                    } else {
                        order = '11';
                    console.log("id");
            } else {
                var buttons1 = [
                        text: '修改名称',
                                    function (data) {
                                        } else {
                                            $.alert('修改名称失败');
                        text: '分享控制权',
                        text: '用户信息',
                        text: '设备详情',
                            $.alert(t2);
                        text: '设备解绑',
                                {ID: deviceID},
                                function (data) {
                                    if (data == '解绑成功') {
                                        $.alert(data, 'G+智能', function () {
                                    } else {
                                        $.alert(data);
//                        text: '取消',
//                        color: "danger",
                var buttons2 = [
                        text: '取消',
//                        color: "danger",
                            editStatue = 0;
                $.actions(groups);
    $(".content ul li .delBtn").each(function (i) {
            var olState = $(this).children().find('.item-inner .item-subtitle span').text();
                    var order = "";
                        order = "10";
                    } else {
                        order = '11';
                    console.log("id");
            } else {
                var buttons1 = [
                        text: '修改名称',
                                    function (data) {
                                        } else {
                                            $.alert('修改名称失败');
                        text: '分享控制权',
                        text: '用户信息',
                        text: '设备详情',
                            $.alert(t2);
                        text: '设备解绑',
                                {ID: deviceID},
                                function (data) {
                                    } else {
                                        $.alert(data);
//                        text: '取消',
//                        color: "danger",
                var buttons2 = [
                        text: '取消',
//                        color: "danger",
                            editStatue = 0;
                $.actions(groups);
    //    编辑点击
    $(document).on('click', '#hBtn', function () {
        var btnTitle;
//        if (editStatue == 0){
//            btnTitle = '编辑设备';
//        }else {
//            btnTitle = '退出编辑';
        if (delBtn.css("display") == "none") {
            btnTitle = '编辑设备';
        else {
            btnTitle = '退出编辑';
        var buttons1 = [
                text: '请选择',
                label: true
                text: '添加设备',
                    location.href = "/addDevice";
                text: btnTitle,
                        delBtn.css("display", "block");
                        editStatue = 1;
                    else {
                        editStatue = 0;
                text: '一键全关',
                onClick:function () {
                        message = new Paho.MQTT.Message('10');
        var buttons2 = [
                text: '取消',
//                bg: 'danger'
                    console.log("取消");
        var groups = [buttons1, buttons2];
        $.actions(groups);
    function updateUrl(url,key){
        var key= (key || 't') +'=';  //默认key是"t",可以传入key自定义
        var reg=new RegExp(key+'\\d+');  //正则:t=1472286066028
        var timestamp=+new Date();
        if(url.indexOf(key)>-1){ //有时间戳,直接更新
            return url.replace(reg,key+timestamp);
        }else{  //没有时间戳,加上时间戳
            if(url.indexOf('\?')>-1){
                var urlArr=url.split('\?');
                if(urlArr[1]){
                    return urlArr[0]+'?'+key+timestamp+'&'+urlArr[1];
                }else{
                    return urlArr[0]+'?'+key+timestamp;
            }else{
                if(url.indexOf('#')>-1){
                    return url.split('#')[0]+'?'+key+timestamp+location.hash;
                }else{
                    return url+'?'+key+timestamp;
</script>
</body>
</html>
GMT+8, 2025-11-5 05:23 , Processed in 0.106221 second(s), 6 queries , MemCached On.
