楼主: Magic_Shine
[技术探讨] 求教天猫精灵接入NR之后,如何控制本地开关
发表于 2021-1-27 23:43:27 | 显示全部楼层
243539661 发表于 2021-1-27 21:56
麻烦您做个流参考下好吗
[{"id":"dc8984ba.4fc768","type":"switch","z":"ce1f9638.59b5a8","name":"","property":"payload.powerstate","propertyType":"msg","rules":[{"t":"eq","v":"1","vt":"str"},{"t":"eq","v":"0","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":550,"y":2440,"wires":[["84fdc694.6ee8e8","118dd7f3.6e96f8"],["9606bc07.57c93","118dd7f3.6e96f8"]]},{"id":"118dd7f3.6e96f8","type":"aliyun","z":"ce1f9638.59b5a8","DeviceName":"light-b","ProductKey":"1212312","DeviceSecret":"12312312312312","name":"小米夜灯","x":540,"y":2540,"wires":[["dc8984ba.4fc768"],["109abc8f.f73663"]]},{"id":"84fdc694.6ee8e8","type":"api-call-service","z":"ce1f9638.59b5a8","name":"","server":"2b887588.e131fa","version":1,"debugenabled":false,"service_domain":"light","service":"turn_on","entityId":"light.gateway_light_04cf8ca9cb57","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":810,"y":2440,"wires":[[]]},{"id":"9606bc07.57c93","type":"api-call-service","z":"ce1f9638.59b5a8","name":"","server":"2b887588.e131fa","version":1,"debugenabled":false,"service_domain":"light","service":"turn_off","entityId":"light.gateway_light_04cf8ca9cb57","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":810,"y":2500,"wires":[[]]},{"id":"109abc8f.f73663","type":"image","z":"ce1f9638.59b5a8","name":"","width":160,"data":"payload","dataType":"msg","thumbnail":false,"active":true,"pass":false,"outputs":0,"x":760,"y":2560,"wires":[]},{"id":"2b887588.e131fa","type":"server","z":"","name":"Home Assistant","legacy":false,"addon":false,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true}]
发表于 2021-1-28 22:15:40 来自手机 | 显示全部楼层
hunterfox 发表于 2021-1-27 23:43
这个我会,函数不会,我该去哪里学一下?
发表于 2021-1-29 09:57:49 | 显示全部楼层
243539661 发表于 2021-1-28 22:15
这个我会,函数不会,我该去哪里学一下?
慢慢折腾 从传递一个payload 开始  ,先给自己找个需求,然后往需求努力。
GMT+8, 2025-8-24 04:19 , Processed in 0.087732 second(s), 8 queries , MemCached On.
