查看: 58643|回复: 13
[经验分享] D80NK类进出计数器的ha自动化计数或Esphome本地自动化计数代码
3万
发表于 2020-12-30 15:46:30 | 显示全部楼层 |阅读模式
最近研究了一下Esphome,买了2个D80NK,加一个ESP8266。参考以下帖子:
https://bbs.hassbian.com/thread-11065-1-1.html
https://bbs.hassbian.com/thread-11313-1-1.html
动手连接时才发现,帖子中的是ESP32S,针脚不一样。D80NK说明书中明确要求5V电源,还好用万用表找到了esp8266上的5V针脚。
稳定工作时电压5V,电流0.07A。
最初使用  https://bbs.hassbian.com/thread-11749-1-1.html 中的esphome代码:
esphome:
  platform: ESP32
  board: nodemcu-32s
wifi:
  ssid: "你的WiFi名"
  password: "你的WiFi密码"
  ap:
    ssid: "Esphome 32 Fallback Hotspot"
    password: "zrSLkHpn8Ufd"
captive_portal:
# Enable Home Assistant API
api:
  password: "自定义一个密码"
ota:
  password: "自定义一个密码"
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO22
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio
    pin:
      number: GPIO18
      mode: INPUT_PULLUP
      inverted: True
人数增减原理:
触发:2号传感器变off,条件:时间1< 2 <3
反向同理。其它情况忽略,不做增减。
一开始用ha中的UI自动化来实现,增加以下辅助元素:
自动化代码:
- id: '1609167392619'
  alias: zone_ppl_start
  description: ''
  trigger:
  - type: turned_on
    platform: device
    device_id: 50bbba6ebbc243238ddea4fea793594c
    entity_id: binary_sensor.throughs_sensor_1
    domain: binary_sensor
  - type: turned_on
    platform: device
    entity_id: binary_sensor.throughs_sensor_2
  condition: []
  action:
  - choose:
    - conditions:
      - condition: template
        value_template: '{{ trigger.entity_id == "binary_sensor.throughs_sensor_2"
      - condition: state
        state: 'on'
      sequence:
      - service: input_number.increment
        data: {}
        entity_id: input_number.zone_ppl_num
    - conditions:
        value_template: '{{ trigger.entity_id == "binary_sensor.throughs_sensor_1"
      - condition: state
        state: 'on'
      sequence:
      - service: input_number.decrement
        data: {}
    default: []
  mode: single
- id: '1609170604556'
  alias: zone_ppl_end
  description: ''
  trigger:
  - type: turned_off
    platform: device
  - type: turned_off
    platform: device
  condition: []
  action:
  - choose:
    - conditions:
      - condition: state
        state: 'off'
      sequence:
        data: {}
    - conditions:
      - condition: state
        state: 'off'
      sequence:
        data: {}
    default: []
  mode: single
- id: '1609173635413'
  alias: zone_ppl_time1
  description: ''
  trigger:
  - type: turned_on
    platform: device
  condition: []
  action:
  - service: input_datetime.set_datetime
    data:
      entity_id: input_datetime.zone_ppl_time1
      timestamp: '{{ now().timestamp() }}'
  mode: single
- id: '1609174891352'
  alias: zone_ppl_time2
  description: ''
  trigger:
  - type: turned_off
    platform: device
  condition: []
  action:
    data:
      entity_id: input_datetime.zone_ppl_time2
  mode: single
- id: '1609174980524'
  alias: zone_ppl_time3
  description: ''
  trigger:
  - type: turned_on
    platform: device
  condition: []
  action:
    data:
      entity_id: input_datetime.zone_ppl_time3
  mode: single
- id: '1609175003405'
  alias: zone_ppl_time4
  description: ''
  trigger:
  - type: turned_off
    platform: device
  condition: []
  action:
    data:
      entity_id: input_datetime.zone_ppl_time4
  mode: single
- id: '1609175810473'
  alias: zone_ppl_increment
  description: ''
  trigger:
  - type: turned_off
    platform: device
  condition:
    value_template: '{{ state_attr(''input_datetime.zone_ppl_time3'', ''timestamp'')|float()
      < state_attr(''input_datetime.zone_ppl_time2'', ''timestamp'')|float() }}'
    value_template: '{{ state_attr(''input_datetime.zone_ppl_time1'', ''timestamp'')|float()
      < state_attr(''input_datetime.zone_ppl_time3'', ''timestamp'')|float() }}'
  action:
    data: {}
  mode: single
- id: '1609176481429'
  alias: zone_ppl_decrement
  description: ''
  trigger:
  - type: turned_off
    platform: device
  condition:
      < state_attr(''input_datetime.zone_ppl_time1'', ''timestamp'')|float() }}'
      < state_attr(''input_datetime.zone_ppl_time4'', ''timestamp'')|float() }}'
  action:
    data: {}
  mode: single
计数能用,但不稳定,受网络状态等多种外界因素影响比较大,hass收到传感器的信息时间可能会滞后,严重时就乱了。后面打算在esphome中实现代码:参考:https://esphome.io/components/binary_sensor/
https://esphome.io/components/sensor/
https://esphome.io/components/se ... platform%20template
https://esphome.io/guides/automations.html?highlight=template
https://github.com/esphome/issues/issues/1099
发现这个esp8266的时间.timestamp每128秒才更新一次,难怪所有地时间显示都一样。导致这个按时间顺序的逻辑在esphome中无法实现。
只能试试传感器的on/off组合状态为条件来区分阶段,阶段完成后进行增减。
esphome本地自动化完成计数增减,效果相对比较好!
