查看: 12509|回复: 2
[技术探讨] 我这边有几个东西报错有大神解答下不。
发表于 2021-1-24 12:57:38 | 显示全部楼层 |阅读模式
先说我的环境,UNRAID 下的DOCKER安装的HASS核心版本。然后运行报错如下,各种搜也搜不到结果。。。。有看的懂的人没啊
Logger: homeassistant.components.websocket_api.http.connection
Source: custom_components/hitachi/climate.py:444
Integration: Home Assistant WebSocket API ([color=var(--primary-color)]documentation
, [color=var(--primary-color)]issues
First occurred: 下午12:46:09 (4 occurrences)
Last logged: 下午12:46:12
[22404597241072] [Errno -5] The device storage is fullTraceback (most recent call last):  File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 135, in handle_call_service    await hass.services.async_call(  File "/usr/src/homeassistant/homeassistant/core.py", line 1445, in async_call    task.result()  File "/usr/src/homeassistant/homeassistant/core.py", line 1480, in _execute_service    await handler.job.target(service_call)  File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 204, in handle_service    await self.hass.helpers.service.entity_service_call(  File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 593, in entity_service_call    future.result()  # pop exception if have  File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 664, in async_request_call    await coro  File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 630, in _handle_entity_call    await result  File "/config/custom_components/hitachi/climate.py", line 338, in async_set_hvac_mode    await self._sendpacket('operation')  File "/config/custom_components/hitachi/climate.py", line 444, in _sendpacket    self._controller.send_data(b64decode(packet))  File "/usr/local/lib/python3.8/site-packages/broadlink/remote.py", line 31, in send_data    check_error(response[0x22:0x24])  File "/usr/local/lib/python3.8/site-packages/broadlink/exceptions.py", line 137, in check_error    raise exception(error_code)broadlink.exceptions.StorageError: [Errno -5] The device storage is full
发表于 2021-1-24 22:26:22 | 显示全部楼层
磁盘满了
 楼主| 发表于 2021-1-25 17:58:58 | 显示全部楼层
磁盘满了
我宿主机的硬盘3T呢,理论上不应该啊。不知道咋回事。
GMT+8, 2025-12-29 14:22 , Processed in 1.457264 second(s), 7 queries , MemCached On.
