查看: 2607|回复: 7
[基础教程] debian10使用python3安装ha求助
发表于 2021-1-24 10:56:53 | 显示全部楼层 |阅读模式
使用debian10装了最新的Python3.9.1,pip3安装了homeassistant,但是hass --open-ui就出问题,实体机和虚拟机都这样报错,都是按照网上的教程一步步来的,就很奇怪。希望大神能指点指点。没有通过python的venv安装。
root@debian-homeassistant-test:~# hass --open -ui
usage: hass [-h] [--version] [-c path_to_config_dir] [--safe-mode] [--debug] [--open-ui] [--skip-pip] [-v] [--pid-file path_to_pid_file]
            [--log-rotate-days LOG_ROTATE_DAYS] [--log-file LOG_FILE] [--log-no-color] [--runner] [--script ...] [--daemon]
hass: error: unrecognized arguments: -ui
root@debian-homeassistant-test:~# hass --open-ui
2021-01-24 10:49:43 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: No module named '_sqlite3' (retrying in 3 seconds)
2021-01-24 10:49:46 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: No module named '_sqlite3' (retrying in 3 seconds)
2021-01-24 10:49:49 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: No module named '_sqlite3' (retrying in 3 seconds)
2021-01-24 10:49:52 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: No module named '_sqlite3' (retrying in 3 seconds)
2021-01-24 10:49:53 WARNING (MainThread) [homeassistant.setup] Setup of recorder is taking over 10 seconds.
2021-01-24 10:49:55 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: No module named '_sqlite3' (retrying in 3 seconds)
2021-01-24 10:49:58 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: No module named '_sqlite3' (retrying in 3 seconds)
2021-01-24 10:50:01 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: No module named '_sqlite3' (retrying in 3 seconds)
2021-01-24 10:50:04 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: No module named '_sqlite3' (retrying in 3 seconds)
2021-01-24 10:50:07 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: No module named '_sqlite3' (retrying in 3 seconds)
2021-01-24 10:50:10 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: No module named '_sqlite3' (retrying in 3 seconds)
2021-01-24 10:50:10 ERROR (MainThread) [homeassistant.setup] Setup failed for recorder: Integration failed to initialize.
2021-01-24 10:50:13 ERROR (SyncWorker_1) [homeassistant.util.package] Unable to install package pillow==7.2.0: ERROR: Command errored out with exit status 1:
     command: /usr/local/bin/python3.9 -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-r1tp0fj6/pillow/setup.py'"'"'; __file__='"'"'/tmp/pip-install-r1tp0fj6/pillow/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-66dzbtwu/install-record.txt --single-version-externally-managed --prefix '' --user --prefix= --compile --install-headers /root/.homeassistant/deps/include/python3.9/pillow
         cwd: /tmp/pip-install-r1tp0fj6/pillow/
    Complete output (172 lines):
    running install
    running build
    running build_py
    creating build
    creating build/lib.linux-x86_64-3.9
    creating build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/WebPImagePlugin.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/MpegImagePlugin.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/PyAccess.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/DdsImagePlugin.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/ContainerIO.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/MspImagePlugin.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/GimpPaletteFile.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/PcfFontFile.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/PixarImagePlugin.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/ImageFilter.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/FontFile.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/XpmImagePlugin.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/Jpeg2KImagePlugin.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/ImageChops.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/JpegImagePlugin.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/ImageStat.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/PpmImagePlugin.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/PalmImagePlugin.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/ImImagePlugin.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/ImageFont.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/FpxImagePlugin.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/SpiderImagePlugin.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/GdImageFile.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/ImageMorph.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/IcoImagePlugin.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/BdfFontFile.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/MicImagePlugin.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/PcdImagePlugin.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/ImageEnhance.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/ImageDraw2.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/ImageQt.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/XbmImagePlugin.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/ImagePalette.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/ImageTk.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/ImageWin.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/PdfParser.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/ImageGrab.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/JpegPresets.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/ImageCms.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/CurImagePlugin.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/BlpImagePlugin.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/features.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/FitsStubImagePlugin.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/ImageColor.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/ImageMath.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/ImageOps.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/PngImagePlugin.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/WalImageFile.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/EpsImagePlugin.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/ImageFile.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/ExifTags.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/GribStubImagePlugin.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/Image.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/PcxImagePlugin.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/__init__.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/BmpImagePlugin.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/BufrStubImagePlugin.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/GimpGradientFile.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/TgaImagePlugin.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/ImageTransform.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/TiffTags.