查看: 4849|回复: 3
[已解决] 求助树莓派python安装hass成功以后一直卡住
发表于 2021-1-12 23:53:17 | 显示全部楼层 |阅读模式
有没有大佬帮帮忙看看这是怎么回事啊,树莓派4b,系统什么的都是更新了的,也搭了梯子,python也更新到了3.8.6,但是homeassistant就是不能启动,启动就所有的都是未成功安装,这种应该怎么解决呢?谢谢各位大佬
发表于 2021-1-13 14:25:33 | 显示全部楼层
你用pip env的话得激活虚拟环境
 楼主| 发表于 2021-1-14 01:36:06 | 显示全部楼层
trover 发表于 2021-1-13 14:25
你用pip env的话得激活虚拟环境
我没有用虚拟环境安装哒
 楼主| 发表于 2021-1-14 01:39:49 | 显示全部楼层
2021-01-13 17:38:18 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=1 from 2021-01-13 17:33:22.759201)
2021-01-13 17:38:54 ERROR (SyncWorker_3) [homeassistant.util.package] Unable to install package pillow==7.2.0: ERROR: Command errored out with exit status 1:
     command: /usr/local/bin/python3.8 -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-k0ijz6y7/pillow/setup.py'"'"'; __file__='"'"'/tmp/pip-install-k0ijz6y7/pillow/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-e6yg_83h/install-record.txt --single-version-externally-managed --prefix '' --user --prefix= --compile --install-headers /home/pi/.homeassistant/deps/include/python3.8/pillow
         cwd: /tmp/pip-install-k0ijz6y7/pillow/
    Complete output (172 lines):
    running install
    running build
    running build_py
    creating build
    creating build/lib.linux-armv7l-3.8
    creating build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/MpegImagePlugin.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/PalmImagePlugin.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/JpegImagePlugin.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/ImageDraw2.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/ImageColor.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/PSDraw.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/PcfFontFile.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/GimpPaletteFile.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/ImageCms.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/ImageStat.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/FtexImagePlugin.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/PsdImagePlugin.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/ImageSequence.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/ImageQt.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/ImageWin.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/XVThumbImagePlugin.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/PaletteFile.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/ImageTk.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/SpiderImagePlugin.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/PcdImagePlugin.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/FontFile.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/WebPImagePlugin.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/XbmImagePlugin.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/TgaImagePlugin.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/EpsImagePlugin.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/BmpImagePlugin.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/Image.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/_util.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/_binary.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/ImageEnhance.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/PdfImagePlugin.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/FliImagePlugin.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/GimpGradientFile.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/GdImageFile.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/FitsStubImagePlugin.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/PngImagePlugin.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/GbrImagePlugin.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/SunImagePlugin.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/XpmImagePlugin.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/ImageMode.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/MspImagePlugin.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/ContainerIO.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/PcxImagePlugin.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/PyAccess.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/features.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/ImagePalette.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/WalImageFile.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/ExifTags.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/PdfParser.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/__main__.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/CurImagePlugin.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/SgiImagePlugin.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/ImageFont.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/ImageFilter.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/MicImagePlugin.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/ImageGrab.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/FpxImagePlugin.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/ImageOps.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/GribStubImagePlugin.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/TiffImagePlugin.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/DdsImagePlugin.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/Hdf5StubImagePlugin.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/TarIO.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/BlpImagePlugin.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/ImageTransform.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/McIdasImagePlugin.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/GifImagePlugin.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/PixarImagePlugin.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/_version.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/ImageDraw.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/IptcImagePlugin.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/BdfFontFile.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/TiffTags.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/_tkinter_finder.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/JpegPresets.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/DcxImagePlugin.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/MpoImagePlugin.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/ImageShow.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/__init__.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/ImageMorph.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/ImageMath.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/ImageFile.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/ImImagePlugin.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/ImagePath.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/PpmImagePlugin.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/IcnsImagePlugin.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/Jpeg2KImagePlugin.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/ImtImagePlugin.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/BufrStubImagePlugin.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/ImageChops.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/IcoImagePlugin.py -> build/lib.linux-armv7l-3.8/PIL
    copying src/PIL/WmfImagePlugin.py -> build/lib.linux-armv7l-3.8/PIL
    running egg_info
    writing src/Pillow.egg-info/PKG-INFO
    writing dependency_links to src/Pillow.egg-info/dependency_links.txt
    writing top-level names to src/Pillow.egg-info/top_level.txt
    reading manifest file 'src/Pillow.egg-info/SOURCES.txt'
    reading manifest template 'MANIFEST.in'
    warning: no files found matching '*.c'
    warning: no files found matching '*.h'
    warning: no files found matching '*.sh'
    warning: no previously-included files found matching '.appveyor.yml'
    warning: no previously-included files found matching '.coveragerc'
    warning: no previously-included files found matching '.editorconfig'
    warning: no previously-included files found matching '.readthedocs.yml'
    warning: no previously-included files found matching 'codecov.yml'
    warning: no previously-included files matching '.git*' found anywhere in distribution
    warning: no previously-included files matching '*.pyc' found anywhere in distribution
    warning: no previously-included files matching '*.so' found anywhere in distribution
    no previously-included directories found matching '.ci'
    writing manifest file 'src/Pillow.egg-info/SOURCES.txt'
    running build_ext
    The headers or library files could not be found for jpeg,
    a required dependency when compiling Pillow from source.
