- 积分
- 458
- 金钱
- 392
- 威望
- 0
- 贡献
- 0
- HASS币
- 0
- 积分
- 458
- 金钱
- 392
- HASS币
- 0
发表于 2021-10-24 22:03:53
显示全部楼层
接入成功了,可是出现了这个错误:
调用服务 remote/turn_off 失败。 'NoneType' object has no attribute 'get'
Logger: root
Source: /usr/local/lib/python3.9/site-packages/micloud/micloud.py:317
First occurred: 15:00:50 (4 occurrences)
Last logged: 21:39:51
Error while executing request to https://api.io.mi.com/app/miotspec/prop/get 'Connection aborted.', TimeoutError(110, 'Operation timed out'))
File "/usr/local/lib/python3.9/site-packages/urllib3/connectionpool.py", line 699, in urlopen
httplib_response = self._make_request(
File "/usr/local/lib/python3.9/site-packages/urllib3/connectionpool.py", line 382, in _make_request
self._validate_conn(conn)
File "/usr/local/lib/python3.9/site-packages/urllib3/connectionpool.py", line 1010, in _validate_conn
conn.connect()
File "/usr/local/lib/python3.9/site-packages/urllib3/connection.py", line 416, in connect
self.sock = ssl_wrap_socket(
File "/usr/local/lib/python3.9/site-packages/urllib3/util/ssl_.py", line 449, in ssl_wrap_socket
ssl_sock = _ssl_wrap_socket_impl(
File "/usr/local/lib/python3.9/site-packages/urllib3/util/ssl_.py", line 493, in _ssl_wrap_socket_impl
return ssl_context.wrap_socket(sock, server_hostname=server_hostname)
File "/usr/local/lib/python3.9/ssl.py", line 500, in wrap_socket
return self.sslsocket_class._create(
File "/usr/local/lib/python3.9/ssl.py", line 1040, in _create
self.do_handshake()
File "/usr/local/lib/python3.9/ssl.py", line 1309, in do_handshake
self._sslobj.do_handshake()
TimeoutError: [Errno 110] Operation timed out
File "/usr/local/lib/python3.9/site-packages/requests/adapters.py", line 439, in send
resp = conn.urlopen(
File "/usr/local/lib/python3.9/site-packages/urllib3/connectionpool.py", line 755, in urlopen
retries = retries.increment(
File "/usr/local/lib/python3.9/site-packages/urllib3/util/retry.py", line 532, in increment
raise six.reraise(type(error), error, _stacktrace)
File "/usr/local/lib/python3.9/site-packages/urllib3/packages/six.py", line 769, in reraise
raise value.with_traceback(tb)
conn.connect()
self.do_handshake()
urllib3.exceptions.ProtocolError: ('Connection aborted.', TimeoutError(110, 'Operation timed out'))
File "/usr/local/lib/python3.9/site-packages/micloud/micloud.py", line 306, in request
response = self.session.post(url, data = post_data)
File "/usr/local/lib/python3.9/site-packages/requests/sessions.py", line 590, in post
return self.request('POST', url, data=data, json=json, **kwargs)
File "/usr/local/lib/python3.9/site-packages/requests/sessions.py", line 542, in request
resp = self.send(prep, **send_kwargs)
File "/usr/local/lib/python3.9/site-packages/requests/sessions.py", line 655, in send
r = adapter.send(request, **kwargs)
File "/usr/local/lib/python3.9/site-packages/requests/adapters.py", line 498, in send
raise ConnectionError(err, request=request)
requests.exceptions.ConnectionError: ('Connection aborted.', TimeoutError(110, 'Operation timed out'))
大佬能帮忙看看吗 |