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/PaletteFile.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/TiffImagePlugin.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/McIdasImagePlugin.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/WmfImagePlugin.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/_binary.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/SgiImagePlugin.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/XVThumbImagePlugin.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/DcxImagePlugin.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/__main__.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/PSDraw.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/_version.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/ImageDraw.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/ImageShow.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/ImageSequence.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/TarIO.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/GifImagePlugin.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/IptcImagePlugin.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/SunImagePlugin.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/PsdImagePlugin.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/_tkinter_finder.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/MpoImagePlugin.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/ImageMode.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/GbrImagePlugin.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/ImagePath.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/Hdf5StubImagePlugin.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/PdfImagePlugin.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/FtexImagePlugin.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/ImtImagePlugin.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/IcnsImagePlugin.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/FliImagePlugin.py -> build/lib.linux-x86_64-3.9/PIL
    copying src/PIL/_util.py -> build/lib.linux-x86_64-3.9/PIL
    running egg_info
    writing src/Pillow.egg-info/PKG-INFO
    writing dependency_links to src/Pillow.egg-info/dependency_links.txt
    writing top-level names to src/Pillow.egg-info/top_level.txt
    reading manifest file 'src/Pillow.egg-info/SOURCES.txt'
    reading manifest template 'MANIFEST.in'
    warning: no files found matching '*.c'
    warning: no files found matching '*.h'
    warning: no files found matching '*.sh'
    warning: no previously-included files found matching '.appveyor.yml'
    warning: no previously-included files found matching '.coveragerc'
    warning: no previously-included files found matching '.editorconfig'
    warning: no previously-included files found matching '.readthedocs.yml'
    warning: no previously-included files found matching 'codecov.yml'
    warning: no previously-included files matching '.git*' found anywhere in distribution
    warning: no previously-included files matching '*.pyc' found anywhere in distribution
    warning: no previously-included files matching '*.so' found anywhere in distribution
    no previously-included directories found matching '.ci'
    writing manifest file 'src/Pillow.egg-info/SOURCES.txt'
    running build_ext
    The headers or library files could not be found for jpeg,
    a required dependency when compiling Pillow from source.
    Please see the install instructions at:
       https://pillow.readthedocs.io/en/latest/installation.html
      File "/tmp/pip-install-r1tp0fj6/pillow/setup.py", line 864, in <module>
        setup(
      File "/usr/local/lib/python3.9/site-packages/setuptools/__init__.py", line 165, in setup
        return distutils.core.setup(**attrs)
      File "/usr/local/lib/python3.9/distutils/core.py", line 148, in setup
        dist.run_commands()
      File "/usr/local/lib/python3.9/distutils/dist.py", line 966, in run_commands
        self.run_command(cmd)
      File "/usr/local/lib/python3.9/distutils/dist.py", line 985, in run_command
        cmd_obj.run()
      File "/usr/local/lib/python3.9/site-packages/setuptools/command/install.py", line 61, in run
        return orig.install.run(self)
      File "/usr/local/lib/python3.9/distutils/command/install.py", line 546, in run
        self.run_command('build')
      File "/usr/local/lib/python3.9/distutils/cmd.py", line 313, in run_command
        self.distribution.run_command(command)
        cmd_obj.run()
      File "/usr/local/lib/python3.9/distutils/command/build.py", line 135, in run
        self.run_command(cmd_name)
        cmd_obj.run()
      File "/usr/local/lib/python3.9/distutils/command/build_ext.py", line 340, in run
        self.build_extensions()
      File "/tmp/pip-install-r1tp0fj6/pillow/setup.py", line 694, in build_extensions
        raise RequiredDependencyException(f)
    __main__.RequiredDependencyException: jpeg
      File "<string>", line 1, in <module>
      File "/tmp/pip-install-r1tp0fj6/pillow/setup.py", line 918, in <module>
        raise RequiredDependencyException(msg)
ERROR: Command errored out with exit status 1: /usr/local/bin/python3.9 -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-r1tp0fj6/pillow/setup.py'"'"'; __file__='"'"'/tmp/pip-install-r1tp0fj6/pillow/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-66dzbtwu/install-record.txt --single-version-externally-managed --prefix '' --user --prefix= --compile --install-headers /root/.homeassistant/deps/include/python3.9/pillow Check the logs for full command output.
WARNING: You are using pip version 20.2.4; however, version 20.3.3 is available.
You should consider upgrading via the '/usr/local/bin/python3.9 -m pip install --upgrade pip' command.
2021-01-24 10:50:13 ERROR (MainThread) [homeassistant.setup] Setup failed for image: Requirements for image not found: ['pillow==7.2.0'].
2021-01-24 10:50:13 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of person. Setup failed for dependencies: image
2021-01-24 10:50:13 ERROR (MainThread) [homeassistant.setup] Setup failed for person: Could not set up all dependencies.
2021-01-24 10:50:13 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of onboarding. Setup failed for dependencies: person
2021-01-24 10:50:13 ERROR (MainThread) [homeassistant.setup] Setup failed for onboarding: Could not set up all dependencies.
2021-01-24 10:50:13 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of frontend. Setup failed for dependencies: onboarding
2021-01-24 10:50:13 ERROR (MainThread) [homeassistant.setup] Setup failed for frontend: Could not set up all dependencies.
2021-01-24 10:50:14 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of map. Setup failed for dependencies: frontend
2021-01-24 10:50:14 ERROR (MainThread) [homeassistant.setup] Setup failed for map: Could not set up all dependencies.
