查看: 14740|回复: 0
[进阶教程] traccar获取到数据后为何经纬度显示为0呢?
发表于 2021-2-21 18:33:06 | 显示全部楼层 |阅读模式
我可以获取到设备GT06的数据,在日志里面也可以看到是正常的,但在web界面看为何是0呢?
<?xml version='1.0' encoding='UTF-8'?>
<!DOCTYPE properties SYSTEM 'http://java.sun.com/dtd/properties.dtd'>
<properties>
    <entry key='config.default'>./conf/default.xml</entry>
    This is the main configuration file. All your configuration parameters should be placed in this file.
    Default configuration parameters are located in the "default.xml" file. You should not modify it to avoid issues
    with upgrading to a new version. Parameters in the main config file override values in the default file. Do not
    remove "config.default" parameter from this file unless you know what you are doing.
    For list of available parameters see following page: https://www.traccar.org/configuration-file/
    <entry key='web.port'>8082</entry>
    <entry key='web.debug'>true</entry>
    <entry key='geocoder.enable'>true</entry>
    <entry key='geocoder.type'>nominatim</entry>
    <entry key='geocoder.url'>https://nominatim.openstreetmap.org/reverse</entry>
    <entry key='database.driver'>com.mysql.cj.jdbc.Driver</entry>
    <entry key='database.url'>jdbc:mysql://10.10.10.10:3306/traccar2?serverTimezone=UTC&useSSL=false&allowMultiQueries=true&autoReconnect=true&useUnicode=yes&characterEncoding=UTF-8&sessionVariables=sql_mode='TRADITIONAL,ALLOW_INVALID_DATES'</entry>
    <entry key='database.user'>root</entry>
    <entry key='database.password'>123456</entry>
    <entry key='database.changelog'>/opt/traccar/data/changelog-4.0-clean.xml</entry>
    <entry key='server.timeout'>120</entry>
    <entry key='time.override'>deviceTime</entry>
    <entry key='time.protocols'>osmand,gt06</entry>
    <entry key='web.healthCheck'>false</entry>
    <entry key='gt06.port'>5023</entry>
    <entry key='osmand.port'>5055</entry>
    <entry key='logger.enable'>true</entry>
    <entry key='logger.level'>INFO</entry>
    <entry key='logger.file'>logs/traccar-user.log</entry>
</properties>
GMT+8, 2025-12-29 10:27 , Processed in 1.579582 second(s), 7 queries , MemCached On.
