楼主: diba.qiu
[插件集成] 科沃斯掃地機器人插件(支持內地伺服器),親測可用
 楼主| 发表于 2021-2-2 13:37:19 | 显示全部楼层
ddkens 发表于 2021-2-2 00:22
可以了,在app里改了一下名字就有了,感谢
恭喜恭喜
发表于 2021-2-3 18:09:05 | 显示全部楼层
dd35哭晕在厕所
nut
发表于 2021-2-9 09:21:37 | 显示全部楼层
大神,username怎么获取啊?
 楼主| 发表于 2021-2-9 10:14:18 | 显示全部楼层
nut 发表于 2021-2-9 09:21
大神,username怎么获取啊?
打開手機APP,
我的\
設定\
帳號與安全\
ECOVACS ID就是了
nut
发表于 2021-2-9 16:18:58 | 显示全部楼层
diba.qiu 发表于 2021-2-9 10:14
打開手機APP,
我的\
設定\
好的,谢谢。我试试
发表于 2021-2-19 13:32:08 | 显示全部楼层
这个需要点赞,测试成功!
yuyj 手机认证
发表于 2021-2-25 10:45:44 来自手机 | 显示全部楼层
这个需不需要一直联网?
发表于 2021-2-28 19:31:23 | 显示全部楼层
Deebot U2 成功了,感谢博主
发表于 2021-3-8 22:42:04 | 显示全部楼层
大佬,请问这个插件只能在hassio中使用吗?我直接用的homeassistant官方的系统Home Assistant OS,运行插件时候报错了。报错代码如下:
2021-03-08 11:56:47 ERROR (MainThread) [homeassistant.bootstrap] Error setting up integration deebot - received exception
File "/usr/src/homeassistant/homeassistant/setup.py", line 64, in async_setup_component
return await task # type: ignore
File "/usr/src/homeassistant/homeassistant/setup.py", line 158, in _async_setup_component
await async_process_deps_reqs(hass, config, integration)
File "/usr/src/homeassistant/homeassistant/setup.py", line 343, in async_process_deps_reqs
await requirements.async_get_integration_with_requirements(
File "/usr/src/homeassistant/homeassistant/requirements.py", line 79, in async_get_integration_with_requirements
await async_process_requirements(
File "/usr/src/homeassistant/homeassistant/requirements.py", line 126, in async_process_requirements
if pkg_util.is_installed(req):
File "/usr/src/homeassistant/homeassistant/util/package.py", line 44, in is_installed
return version(req.project_name) in req
File "/usr/local/lib/python3.8/site-packages/pkg_resources/__init__.py", line 3129, in __contains__
return self.specifier.contains(item, prereleases=True)
File "/usr/local/lib/python3.8/site-packages/pkg_resources/_vendor/packaging/specifiers.py", line 789, in contains
item = parse(item)
File "/usr/local/lib/python3.8/site-packages/pkg_resources/_vendor/packaging/version.py", line 56, in parse
return Version(version)
File "/usr/local/lib/python3.8/site-packages/pkg_resources/_vendor/packaging/version.py", line 275, in __init__
match = self._regex.search(version)
TypeError: expected string or bytes-like object
小白完全看不懂这是什么意思,希望有大佬能说下这是什么原因。。
 楼主| 发表于 2021-3-11 20:15:54 来自手机 | 显示全部楼层
Echolover8023 发表于 2021-3-8 22:42
大佬,请问这个插件只能在hassio中使用吗?我直接用的homeassistant官方的系统Home Assistant OS,运行插件 ...
不好意思我也看不懂這什麼意思,我本來docker現在轉到官方OS也都能用耶
GMT+8, 2026-1-14 18:53 , Processed in 0.635129 second(s), 11 queries , MemCached On.