2021-01-24 10:50:14 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of logbook. Setup failed for dependencies: frontend, recorder
2021-01-24 10:50:14 ERROR (MainThread) [homeassistant.setup] Setup failed for logbook: Could not set up all dependencies.
2021-01-24 10:50:14 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of history. Setup failed for dependencies: recorder
2021-01-24 10:50:14 ERROR (MainThread) [homeassistant.setup] Setup failed for history: Could not set up all dependencies.
2021-01-24 10:50:14 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of mobile_app. Setup failed for dependencies: person
2021-01-24 10:50:14 ERROR (MainThread) [homeassistant.setup] Setup failed for mobile_app: Could not set up all dependencies.
2021-01-24 10:50:14 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of default_config. Setup failed for dependencies: frontend, history, logbook, map, mobile_app, person
2021-01-24 10:50:14 ERROR (MainThread) [homeassistant.setup] Setup failed for default_config: Could not set up all dependencies.
2021-01-24 10:50:14 WARNING (MainThread) [homeassistant.bootstrap] Detected that frontend did not load. Activating safe mode
2021-01-24 10:50:17 ERROR (SyncWorker_4) [homeassistant.util.package] Unable to install package pillow==7.2.0: ERROR: Command errored out with exit status 1:
     command: /usr/local/bin/python3.9 -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-hlqobxpq/pillow/setup.py'"'"'; __file__='"'"'/tmp/pip-install-hlqobxpq/pillow/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-scq8hfm3/install-record.txt --single-version-externally-managed --prefix '' --user --prefix= --compile --install-headers /root/.homeassistant/deps/include/python3.9/pillow
         cwd: /tmp/pip-install-hlqobxpq/pillow/
    running install
    running build
    running build_py
    creating build
    running egg_info
    running build_ext
      File "/tmp/pip-install-hlqobxpq/pillow/setup.py", line 864, in <module>
        setup(
        dist.run_commands()
        cmd_obj.run()
        cmd_obj.run()
        cmd_obj.run()
      File "/tmp/pip-install-hlqobxpq/pillow/setup.py", line 694, in build_extensions
      File "/tmp/pip-install-hlqobxpq/pillow/setup.py", line 918, in <module>
ERROR: Command errored out with exit status 1: /usr/local/bin/python3.9 -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-hlqobxpq/pillow/setup.py'"'"'; __file__='"'"'/tmp/pip-install-hlqobxpq/pillow/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-scq8hfm3/install-record.txt --single-version-externally-managed --prefix '' --user --prefix= --compile --install-headers /root/.homeassistant/deps/include/python3.9/pillow Check the logs for full command output.
2021-01-24 10:50:17 ERROR (MainThread) [homeassistant.setup] Setup failed for image: Requirements for image not found: ['pillow==7.2.0'].
2021-01-24 10:50:17 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of person. Setup failed for dependencies: image
2021-01-24 10:50:17 ERROR (MainThread) [homeassistant.setup] Setup failed for person: Could not set up all dependencies.
2021-01-24 10:50:17 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of onboarding. Setup failed for dependencies: person
2021-01-24 10:50:17 ERROR (MainThread) [homeassistant.setup] Setup failed for onboarding: Could not set up all dependencies.
2021-01-24 10:50:17 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of frontend. Setup failed for dependencies: onboarding
2021-01-24 10:50:17 ERROR (MainThread) [homeassistant.setup] Setup failed for frontend: Could not set up all dependencies.
2021-01-24 10:50:17 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of safe_mode. Setup failed for dependencies: frontend
2021-01-24 10:50:17 ERROR (MainThread) [homeassistant.setup] Setup failed for safe_mode: Could not set up all dependencies.
2021-01-24 10:50:17 WARNING (SyncWorker_0) [homeassistant.bootstrap] Cannot launch the UI because frontend not loaded
发表于 2021-1-24 11:25:10 | 显示全部楼层
最近刚用树莓派安装了,在虚拟容器里面安装的,没啥问题。不是用你这种方法,https://www.e-learn.cn/topic/3753572我是按照这个方法安装的
发表于 2021-1-24 11:27:40 | 显示全部楼层
我是3.85
 楼主| 发表于 2021-1-24 11:33:31 | 显示全部楼层
smartpartner 发表于 2021-1-24 11:25
最近刚用树莓派安装了,在虚拟容器里面安装的,没啥问题。不是用你这种方法,https://www.e-learn.cn/topic/ ...
docker我会弄,我之前就是用的docker,后来换python弄的
 楼主| 发表于 2021-1-24 12:38:09 | 显示全部楼层
有没有大佬解惑啊
发表于 2021-1-24 18:32:47 | 显示全部楼层
那不知道了。
 楼主| 发表于 2021-1-25 11:44:28 | 显示全部楼层
这个论坛都不喜欢小白了吗
 楼主| 发表于 2021-1-27 10:41:46 | 显示全部楼层
搞定啦,把ha目录下的package_constraints.txt内容修改下就可以。运行后网络差异等下载frontend就行了
GMT+8, 2025-11-5 11:17 , Processed in 0.066984 second(s), 11 queries , MemCached On.