    Please see the install instructions at:
       https://pillow.readthedocs.io/en/latest/installation.html
      File "/tmp/pip-install-k0ijz6y7/pillow/setup.py", line 864, in <module>
        setup(
      File "/usr/local/lib/python3.8/site-packages/setuptools/__init__.py", line 165, in setup
        return distutils.core.setup(**attrs)
      File "/usr/local/lib/python3.8/distutils/core.py", line 148, in setup
        dist.run_commands()
      File "/usr/local/lib/python3.8/distutils/dist.py", line 966, in run_commands
        self.run_command(cmd)
      File "/usr/local/lib/python3.8/distutils/dist.py", line 985, in run_command
        cmd_obj.run()
      File "/usr/local/lib/python3.8/site-packages/setuptools/command/install.py", line 61, in run
        return orig.install.run(self)
      File "/usr/local/lib/python3.8/distutils/command/install.py", line 545, in run
        self.run_command('build')
      File "/usr/local/lib/python3.8/distutils/cmd.py", line 313, in run_command
        self.distribution.run_command(command)
        cmd_obj.run()
      File "/usr/local/lib/python3.8/distutils/command/build.py", line 135, in run
        self.run_command(cmd_name)
        cmd_obj.run()
      File "/usr/local/lib/python3.8/distutils/command/build_ext.py", line 340, in run
        self.build_extensions()
      File "/tmp/pip-install-k0ijz6y7/pillow/setup.py", line 694, in build_extensions
        raise RequiredDependencyException(f)
    __main__.RequiredDependencyException: jpeg
      File "<string>", line 1, in <module>
      File "/tmp/pip-install-k0ijz6y7/pillow/setup.py", line 918, in <module>
        raise RequiredDependencyException(msg)
ERROR: Command errored out with exit status 1: /usr/local/bin/python3.8 -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-k0ijz6y7/pillow/setup.py'"'"'; __file__='"'"'/tmp/pip-install-k0ijz6y7/pillow/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-e6yg_83h/install-record.txt --single-version-externally-managed --prefix '' --user --prefix= --compile --install-headers /home/pi/.homeassistant/deps/include/python3.8/pillow Check the logs for full command output.
WARNING: You are using pip version 20.2.4; however, version 20.3.3 is available.
You should consider upgrading via the '/usr/local/bin/python3.8 -m pip install --upgrade pip' command.
2021-01-13 17:38:54 ERROR (MainThread) [homeassistant.setup] Setup failed for image: Requirements for image not found: ['pillow==7.2.0'].
2021-01-13 17:38:54 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of person. Setup failed for dependencies: image
2021-01-13 17:38:54 ERROR (MainThread) [homeassistant.setup] Setup failed for person: Could not set up all dependencies.
2021-01-13 17:38:54 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of onboarding. Setup failed for dependencies: person
2021-01-13 17:38:54 ERROR (MainThread) [homeassistant.setup] Setup failed for onboarding: Could not set up all dependencies.
2021-01-13 17:38:54 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of frontend. Setup failed for dependencies: onboarding
2021-01-13 17:38:54 ERROR (MainThread) [homeassistant.setup] Setup failed for frontend: Could not set up all dependencies.
2021-01-13 17:38:55 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of logbook. Setup failed for dependencies: frontend
2021-01-13 17:38:55 ERROR (MainThread) [homeassistant.setup] Setup failed for logbook: Could not set up all dependencies.
2021-01-13 17:38:56 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of map. Setup failed for dependencies: frontend
2021-01-13 17:38:56 ERROR (MainThread) [homeassistant.setup] Setup failed for map: Could not set up all dependencies.
2021-01-13 17:38:56 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of mobile_app. Setup failed for dependencies: person
2021-01-13 17:38:56 ERROR (MainThread) [homeassistant.setup] Setup failed for mobile_app: Could not set up all dependencies.
2021-01-13 17:38:56 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of default_config. Setup failed for dependencies: frontend, logbook, map, mobile_app, person
2021-01-13 17:38:56 ERROR (MainThread) [homeassistant.setup] Setup failed for default_config: Could not set up all dependencies.
2021-01-13 17:38:56 WARNING (MainThread) [homeassistant.bootstrap] Detected that frontend did not load. Activating safe mode
GMT+8, 2025-12-22 23:15 , Processed in 0.138411 second(s), 10 queries , MemCached On.
