楼主: natic
[插件集成] 米家窗帘-HA插件
 楼主| 发表于 2023-9-22 16:56:18 | 显示全部楼层
a_dongde 发表于 2023-9-21 15:58
大佬我的窗帘电机是 平头熊的三平台版本,使用米家平台识别的型号为:090615.curtain.sidt82 ,插件貌似不 ...
更新了配置
model: 090615.curtain.sidt82
发表于 2023-9-23 12:39:00 | 显示全部楼层
natic 发表于 2023-9-22 16:56
更新了配置
配置文件写好后
提示错误:
Platform error cover.mijia_curtain - Exception importing custom_components.mijia_curtain.cover
 楼主| 发表于 2023-9-23 17:01:22 | 显示全部楼层
a_dongde 发表于 2023-9-23 12:39
配置文件写好后
提示错误:
Platform error cover.mijia_curtain - Exception importing custom_components ...
抱歉,注释写错了,在更新一下试试
发表于 2023-9-23 23:05:47 | 显示全部楼层
natic 发表于 2023-9-23 17:01
抱歉,注释写错了,在更新一下试试
安装上了,但是添加好电机后还是提示错误:
Logger: homeassistant.components.cover
Source: custom_components/mijia_curtain/cover.py:253
Integration: 窗帘 (documentation, issues)
First occurred: 23:02:13 (1 occurrences)
Last logged: 23:02:13
Error while setting up mijia_curtain platform for cover
  File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 362, in _async_setup_platform
    await asyncio.shield(task)
  File "/usr/local/lib/python3.11/concurrent/futures/thread.py", line 58, in run
  File "/config/custom_components/mijia_curtain/cover.py", line 187, in setup_platform
    cover = MijiaCurtain(name, host, token, model)
  File "/config/custom_components/mijia_curtain/cover.py", line 288, in __init__
    self._mapping = get_mapping(self._model, self._mapping)
  File "/config/custom_components/mijia_curtain/cover.py", line 253, in get_mapping
    current_position_prop = [prop for prop in curtain_properties if ATTR_CURRENT_POSITION in prop['type']][0]
IndexError: list index out of range
发表于 2023-9-23 23:17:03 | 显示全部楼层
我有三台:090615.curtain.sidt82  这个型号的的电机一个没成,  倒是涂鸦接入米家的:babai.curtain.190812  这个型号的窗帘电机接入成功了
 楼主| 发表于 2023-9-27 21:21:38 | 显示全部楼层
a_dongde 发表于 2023-9-23 23:17
我有三台:090615.curtain.sidt82  这个型号的的电机一个没成,  倒是涂鸦接入米家的:babai.curtain.19081 ...
我用其他机器测试没报错,要不加我微信naticwx, 调试一下
发表于 2023-10-8 16:52:59 | 显示全部楼层
感谢楼主
发表于 2024-1-12 13:19:00 | 显示全部楼层
感谢楼主,窗帘成功识别,但是,只要重启HA,实体就变了,要重新添加实体到仪表盘上,重启几次之后,未使用实体里一堆失效的。
 楼主| 发表于 2024-2-16 21:07:04 | 显示全部楼层
599216045 发表于 2024-1-12 13:19
感谢楼主,窗帘成功识别,但是,只要重启HA,实体就变了,要重新添加实体到仪表盘上,重启几次之后,未使用 ...
更新一下最新版插件,修复了这个问题,不过需要删除旧的实体
发表于 2024-2-21 15:32:09 | 显示全部楼层
请问一下大佬 这个接入梦幻帘 只有旋转没有开合 可以设置吗
GMT+8, 2026-1-14 04:25 , Processed in 0.244137 second(s), 9 queries , MemCached On.
