查看: 11033|回复: 3
[基础教程] 关于开机启动py脚本
发表于 2017-9-19 07:39:13 | 显示全部楼层 |阅读模式
  网上有很多方案,下面我列出我最顺手的防范.
  原理:通过在init.d下创建服务,通过服务来启动脚本
  1.创建服务.
sudo nano /etc/init.d/fan
创建服务文件"fan"
fan内容:
#!/bin/bash
#!/bin/bash
### BEGIN INIT INFO
# Provides:          any
# Required-Start:    $local_fs $network
# Required-Stop:     $local_fs
# Default-Start:     2 3 4 5
# Default-Stop:      0 1 6
# Short-Description: auto-fan service
# Description:       auto-fan service daemon
### END INIT INFO
case "$1" in
  start)
        echo -n "Starting python: "
        echo "---------------------------------------------------------------------------------" >>/var/log/python
        date +"! %T %a %D : Starting python ." >>/var/log/python
                echo start
        python  /home/pi/scp/fan.py &
                #sh /root/finmonAgent/startpy
        echo "Done."
        echo ""
        date +"! %T %a %D : Finished." >>/var/log/python
        touch /var/lock/subsys/python
  stop)
        echo -n "Shutting Down python Listeners: "
        date +"! %T %a %D : Shutting Down python." >>/var/log/python
                echo "python"
        killall -9 finmonAgent.py
        echo "Done."
        rm -f /var/lock/subsys/python
        echo "Done."
  echo "Usage: python { start | stop | restart }"
  exit 1
esac
exit 0
ctrl+o保存
ctrl+x退出
2.重新载入服务
systemctl daemon-reload
启动服务
systemctl start fan
停止服务
systemctl stop fan
重启服务
systemctl restart fan
查询服务状态
systemctl status fan
设置开机启动
systemctl enable fan
2.2方案BBBBB
sudo chmod 755 /etc/init.d/homebridge
sudo update-rc.d homebridge defaults
sudo reboot重启就成功了。
[/hide]
3.顺便保存自动风扇的脚本
import RPi.GPIO as GPIO
import time
import commands
T_HIGH = 52
T_LOW = 40
fan_pin = 40
GPIO.setwarnings(False)
GPIO.setmode(GPIO.BOARD)
GPIO.setup(fan_pin, GPIO.OUT)
def get_gpu_temp():
    gpu_temp = commands.getoutput( '/opt/vc/bin/vcgencmd measure_temp' ).replace( 'temp=', '' ).replace( '\'C', '' )
    return  float(gpu_temp)
GPIO.output(fan_pin, 1)#第一次通电,风扇默认开转.
while 1:
    gpu_temp_loop = get_gpu_temp()
    print 'CPU temp:', gpu_temp_loop,'C'
    if gpu_temp_loop > T_HIGH:
    elif gpu_temp_loop < T_LOW:
        GPIO.output(fan_pin, 0)
    time.sleep(5)
发表于 2017-9-19 20:18:59 | 显示全部楼层
现在一般用systemd方式启动了吧,还方便一些
 楼主| 发表于 2017-9-19 22:01:30 | 显示全部楼层
这....是真的不会,出个教程吧
教程狂人论坛风云人物突出贡献
发表于 2017-10-2 15:17:55 来自手机 | 显示全部楼层
服务更方便,还能监控还能自动重启
GMT+8, 2025-12-24 17:13 , Processed in 0.638642 second(s), 5 queries , MemCached On.
