查看: 65223|回复: 32
[技术探讨] 摸着石头过河,DIY把普通风扇改造接入ha
发表于 2021-3-6 18:28:02 | 显示全部楼层 |阅读模式
天气越来越热了,心想怎么把普通风扇接入ha,学习了几遍论坛的diy改造风扇帖子确定亲自动手试试
esp8266----------- 一个
5v变压器---------- 一个
3路继电器-------- 一个
风扇开关改造一下 拆开把里面的卡扣拿出来,原本按一下会卡着,需要按第一个按钮才可以回弹,现在一下自动回弹。
软件的是esphome。按键设定 按一下开/关。 长按1秒上面3个任意按键关
现在有个小问题, 风扇在第一次通电,GPIO16回接通0点几秒后关闭,不知道怎么解决
esphome:
platform: ESP8266
board: esp01_1m
wifi:
ssid: "XXX"
password: "XXXXXXXXXXXX"
fast_connect: on
ap:
ssid: "Esp32 01 Fan"
password: "1355955z"
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
#esp32_ble_tracker:
web_server:
port: 80
css_url: https://esphome.io/_static/webserver-v1.min.css
js_url: https://esphome.io/_static/webserver-v1.min.js
switch:
- platform: restart
- platform: gpio
pin: 15
interlock: [mid, fast]
- platform: gpio
pin: 16
interlock: [low, fast]
- platform: gpio
pin: 04
interlock: [low, mid]
#- platform: gpio
#name: "quanguan"
#pin: 4
#inverted: yes
#id: qg
#interlock: [low, mid,fast]
binary_sensor:
#- platform: status
#连接状态
#name: "esp32_fan"
- platform: gpio
pin:
number: 5 #io1接人体感应器
inverted: yes
mode: INPUT
device_class: motion
filters:
- invert:
- delayed_on: 500ms
- delayed_off: 30s
- platform: gpio
pin:
number: GPIO14
mode: INPUT_PULLUP
inverted: True
on_click:
min_length: 10ms
max_length: 500ms
then:
- switch.toggle: low
- platform: gpio
pin:
number: GPIO12
mode: INPUT_PULLUP
inverted: True
on_click:
min_length: 10ms
max_length: 500ms
then:
- switch.toggle: mid
- platform: gpio
pin:
number: GPIO13
mode: INPUT_PULLUP
inverted: True
on_click:
min_length: 10ms
max_length: 500ms
then:
- switch.toggle: fast
- platform: gpio
pin:
number: GPIO13
mode: INPUT_PULLUP
inverted: True
on_click:
min_length: 600ms
max_length: 5000ms
then:
- switch.turn_off: fast
- switch.turn_off: mid
- switch.turn_off: low
- platform: gpio
pin:
number: GPIO14
mode: INPUT_PULLUP
inverted: True
on_click:
min_length: 600ms
max_length: 5000ms
then:
- platform: gpio
pin:
number: GPIO12
mode: INPUT_PULLUP
inverted: True
on_click:
min_length: 600ms
max_length: 5000ms
then:
 - platform: template
    sensors:
      fan_speeds:
        value_template: >
          {% if states('switch.fanlow') == 'unavailable' %}
            unavailable
          {% elif states('switch.fanfast') == 'on' %}
            高速
          {% elif states('switch.fanmid') == 'on' %}
            中速
          {% elif states('switch.fanlow') == 'on' %}
            低速
          {% else %}
            关闭
          {% endif %}
fan:        #建立一个fan元件
    fans:
      fan_speed:
        value_template: >
          {% if is_state("sensor.fan_speeds", "unavailable") %}
            off
          {% elif states('sensor.fan_speeds') == '关闭' %}
            off
          {% else %}
            on
          {% endif %}
        speed_template: '{{ states("sensor.fan_speeds") }}'
        turn_on:
          - service: switch.turn_on
            entity_id: switch.fanlow
        turn_off:
          - service: switch.turn_off
            entity_id: switch.fanmid
            entity_id: switch.fanfast
        set_speed:
            data_template:
              entity_id: >
                {% if speed == '低速' %}
                  switch.fanlow
                {% elif speed == '中速' %}
                  switch.fanmid
                {% elif speed == '高速' %}
                  switch.fanfast
                {% elif speed == '关闭' %}
                  switch.off
                {% endif %}
        speeds:
          - '关闭'
          - '低速'
          - '中速'
          - '高速'
homekit:
  filter:
    include_domains:
      - fan
参与人数 6金钱 +48 HASS币 +20 收起 理由
yamqq2009 + 5 感谢楼主分享!
taida + 5
sorrypqa + 8 大神666!
neoyang + 5
+ 20 + 20 厉害了word楼主!
kleinsoul + 5 感谢楼主分享!
发表于 2021-3-8 11:23:12 | 显示全部楼层
改装类大神多,发详细教程的几乎没有。
发表于 2021-3-9 18:03:54 | 显示全部楼层
厉害了我的楼主
发表于 2021-3-12 03:07:21 | 显示全部楼层
这个好!可以按图索骥
发表于 2021-3-13 14:29:07 | 显示全部楼层
学习学习!
发表于 2023-3-14 18:28:40 | 显示全部楼层
为什么下面传感器和风扇代码用不了呢?要报错,新版本不支持?
 楼主| 发表于 2023-3-15 08:41:56 | 显示全部楼层
是的是的 ha更新了
发表于 2023-3-15 09:21:54 | 显示全部楼层
不清楚的,只有在试试,谢谢啦,@gmshiwoge
yaml文件添加fan出错
yaml文件添加fan出错
 楼主| 发表于 2023-3-15 09:57:41 | 显示全部楼层
我后面修改的
fan:        #建立一个fan元件
    fans:
      fan_speed:
        value_template: >
            off
            off
          {% else %}
            on
          {% endif %}
        percentage_template: >-
             {%if states("switch.fanfast") == 'on' -%}
              100
             {%- elif states("switch.fanmid") == 'on' -%}
              66
             {%- elif states("switch.fanlow") == 'on' -%}
             {%- else -%}
             {%- endif %}
        turn_on:
        turn_off:
          - service: script.turn_on
            entity_id: script.fan_off
        set_percentage:
          service: homeassistant.turn_on
          target:
            entity_id: >-
              {%if percentage>0 and percentage <=33 -%}
                {% set percentage=33 %}
              {%- elif percentage>33 and percentage <=66 -%}
                {% set percentage=66 %}
              {%- elif percentage>66 -%}
                {% set percentage=100 %}
              {%- else -%}
                {% set percentage=0 %}
              {%- endif %}
              {%if percentage == 100 -%}
                switch.fanfast
              {%- elif percentage ==66 -%}
                switch.fanmid
              {%- elif percentage ==33 -%}
                switch.fanlow
              {%- else -%}
                script.fan_off
              {%- endif %}
        speed_count: 3
发表于 2023-3-15 10:09:37 | 显示全部楼层
谢谢@gmshiwoge ,我试试,
GMT+8, 2025-12-18 15:52 , Processed in 1.387844 second(s), 12 queries , MemCached On.
