查看: 10461|回复: 3
[求助] Zigbee2mqtt 调试求助帖
Moin
发表于 2021-2-1 22:07:15 | 显示全部楼层 |阅读模式
小白一枚!在某鱼入手妖神版的zigbee2mqtt自制网关一个,目的就是想把家里的小米zigbee版插座及人体红外感应接入homeassistant。但调试遇到瓶颈,求助大神!
现象:MQTT已调通,通过IOS端的MQTTool试验没有问题!但是插件zigbee2mqtt显示 502: Bad Gateway。日志如下:
> node index.jsZigbee2MQTT:info 2021-02-01 22:02:59: Logging to console and directory: '/share/zigbee2mqtt/log/2021-02-01.22-02-58' filename: log.txtZigbee2MQTT:info 2021-02-01 22:02:59: Starting Zigbee2MQTT version 1.17.0 (commit #1.17.0)Zigbee2MQTT:info 2021-02-01 22:02:59: Starting zigbee-herdsman (0.13.46)Zigbee2MQTT:error 2021-02-01 22:03:19: Error while starting zigbee-herdsmanZigbee2MQTT:error 2021-02-01 22:03:19: Failed to start zigbeeZigbee2MQTT:error 2021-02-01 22:03:19: Exiting...Zigbee2MQTT:error 2021-02-01 22:03:19: Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)    at ZStackAdapter.<anonymous> (/zigbee2mqtt-1.17.0/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:94:31)    at Generator.throw (<anonymous>)    at rejected (/zigbee2mqtt-1.17.0/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:25:65)npm ERR! code ELIFECYCLEnpm ERR! errno 1npm ERR! [email protected] start: `node index.js`npm ERR! Exit status 1npm ERR! npm ERR! Failed at the [email protected] start script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.npm ERR! A complete log of this run can be found in:npm ERR!     /root/.npm/_logs/2021-02-01T14_03_19_098Z-debug.log2021-02-01T22:03:19: PM2 log: App [npm:0] exited with code [1] via signal [SIGINT]2021-02-01T22:03:19: PM2 log: App [npm:0] starting in -fork mode-2021-02-01T22:03:19: PM2 log: App [npm:0] online
能否给些提示,从哪个地方入手。
发表于 2021-2-1 22:57:16 | 显示全部楼层
是不是网关没连同啊
Moin
 楼主| 发表于 2021-2-2 11:24:08 | 显示全部楼层
guitengyue 发表于 2021-2-1 22:57
是不是网关没连同啊
感谢回复,应该是连通了,我用MQTT的监听功能,可以接收到网关相应的字节。。。
发表于 2021-11-18 10:49:17 来自手机 | 显示全部楼层
怎么解决的,我的也是这样。
GMT+8, 2025-12-22 05:47 , Processed in 0.208682 second(s), 5 queries , MemCached On.