esphome:
  platform: ESP32
  board: nodemcu-32s
wifi:
  ssid: "你的WiFi名"
  ap:
captive_portal:
api:
  password: "自定义一个密码"
ota:
  password: "自定义一个密码"
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO22
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio
    pin:
      number: GPIO18
      mode: INPUT_PULLUP
      inverted: True
time:
  - platform: sntp
    timezone: Asia/Shanghai
  - platform: homeassistant
globals:
   - id: counter_int
     type: int
     restore_value: no
     initial_value: '0'
   - id: counter_increment
     type: int
     restore_value: no
     initial_value: '0'
   - id: counter_decrement
     type: int
     restore_value: no
     initial_value: '0'
binary_sensor:
  - platform: gpio
    pin:
      number: D1
      mode: INPUT_PULLUP
      inverted: True
    device_class: motion
    on_press:
      then:
        - lambda: |-
            if ((id(throughs_sensor_2).state) and id(counter_decrement) == 1) {
              id(counter_decrement) = 2;
            if (id(throughs_sensor_2).state == false) {
              id(counter_increment) = 1;
    on_release:
      then:
        - lambda: |-
            if ((id(throughs_sensor_2).state) and id(counter_increment) == 2) {
              id(counter_increment) = 3;
            if ((id(throughs_sensor_2).state == false) and id(counter_decrement) == 3) {
              id(counter_decrement) = 0;
              id(counter_int) -= 1;
  - platform: gpio
    pin:
      number: D2
      mode: INPUT_PULLUP
      inverted: True
    on_press:
      then:
        - lambda: |-
            if ((id(throughs_sensor_1).state) and id(counter_increment) == 1) {
              id(counter_increment) = 2;
            if (id(throughs_sensor_1).state == false)  {
              id(counter_decrement) = 1;
    on_release:
      then:
        - lambda: |-
            if ((id(throughs_sensor_1).state) and id(counter_decrement) == 2) {
              id(counter_decrement) = 3;
            if ((id(throughs_sensor_2).state == false) and id(counter_increment) == 3) {
              id(counter_increment) = 0;
              id(counter_int) += 1;
text_sensor:
  - platform: wifi_info
    ip_address:
      icon: "mdi:ip"
    ssid:
      icon: "mdi:access-point-network"
    bssid:
  - platform: wifi_signal
    name: "WiFi Espcounter"
    update_interval: 60s
## 8266运行时间
  - platform: uptime
  - platform: template
    lambda: !lambda |-
        return id(counter_int);
    update_interval: 5s
第一时间发上来了,实际使用还需要更多测试。
代码再次优化补充,弃用定时上报消息,改为按需上报消息,增加一个重置计数的开关,以便校正数据(20201230)。
效果:
日志:
[21:27:15][C][wifi_info:010]: WifiInfo SSID 'Espcounter SSID'
[21:27:15][C][wifi_info:010]:   Icon: 'mdi:access-point-network'
[21:27:15][C][wifi_info:011]: WifiInfo BSSID 'Espcounter BSSID'
[21:27:15][C][wifi_info:011]:   Icon: 'mdi:access-point-network'
[21:27:44][D][sensor:092]: 'Counter Number': Sending state 0.00000  with 1 decimals of accuracy
[21:27:48][D][sensor:092]: 'Uptime Sensor': Sending state 300.53400 s with 0 decimals of accuracy
[21:27:50][D][sensor:092]: 'WiFi Espcounter': Sending state -43.00000 dB with 0 decimals of accuracy
[21:28:10][D][api.connection:604]: Client 'Home Assistant 2020.12.1 (192.168.12.1)' connected successfully!
