楼主: chychyy
米家智能插座2 蓝牙网关版如何接入HomeKit?
发表于 2021-3-16 18:17:45 | 显示全部楼层
  - platform: xiaomi_miio_raw
    host: 192.168.x.x
    token: xxxxxxxxxx
    max_properties: 10
    default_properties_getter: get_properties
    default_properties:
      - "{'did': 'power', 'piid': 1, 'siid': 2}"
      - "{'did': 'temperature', 'piid': 6, 'siid': 2}"
      - "{'did': 'indicator_light', 'piid': 1, 'siid': 3}"
      - "{'did': 'on_duration', 'piid': 1, 'siid': 4}"
      - "{'did': 'off_duration', 'piid': 2, 'siid': 4}"
      - "{'did': 'countdown', 'piid': 3, 'siid': 4}"
      - "{'did': 'task_switch', 'piid': 4, 'siid': 4}"
      - "{'did': 'countdown_info', 'piid': 5, 'siid': 4}"
      - "{'did': 'power_consumption', 'piid': 1, 'siid': 5}"
      - "{'did': 'electric_current', 'piid': 2, 'siid': 5}"
      - "{'did': 'voltage', 'piid': 3, 'siid': 5}"
      - "{'did': 'electric_power', 'piid': 6, 'siid': 5}"
  - platform: template
    sensors:
      smart_plug_power:
        unique_id: smart_plug_power
        unit_of_measurement: W
        value_template: "{{ state_attr('sensor.smart_plug', 'electric_power')/100 }}"
        availability_template: "{{ not is_state('sensor.smart_plug', 'unavailable') }}"
        icon_template: "mdi:flash"
switch:
    switches:
      smart_plug_switch:
        unique_id: smart_plug_switch
        value_template: "{{ state_attr('sensor.smart_plug', 'power') }}"
        turn_on:
          service: xiaomi_miio_raw.sensor_raw_command
          data:
            entity_id: sensor.smart_plug
            method: set_properties
            params:
              - did: power
                siid: 2
                piid: 1
                value: true
        turn_off:
          data:
            params:
              - did: power
                siid: 2
                piid: 1
                value: false
发表于 2021-3-18 06:13:56 | 显示全部楼层
在 HACS 商店中,直接搜索添加“Xiaomi MIoT”
发表于 2021-12-11 10:06:31 | 显示全部楼层
关注一下,最近买了几个这种插座,还挺好用
GMT+8, 2025-12-2 15:05 , Processed in 1.170143 second(s), 10 queries , MemCached On.
