查看: 8460|回复: 2
[已解决] 超级新人求助,homebridge和homeassistant
发表于 2017-9-16 09:15:31 | 显示全部楼层 |阅读模式
已搞定,装了homebridge-homeassistant插件就哦了
根据入门篇一步一步设置的homebridge和homeassistant,配置是VMware虚拟的ubuntu,
中间也没啥问题,但是添加小米网关之后homeassistant里面显示xiaomi配置错误,也不太懂啥意思,哪位大神可以帮助解答一下,万分感谢!!
kuair@ubuntu:~$ homebridge
*** WARNING *** The program 'nodejs' uses the Apple Bonjour compatibility layer of Avahi.
*** WARNING *** Please fix your application to use the native API of Avahi!
*** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=nodejs>
*** WARNING *** The program 'nodejs' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
*** WARNING *** For more information see <http://0pointer.de/avahi-compat? ... ServiceRegister>
[9/15/2017, 6:09:49 PM] Loaded plugin: homebridge-homeassistant
[9/15/2017, 6:09:49 PM] Registering platform 'homebridge-homeassistant.HomeAssistant'
[9/15/2017, 6:09:49 PM] ---
[9/15/2017, 6:09:49 PM] Loaded config.json with 0 accessories and 1 platforms.
[9/15/2017, 6:09:49 PM] Loading 1 platforms...
[9/15/2017, 6:09:49 PM] [HomeAssistant] Initializing HomeAssistant platform...
[9/15/2017, 6:09:49 PM] [HomeAssistant] Please set default_visibility in config.json to "hidden" or "visible".
[9/15/2017, 6:09:49 PM] [HomeAssistant] Fetching HomeAssistant devices.
[9/15/2017, 6:09:49 PM] [HomeAssistant] Received event: ping
Scan this code with your HomeKit App on your iOS device to pair with Homebridge:
    │ 123-45-678 │
[9/15/2017, 6:09:49 PM] Homebridge is running on port 51826.
发表于 2017-9-16 09:59:37 | 显示全部楼层
上配置~~~~~~~~~~~
 楼主| 发表于 2017-9-16 15:15:32 | 显示全部楼层
您好,我市VMware虚拟的ubuntu,小米网关二代
GMT+8, 2025-12-25 05:10 , Processed in 0.587474 second(s), 9 queries , MemCached On.