[21:28:10][D][time:040]: Synchronized time: Wed Dec 30 21:28:10 2020
[21:28:44][D][sensor:092]: 'Counter Number': Sending state 0.00000  with 1 decimals of accuracy
[21:28:48][D][sensor:092]: 'Uptime Sensor': Sending state 360.53601 s with 0 decimals of accuracy
[21:28:50][D][sensor:092]: 'WiFi Espcounter': Sending state -44.00000 dB with 0 decimals of accuracy
[21:29:05][D][binary_sensor:036]: 'throughs_sensor_1': Sending state ON
[21:29:05][D][binary_sensor:036]: 'throughs_sensor_1': Sending state OFF
[21:29:11][D][binary_sensor:036]: 'throughs_sensor_1': Sending state ON
[21:29:12][D][binary_sensor:036]: 'throughs_sensor_2': Sending state ON
[21:29:12][D][binary_sensor:036]: 'throughs_sensor_1': Sending state OFF
[21:29:12][D][binary_sensor:036]: 'throughs_sensor_2': Sending state OFF
[21:29:12][D][sensor:092]: 'Counter Number': Sending state 1.00000  with 1 decimals of accuracy
[21:29:12][D][binary_sensor:036]: 'Motion Sensor': Sending state ON
[21:29:28][D][binary_sensor:036]: 'throughs_sensor_1': Sending state ON
[21:29:28][D][binary_sensor:036]: 'throughs_sensor_2': Sending state ON
[21:29:28][D][binary_sensor:036]: 'throughs_sensor_1': Sending state OFF
[21:29:28][D][binary_sensor:036]: 'throughs_sensor_2': Sending state OFF
[21:29:28][D][sensor:092]: 'Counter Number': Sending state 2.00000  with 1 decimals of accuracy
[21:29:44][D][sensor:092]: 'Counter Number': Sending state 2.00000  with 1 decimals of accuracy
[21:29:45][D][binary_sensor:036]: 'throughs_sensor_2': Sending state ON
[21:29:45][D][binary_sensor:036]: 'throughs_sensor_1': Sending state ON
[21:29:46][D][binary_sensor:036]: 'throughs_sensor_2': Sending state OFF
[21:29:46][D][binary_sensor:036]: 'throughs_sensor_1': Sending state OFF
[21:29:46][D][sensor:092]: 'Counter Number': Sending state 1.00000  with 1 decimals of accuracy
[21:29:48][D][sensor:092]: 'Uptime Sensor': Sending state 420.53101 s with 0 decimals of accuracy
[21:29:49][D][binary_sensor:036]: 'throughs_sensor_2': Sending state ON
[21:29:49][D][binary_sensor:036]: 'throughs_sensor_1': Sending state ON
[21:29:49][D][binary_sensor:036]: 'throughs_sensor_2': Sending state OFF
[21:29:49][D][binary_sensor:036]: 'throughs_sensor_1': Sending state OFF
[21:29:49][D][sensor:092]: 'Counter Number': Sending state 0.00000  with 1 decimals of accuracy
[21:29:49][D][binary_sensor:036]: 'Motion Sensor': Sending state OFF
[21:29:50][D][sensor:092]: 'WiFi Espcounter': Sending state -49.00000 dB with 0 decimals of accuracy
[21:30:02][D][binary_sensor:036]: 'throughs_sensor_1': Sending state ON
[21:30:02][D][binary_sensor:036]: 'throughs_sensor_2': Sending state ON
[21:30:02][D][binary_sensor:036]: 'throughs_sensor_1': Sending state OFF
[21:30:02][D][binary_sensor:036]: 'throughs_sensor_2': Sending state OFF
