查看: 2797|回复: 2
[求助] linux deploy启动HB时报http组件安装失败
发表于 2021-1-8 23:13:05 | 显示全部楼层 |阅读模式
手机用的armhf架构debian的系统,已经照安装步骤装好了HB,是在homeassistant用户下用sudo pip3 install -U homeassistant 安装的(跟教程的区别就是用了sudo,不用sudo装不上去。。),安装过程没有报错,可在最后hass启动时候报错,如下:看着样子是安装http组件失败,找遍了全网也没看见有这个报错的,求大神帮助
(homeassistant) homeassistant@localhost:/home/android$ hass
2021-01-08 23:08:24 ERROR (MainThread) [homeassistant.setup] Error during setup of component http
  File "/usr/local/lib/python3.7/dist-packages/homeassistant/setup.py", line 213, in _async_setup_component
    result = await task
  File "/usr/local/lib/python3.7/dist-packages/homeassistant/components/http/__init__.py", line 258, in async_setup
    local_ip = await hass.async_add_executor_job(hass_util.get_local_ip)
  File "/usr/lib/python3.7/concurrent/futures/thread.py", line 57, in run
  File "/usr/local/lib/python3.7/dist-packages/homeassistant/util/__init__.py", line 108, in get_local_ip
    sock.close()
UnboundLocalError: local variable 'sock' referenced before assignment
2021-01-08 23:08:24 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of system_log. Setup failed for dependencies: http
2021-01-08 23:08:24 ERROR (MainThread) [homeassistant.setup] Setup failed for system_log: Could not set up all dependencies.
2021-01-08 23:08:24 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=10 from 2021-01-08 14:50:21.737447)
2021-01-08 23:08:24 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of websocket_api. Setup failed for dependencies: http
2021-01-08 23:08:24 ERROR (MainThread) [homeassistant.setup] Setup failed for websocket_api: Could not set up all dependencies.
2021-01-08 23:08:24 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of alexa. Setup failed for dependencies: http
2021-01-08 23:08:24 ERROR (MainThread) [homeassistant.setup] Setup failed for alexa: Could not set up all dependencies.
2021-01-08 23:08:24 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of config. Setup failed for dependencies: http
2021-01-08 23:08:24 ERROR (MainThread) [homeassistant.setup] Setup failed for config: Could not set up all dependencies.
2021-01-08 23:08:24 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of webhook. Setup failed for dependencies: http
2021-01-08 23:08:24 ERROR (MainThread) [homeassistant.setup] Setup failed for webhook: Could not set up all dependencies.
2021-01-08 23:08:24 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of auth. Setup failed for dependencies: http
2021-01-08 23:08:24 ERROR (MainThread) [homeassistant.setup] Setup failed for auth: Could not set up all dependencies.
2021-01-08 23:08:24 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of api. Setup failed for dependencies: http
2021-01-08 23:08:24 ERROR (MainThread) [homeassistant.setup] Setup failed for api: Could not set up all dependencies.
2021-01-08 23:08:24 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of image. Setup failed for dependencies: http
2021-01-08 23:08:24 ERROR (MainThread) [homeassistant.setup] Setup failed for image: Could not set up all dependencies.
2021-01-08 23:08:25 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of search. Setup failed for dependencies: websocket_api
2021-01-08 23:08:25 ERROR (MainThread) [homeassistant.setup] Setup failed for search: Could not set up all dependencies.
2021-01-08 23:08:25 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of cloud. Setup failed for dependencies: http, webhook, alexa
2021-01-08 23:08:25 ERROR (MainThread) [homeassistant.setup] Setup failed for cloud: Could not set up all dependencies.
2021-01-08 23:08:25 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of person. Setup failed for dependencies: image
2021-01-08 23:08:25 ERROR (MainThread) [homeassistant.setup] Setup failed for person: Could not set up all dependencies.
2021-01-08 23:08:25 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of onboarding. Setup failed for dependencies: auth, http, person
2021-01-08 23:08:25 ERROR (MainThread) [homeassistant.setup] Setup failed for onboarding: Could not set up all dependencies.
