查看: 16912|回复: 1
[求助] 小爱音箱play 变砖 只亮蓝灯求助 已经TTL连接
发表于 2021-2-25 23:10:41 | 显示全部楼层 |阅读模式
[183]HELLO! SBOOT is starting!
[186]sboot commit : 38c3a04b2a905c8689df26944e3d69666e680ae4
[223]set pll start
[225]set pll end
[227]board init ok
[229]try to probe rtc region
[232]the chip id is 0x1
[234]the chip id is 0x1
[236]the chip id is 0x1
[238]the chip id is 0x1
[241]the chip id is 0x1
[243]chip id check OK
[245]DRAM BOOT DRIVE INFO: V0.18
[248]DRAM CLK = 528 MHz
[251]DRAM Type = 2 (2DR2,3DR3)
[254]DRAMC ZQ value: 0x3bf9
[257]DRAM ODT value: 0x40.
[260]DRAM SIZE =64 M
[263]DRAM simple test OK.
[266]spinand UBOOT_START_BLK_NUM 8 UBOOT_LAST_BLK_NUM 40
[271]block from 8 to 40
[694]Check is correct.
[696]OLD version: 0.0
[698]NEW version: 0.0
[770]load rotpk hash
[832]load optee-key hash
[897]load kernel1-key hash
[961]load kernel2-key hash
[1026]load rootfs1-key hash
[1091]load rootfs2-key hash
[1158]load u-boot-key hash
[1166]monitor entry=0x0
[1168]uboot entry=0x43000000
[1171]optee entry=0x41a00000
[1174]run out of boot0
U-Boot 2018.05 (Jun 06 2019 - 06:03:47 +0000) Allwinner Technology, Build: jenkins-Mico_lx05_ota_publish-32
CPU:   Allwinner Family
Model: sun8iw18
I2C:   ready
DRAM:  64 MiB
Relocation Offset is: 00f48000
secure enable bit: 1
CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=264Mhz
initr_ledc
ledc_init ok
workmode = 0,storage type = 0
NAND_UbootInit
[01.338]NAND_UbootInit start
[01.341]NB1: enter NAND_LogicInit
Change PC_Power Mode Select to 1.8V
Change PC_Power Mode Select to 3.3V
[01.355] no nand found !
[01.357]nand_physic_init nand_build_nsi error
[01.361]nand_physic_init error -1
[01.364]SpiNandHwInit: Start Nand Hardware initializing .....
[01.370]uboot: nand version: 3 6058 20190419 18212019
[01.379]uboot nand_request_tx_dma: reqest genernal dma for nand success, 0x43fb581c
[01.386]uboot nand_request_tx_dma: reqest genernal dma for nand success, 0x43fb5838
sclk0_reg_adr: 0x8300030e, src clock: 0xb8003100
sclk0_reg_adr: 0x8300020e, src clock: 0xb8003100
sclk0_reg_adr: 0x8300000b, src clock: 0xb8003100
[01.419]not burn nand partition table!
[01.423]NB1: nftl num: 1
[01.425]init nftl: 0
[01.653][ND] not find panic data, no need to recovery!
[01.658]NB1: NAND_LogicInit ok, result = 0x0
[01.662]NAND_UbootInit end: 0x0
sunxi flash init ok
Loading Environment from SUNXI_FLASH... OK
keybox_list not set in env, leave empty
the secure storage map is empty
In:    serial
Out:   serial
Err:   serial
gic: sec monitor mode
(weak)update dtb dram start
update dtb dram  end
[01.711]update dts
[01.713]update part info
[01.716]flag_try_sys1_failed=0
[01.718]flag_try_sys2_failed=0
[01.721]flag_ota_reboot     =0
[01.724]flag_last_success   =0
[01.726]os index:0
[01.729]to be run cmd=run setargs_first boot_first
Net:   Net Initialization Skipped
No ethernet found.
[01.740]probe MP tools from boot
delay time 0
weaktg_phy_config
[01.749]usb init ok
[02.251]usb overtime
try to burn key
out of usb burn from boot: not need burn key
Hit any key to stop autoboot:  0
partinfo: name kernel1, start 0x600, size 0x3000
pubkey rootfs1 valid
partition rootfs1 verify pass
total_len=3123200
pubkey kernel1 valid
## Booting Android Image at 0x40007800 ...
Android's image name: cowbell-lx05
Kernel load addr 0x40008000 size 3046 KiB
RAM disk load addr 0x41000000 size 1 KiB
   XIP Kernel Image ... OK
   Loading Ramdisk to 42b12000, end 42b1200c ... OK
   reserving fdt memory region: addr=41a00000 size=100000
   Using Device Tree in place at 42b172e8, end 42b2ae67
[02.662]Starting kernel ...
NAND_UbootExit
[02.665]NB1: NAND_LogicExit
nand release dma:43fb581c
nand release dma:0
[    0.088287] Initramfs unpacking failed: junk in compressed archive
/dev/by-name/UDISK: UUID="7df02a1b-fbaa-40c2-9093-67640887beae" NAME="EXT_JOURNAL" VERSION="1.0" TYPE="ext4"
/dev/by-name/UDISK already format by ext4
请问putty里面显示的这些启动数据说明了什么问题
怎么解决,
我有看到说格式化请问怎么操作
发表于 2021-7-18 08:35:35 | 显示全部楼层
启动的应该没问题,输出这个信息之后,按一下回车,应该会出现 用户登录信息;
登录信息root  密码的话根据sn计算,计算方式在论坛中有文章可以学习;
GMT+8, 2025-12-22 16:58 , Processed in 0.053559 second(s), 18 queries , MemCached On.
