查看: 11315|回复: 9
[流程系列] 子流程的输入参数怎么传进去?
发表于 2020-12-31 09:59:28 | 显示全部楼层 |阅读模式
这是个Node-RED的问题,不知是发在本讨论区还是应该发在疑问讨论区,如果发错地方了,请版主移到其他版块。谢谢!
简化问题模型:我建了一个子流程,设置了三个入口参数a、b、c,这里似乎只能是环境变量。
[{"id":"6b4c9ba4.deb134","type":"subflow","name":"abc","info":"","category":"","in":[{"x":80,"y":80,"wires":[{"id":"9eff8f77.86c6c"}]}],"out":[{"x":300,"y":80,"wires":[{"id":"9eff8f77.86c6c","port":0}]}],"env":[{"name":"a","type":"str","value":""},{"name":"b","type":"str","value":""},{"name":"c","type":"str","value":""}],"color":"#DDAA99"},{"id":"9eff8f77.86c6c","type":"function","z":"6b4c9ba4.deb134","name":"","func":"// use a, b, c\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":200,"y":80,"wires":[[]]}]
使用这子流程,在前面添加一个比如function节点,想要设置好abc的参数,该怎么写?
[{"id":"6b4c9ba4.deb134","type":"subflow","name":"abc","info":"","category":"","in":[{"x":80,"y":80,"wires":[{"id":"9eff8f77.86c6c"}]}],"out":[{"x":300,"y":80,"wires":[{"id":"9eff8f77.86c6c","port":0}]}],"env":[{"name":"a","type":"str","value":""},{"name":"b","type":"str","value":""},{"name":"c","type":"str","value":""}],"color":"#DDAA99"},{"id":"9eff8f77.86c6c","type":"function","z":"6b4c9ba4.deb134","name":"","func":"// use a, b, c\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":200,"y":80,"wires":[[]]},{"id":"1c05f6a2.f4ef79","type":"tab","label":"use","disabled":false,"info":""},{"id":"b6e78133.51754","type":"subflow:6b4c9ba4.deb134","z":"1c05f6a2.f4ef79","name":"abc","env":[],"x":470,"y":60,"wires":[[]]},{"id":"63c4d8fc.e559f8","type":"function","z":"1c05f6a2.f4ef79","name":"如何设置后面节点所需的abc参数","func":"//这里如何设置后面节点所需的abc参数?\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":220,"y":60,"wires":[["b6e78133.51754"]]}]
我试了下环境变量、flow变量等都不行。请大神们指点下,这里如何将变量传给a、b、c。
发表于 2020-12-31 10:12:00 | 显示全部楼层
顶一下,我也想知道这个问题
发表于 2020-12-31 10:27:31 | 显示全部楼层
 楼主| 发表于 2020-12-31 10:47:49 | 显示全部楼层
感谢大神指导,不过这个似乎只能在子流程中获得数据,在子流程之前好像获得不了它的值。
function节点设置ab的值
直接设置subflow节点中c的值
这是subflow子流程中获得abc的值合并到msg中
打印出来,a和b的值没有设置上,不知道是不是哪里弄错了
发表于 2020-12-31 11:41:34 | 显示全部楼层
function节点设置 ...
之前肯定不行。
发表于 2020-12-31 12:03:04 来自手机 | 显示全部楼层
通过msg传递,需要啥就设置啥属性
 楼主| 发表于 2020-12-31 16:36:21 | 显示全部楼层
pikaq 发表于 2020-12-31 12:03
通过msg传递,需要啥就设置啥属性
前面节点设置msg.xxx,subflow变量名设置为msg.xxx,两个不是一样的东西,传不进去。
你说的msg具体怎么操作?
seon
发表于 2021-1-7 23:41:22 | 显示全部楼层
子流程只能设置静态的值,无法设置动态的值,如果需要有动态的值,可以通过msg传递,或者存到flow里,在子流程里面通过$flowContext('$parent.logModule')这样的方式获取
seon
发表于 2021-1-7 23:43:39 | 显示全部楼层
你说的msg具体怎么 ...
在子流程外面,设置msg.xx,在子流程里面直接读取msg.xx就行了
 楼主| 发表于 2021-1-7 23:50:14 | 显示全部楼层
我需要的是动态的,能在子流程的节点上设置的值,如上图的a、b、c等的值,不是流程外面传来的值
GMT+8, 2025-12-16 19:46 , Processed in 0.682227 second(s), 11 queries , MemCached On.