[21:30:02][D][sensor:092]: 'Counter Number': Sending state 1.00000  with 1 decimals of accuracy
[21:30:02][D][binary_sensor:036]: 'Motion Sensor': Sending state ON
esphome代码:
esphome:
  platform: ESP8266
  board: nodemcuv2
wifi:
  ssid: "家里的wifi信号名"
  password: "wifi的密码"
  ap:
    ssid: "Espcounter Fallback Hotspot"
    password: "热点密码"
captive_portal:
# Enable logging
logger:
api:
  password: "设置一个密码"
ota:
  password: "设置一个密码"
time:
  - platform: sntp
globals:
   - id: counter_int
     type: int
     restore_value: no
     initial_value: '0'
     type: int
     restore_value: no
     initial_value: '0'
     type: int
     restore_value: no
     initial_value: '0'
binary_sensor:
  - platform: gpio
    pin:
      number: D1
      mode: INPUT_PULLUP
      inverted: True
    on_press:
      then:
        - lambda: |-
    on_release:
      then:
        - lambda: |-
              id(counternum).publish_state(id(counter_int));
            if (id(counter_int) == 0) {
              id(motion_sens).publish_state(false);
            if (id(counter_int) < 0) {
              id(counter_int) = 0;
  - platform: gpio
    pin:
      number: D2
      mode: INPUT_PULLUP
      inverted: True
    on_press:
      then:
        - lambda: |-
    on_release:
      then:
        - lambda: |-
            if (id(counter_int) == 1) {
              id(motion_sens).publish_state(true);
text_sensor:
    ip_address:
      icon: "mdi:ip"
    ssid:
    bssid:
## 8266运行时间
  - platform: uptime
    lambda: !lambda |-
switch:
    name: "Reset Counter to 0"
    lambda: |-
        return false;
    turn_on_action:
      - lambda: |-
参与人数 4金钱 +59 HASS币 +20 收起 理由
eric + 16 感谢楼主分享!
jyz_0501 + 20 墙都不扶,就服楼主!
+ 20 + 20 虽然看不懂,但感觉很厉害的样子。.
diba.qiu + 3
3万
 楼主| 发表于 2020-12-30 17:07:19 | 显示全部楼层
视频不知道怎么加上来呢,分别上传到了优酷和腾讯。
https://player.youku.com/embed/XNTAzNDUzMjI3Mg==
发表于 2020-12-30 18:16:11 | 显示全部楼层
佩服 能把 jinja2 玩到这个地步
发表于 2020-12-31 17:56:17 来自手机 | 显示全部楼层
两次的代码怎么都是eps32s的?说好的8266呢
发表于 2020-12-31 17:58:58 来自手机 | 显示全部楼层
问下,d80nk如果检测到有人移动输出的电压是持续吗?
发表于 2021-1-1 13:17:29 | 显示全部楼层
d80nk距离还是不行啊,我已经换成vl53L1X在弄了
3万
 楼主| 发表于 2021-1-1 16:11:48 | 显示全部楼层
前面部分为了方便复制了参考帖的,忘记修改了,实际上是8266的。第一段修改如下:
esphome:
  platform: ESP8266
  board: nodemcuv2
3万
 楼主| 发表于 2021-1-1 16:19:34 | 显示全部楼层
d80nk检测到近距离有障碍物是持续输出,障碍物一离开就没信号了。所以用两个传感器的开关的先后顺序来对进出的物体进行计数。
这个检测距离最好是与门框的宽度差不多,太短有时检测不到。太长了不好安装,如果对侧有墙容易形成持续障碍。也不能正常工作。
代码中增加了一个 Motion Sensor ,当进入人数大于1时显示 "触发",人数等于0时显示“未触发”。
发表于 2021-1-1 19:05:05 | 显示全部楼层
dscao 发表于 2021-1-1 16:19
d80nk检测到近距离有障碍物是持续输出,障碍物一离开就没信号了。所以用两个传感器的开关的先后顺序来对进 ...
我打算安装在马桶正上面,当检测到有人坐在马桶上时,设置成每间隔一段时间就自动冲洗马桶,并且设置成禁止关灯(防止有人关灯)0
发表于 2021-1-10 21:40:48 | 显示全部楼层
楼主可以贴一下视频地址看看吗
GMT+8, 2026-1-8 00:04 , Processed in 1.696667 second(s), 10 queries , MemCached On.
