查看: 14660|回复: 4
【求助】群晖上docker重新安装了hassio,恢复了之前的快照.....
发表于 2021-1-23 22:08:20 | 显示全部楼层 |阅读模式
群晖上docker重新安装了hassio,恢复了之前的快照,结果日志里出现如下错误,麻烦看一下怎么解决,谢谢!
Error saving events: (sqlite3.DatabaseError) database disk image is malformed [SQL: INSERT INTO events (event_type, event_data, origin, time_fired, created, context_id, context_user_id, context_parent_id) VALUES (?, ?, ?, ?, ?, ?, ?, ?)] [parameters: ('call_service', '{"domain": "persistent_notification", "service": "dismiss", "service_data": {"notification_id": "config_entry_discovery"}}', 'LOCAL', '2021-01-23 13:47:38.696762', '2021-01-23 13:47:38.696762', '77d885979ca5fd26287f7e442e4daff8', None, None)] (Background on this error at: http://sqlalche.me/e/13/4xp6)
[color=var(--paper-item-body-secondary-color, var(--secondary-text-color))]下午10:02:08 – Recorder ([color=var(--error-color)]ERROR) - 消息首次出现在 下午9:33:24,显示了 12 次
Error executing query: (sqlite3.DatabaseError) database disk image is malformed [SQL: INSERT INTO events (event_type, event_data, origin, time_fired, created, context_id, context_user_id, context_parent_id) VALUES (?, ?, ?, ?, ?, ?, ?, ?)] [parameters: ('state_changed', '{}', 'LOCAL', '2021-01-23 14:00:32.237802', '2021-01-23 14:00:32.237802', '5c8e9473de27bfb6c845b4465be2188f', None, None)] (Background on this error at: http://sqlalche.me/e/13/4xp6)
[color=var(--paper-item-body-secondary-color, var(--secondary-text-color))]下午10:02:08 – Recorder ([color=var(--error-color)]ERROR) - 消息首次出现在 下午9:33:24,显示了 44 次
:0:0 Script error.
[color=var(--paper-item-body-secondary-color, var(--secondary-text-color))]下午10:02:07 – components/system_log/__init__.py ([color=var(--error-color)]ERROR)
Error saving events: (sqlite3.DatabaseError) database disk image is malformed [SQL: INSERT INTO events (event_type, event_data, origin, time_fired, created, context_id, context_user_id, context_parent_id) VALUES (?, ?, ?, ?, ?, ?, ?, ?)] [parameters: ('automation_triggered', '{"name": "\\u5ba2\\u5385\\u81ea\\u52a8\\u5173\\u706f", "entity_id": "automation.ke_ting_zi_dong_guan_deng", "source": "state of binary_sensor.motion_sensor_307d"}', 'LOCAL', '2021-01-23 13:59:35.172421', '2021-01-23 13:59:35.172421', '7bcce46856ce4a1b3cc7762812f57d31', None, '714ac0ecbe3a6b903bf686ecafe509ec')] (Background on this error at: http://sqlalche.me/e/13/4xp6)
[color=var(--paper-item-body-secondary-color, var(--secondary-text-color))]下午10:01:29 – Recorder ([color=var(--error-color)]ERROR) - 消息首次出现在 下午9:34:11,显示了 32 次
Config entry for upnp not ready yet. Retrying in 80 seconds
[color=var(--paper-item-body-secondary-color, var(--secondary-text-color))]下午10:01:21 – config_entries.py ([color=var(--warning-color)]WARNING) - 消息首次出现在 下午9:34:21,显示了 19 次
发表于 2021-1-24 01:56:10 | 显示全部楼层
把configuration文件夹下的home-assistant_v2.db删了重启HA试试看
 楼主| 发表于 2021-1-24 11:21:43 | 显示全部楼层
感谢!删掉果然没有报错了。
发表于 2021-1-24 22:24:25 | 显示全部楼层
cuiyilin 发表于 2021-1-24 11:21
感谢!删掉果然没有报错了。
太好了. 这是数据库引起的错误,你把旧的删了,HA就会重建新的数据库.
发表于 2021-3-9 17:30:10 | 显示全部楼层
我想问下恢复快照完成会有提示么 我怎么恢复的时候点一下就没反应了 但winscp里看文件是在慢慢恢复的
GMT+8, 2025-12-29 08:22 , Processed in 0.246182 second(s), 6 queries , MemCached On.