2021-01-08 23:08:25 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of frontend. Setup failed for dependencies: api, auth, config, http, onboarding, search, system_log, websocket_api
2021-01-08 23:08:25 ERROR (MainThread) [homeassistant.setup] Setup failed for frontend: Could not set up all dependencies.
2021-01-08 23:08:25 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of logbook. Setup failed for dependencies: frontend, http
2021-01-08 23:08:25 ERROR (MainThread) [homeassistant.setup] Setup failed for logbook: Could not set up all dependencies.
2021-01-08 23:08:25 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of zeroconf. Setup failed for dependencies: api
2021-01-08 23:08:25 ERROR (MainThread) [homeassistant.setup] Setup failed for zeroconf: Could not set up all dependencies.
2021-01-08 23:08:25 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of history. Setup failed for dependencies: http
2021-01-08 23:08:25 ERROR (MainThread) [homeassistant.setup] Setup failed for history: Could not set up all dependencies.
2021-01-08 23:08:25 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of tts. Setup failed for dependencies: http
2021-01-08 23:08:25 ERROR (MainThread) [homeassistant.setup] Setup failed for tts: Could not set up all dependencies.
2021-01-08 23:08:25 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of map. Setup failed for dependencies: frontend
2021-01-08 23:08:25 ERROR (MainThread) [homeassistant.setup] Setup failed for map: Could not set up all dependencies.
2021-01-08 23:08:25 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of media_source. Setup failed for dependencies: http
2021-01-08 23:08:25 ERROR (MainThread) [homeassistant.setup] Setup failed for media_source: Could not set up all dependencies.
2021-01-08 23:08:25 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of system_health. Setup failed for dependencies: http
2021-01-08 23:08:25 ERROR (MainThread) [homeassistant.setup] Setup failed for system_health: Could not set up all dependencies.
2021-01-08 23:08:25 ERROR (MainThread) [homeassistant.components.updater] Error requesting Home Assistant update data: Cannot connect to host updater.home-assistant.io:443 ssl:default [Temporary failure in name resolution]
2021-01-08 23:08:25 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of mobile_app. Setup failed for dependencies: http, webhook, person
2021-01-08 23:08:25 ERROR (MainThread) [homeassistant.setup] Setup failed for mobile_app: Could not set up all dependencies.
2021-01-08 23:08:35 ERROR (SyncWorker_27) [homeassistant.util.package] Unable to install package zeroconf==0.28.8: WARNING: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0xb68bd630>: Failed to establish a new connection: [Errno -2] Name or service not known')': /simple/zeroconf/
WARNING: Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0xb54055d0>: Failed to establish a new connection: [Errno -2] Name or service not known')': /simple/zeroconf/
WARNING: Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0xb5405f90>: Failed to establish a new connection: [Errno -2] Name or service not known')': /simple/zeroconf/
WARNING: Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0xb54059d0>: Failed to establish a new connection: [Errno -2] Name or service not known')': /simple/zeroconf/
WARNING: Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0xb542ea90>: Failed to establish a new connection: [Errno -2] Name or service not known')': /simple/zeroconf/
ERROR: Could not find a version that satisfies the requirement zeroconf==0.28.8 (from -c /usr/local/lib/python3.7/dist-packages/homeassistant/package_constraints.txt (line 33)) (from versions: none)
ERROR: No matching distribution found for zeroconf==0.28.8 (from -c /usr/local/lib/python3.7/dist-packages/homeassistant/package_constraints.txt (line 33))
2021-01-08 23:08:35 ERROR (MainThread) [homeassistant.setup] Setup failed for ssdp: Requirements for zeroconf not found: ['zeroconf==0.28.8'].
2021-01-08 23:08:35 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of default_config. Setup failed for dependencies: cloud, frontend, history, logbook, map, media_source, mobile_app, person, ssdp, system_health, webhook, zeroconf
2021-01-08 23:08:35 ERROR (MainThread) [homeassistant.setup] Setup failed for default_config: Could not set up all dependencies.
2021-01-08 23:08:35 WARNING (MainThread) [homeassistant.bootstrap] Support for the running Python version 3.7.3 is deprecated and will be removed in the first release after December 7, 2020. Please upgrade Python to 3.8.0 or higher.
2021-01-08 23:08:35 WARNING (MainThread) [homeassistant.bootstrap] Detected that frontend did not load. Activating safe mode
2021-01-08 23:08:35 ERROR (MainThread) [homeassistant.setup] Error during setup of component http
    result = await task
    sock.close()
2021-01-08 23:08:35 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of system_log. Setup failed for dependencies: http
2021-01-08 23:08:35 ERROR (MainThread) [homeassistant.setup] Setup failed for system_log: Could not set up all dependencies.
2021-01-08 23:08:35 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of websocket_api. Setup failed for dependencies: http
2021-01-08 23:08:35 ERROR (MainThread) [homeassistant.setup] Setup failed for websocket_api: Could not set up all dependencies.
2021-01-08 23:08:35 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of alexa. Setup failed for dependencies: http
2021-01-08 23:08:35 ERROR (MainThread) [homeassistant.setup] Setup failed for alexa: Could not set up all dependencies.
2021-01-08 23:08:35 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of config. Setup failed for dependencies: http
2021-01-08 23:08:35 ERROR (MainThread) [homeassistant.setup] Setup failed for config: Could not set up all dependencies.
2021-01-08 23:08:35 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of webhook. Setup failed for dependencies: http
2021-01-08 23:08:35 ERROR (MainThread) [homeassistant.setup] Setup failed for webhook: Could not set up all dependencies.
2021-01-08 23:08:35 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of auth. Setup failed for dependencies: http
2021-01-08 23:08:35 ERROR (MainThread) [homeassistant.setup] Setup failed for auth: Could not set up all dependencies.
2021-01-08 23:08:35 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of api. Setup failed for dependencies: http
2021-01-08 23:08:35 ERROR (MainThread) [homeassistant.setup] Setup failed for api: Could not set up all dependencies.
2021-01-08 23:08:35 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of image. Setup failed for dependencies: http
2021-01-08 23:08:35 ERROR (MainThread) [homeassistant.setup] Setup failed for image: Could not set up all dependencies.
2021-01-08 23:08:35 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of search. Setup failed for dependencies: websocket_api
2021-01-08 23:08:35 ERROR (MainThread) [homeassistant.setup] Setup failed for search: Could not set up all dependencies.
2021-01-08 23:08:35 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of cloud. Setup failed for dependencies: http, webhook, alexa
2021-01-08 23:08:35 ERROR (MainThread) [homeassistant.setup] Setup failed for cloud: Could not set up all dependencies.
2021-01-08 23:08:35 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of person. Setup failed for dependencies: image
2021-01-08 23:08:35 ERROR (MainThread) [homeassistant.setup] Setup failed for person: Could not set up all dependencies.
2021-01-08 23:08:35 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of onboarding. Setup failed for dependencies: auth, http, person
2021-01-08 23:08:35 ERROR (MainThread) [homeassistant.setup] Setup failed for onboarding: Could not set up all dependencies.
2021-01-08 23:08:35 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of frontend. Setup failed for dependencies: api, auth, config, http, onboarding, search, system_log, websocket_api
2021-01-08 23:08:35 ERROR (MainThread) [homeassistant.setup] Setup failed for frontend: Could not set up all dependencies.
2021-01-08 23:08:35 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of safe_mode. Setup failed for dependencies: frontend, cloud
2021-01-08 23:08:35 ERROR (MainThread) [homeassistant.setup] Setup failed for safe_mode: Could not set up all dependencies.
发表于 2021-5-26 23:03:01 | 显示全部楼层
请问解决问题了吗? 我也是这样
 楼主| 发表于 2021-5-28 22:52:45 | 显示全部楼层
etmomoabc 发表于 2021-5-26 23:03
请问解决问题了吗? 我也是这样
没 后来换了个环境和教程
https://bbs.hassbian.com/thread-11957-1-1.html
GMT+8, 2025-12-16 20:05 , Processed in 0.992957 second(s), 11 queries , MemCached On.
