查看: 25610|回复: 7
[已解决] 米家智能晾衣机(架)有没有办法接入hass?
3万
发表于 2020-12-23 23:25:14 | 显示全部楼层 |阅读模式
搜索了很久都没找到方法,抓包不会,用路由器抓没发现它的IP 54321端口有数据。如果能接入它的灯也好。否则只能通过小米的智能执行,或者硬改一个小米无线按钮来反向控制。
采用本地控制shell command 配合 https://bbs.hassbian.com/thread-12049-1-1.html 这个插件,目前使用效果良好!
或者使用moit插件 https://bbs.hassbian.com/thread-12009-1-1.html ,但 current_position 对于这个设备有问题。
发表于 2020-12-24 11:59:13 | 显示全部楼层
我刚刚买一个邦先生晾衣架是米家的接入了
发表于 2021-1-5 19:40:12 | 显示全部楼层
不需要抓包了已经 miot的定义都能查得到了
假设你的型号是 mrbond.airer.m1pro
在这里搜索 http://miot-spec.org/miot-spec-v2/instances?status=all
找到这段
{"status":"released","model":"mrbond.airer.m1pro","version":1,"type":"urn:miot-spec-v2:device:airer:0000A00D:mrbond-m1pro:1"}就是到type了
https://miot-spec.org/miot-spec-v2/instance?type=[把type贴在这里]
得到:
https://miot-spec.org/miot-spec-v2/instance?type=urn:miot-spec-v2:device:airer:0000A00D:mrbond-m1pro:1
最后就得到了指令定义, 可以自己随便找一个component改造, 建议通过yonsm 的mrbond 衣架改造, 基本上很接近了
https://github.com/Yonsm/HAExtra ... onents/mrbond_airer
3万
 楼主| 发表于 2021-1-6 15:53:36 | 显示全部楼层
在这里搜索 http://miot-spe ...
谢谢!不过我还是搞不定啊。
mrbond.airer.m1pro:
    "type": "urn:miot-spec-v2:device:airer:0000A00D:mrbond-m1pro:1",
    "description": "Airer",
    "services": [
            "iid": 1,
            "type": "urn:miot-spec-v2:service:device-information:00007801:mrbond-m1pro:1",
            "description": "Device Information",
            "properties": [
                    "iid": 1,
                    "type": "urn:miot-spec-v2:property:manufacturer:00000001:mrbond-m1pro:1",
                    "description": "Device Manufacturer",
                    "format": "string",
                    "access": [
                        "read"
                    "iid": 2,
                    "type": "urn:miot-spec-v2:property:model:00000002:mrbond-m1pro:1",
                    "description": "Device Model",
                    "format": "string",
                    "access": [
                        "read"
                    "iid": 3,
                    "type": "urn:miot-spec-v2:property:serial-number:00000003:mrbond-m1pro:1",
                    "description": "Device Serial Number",
                    "format": "string",
                    "access": [
                        "read"
                    "iid": 4,
                    "type": "urn:miot-spec-v2:property:firmware-revision:00000005:mrbond-m1pro:1",
                    "description": "Current Firmware Version",
                    "format": "string",
                    "access": [
                        "read"
            "iid": 2,
            "type": "urn:miot-spec-v2:service:airer:00007817:mrbond-m1pro:1",
            "properties": [
                    "iid": 1,
                    "type": "urn:miot-spec-v2:property:motor-control:00000038:mrbond-m1pro:1",
                    "description": "Motor Control",
                    "format": "uint8",
                    "access": [
                        "write"
                    "value-list": [
                            "value": 0,
                            "description": "Pause"
                            "value": 1,
                            "description": "Up"
                            "value": 2,
                            "description": "Down"
                    "iid": 2,
                    "type": "urn:miot-spec-v2:property:dryer:00000027:mrbond-m1pro:1",
                    "description": "Dryer",
                    "format": "bool",
                    "access": [
                        "read",
                        "write",
                        "notify"
                    "iid": 3,
                    "type": "urn:miot-spec-v2:property:drying-level:0000003B:mrbond-m1pro:1",
                    "description": "Drying Level",
                    "format": "uint8",
                    "access": [
                        "read",
                        "write",
                        "notify"
                    "value-list": [
                            "value": 1,
                            "description": "Level1"
                            "value": 2,
                            "description": "Level2"
                            "value": 3,
                            "description": "Level3"
                            "value": 4,
                            "description": "Level4"
            "iid": 3,
            "type": "urn:miot-spec-v2:service:light:00007802:mrbond-m1pro:1",
            "description": "Light",
            "properties": [
                    "iid": 1,
                    "type": "urn:miot-spec-v2:property:on:00000006:mrbond-m1pro:1",
                    "description": "Switch Status",
                    "format": "bool",
                    "access": [
                        "read",
                        "write",
                        "notify"
小米晾衣架:
    "type": "urn:miot-spec-v2:device:airer:0000A00D:hyd-znlyj1:1",
    "services": [
            "iid": 1,
            "type": "urn:miot-spec-v2:service:device-information:00007801:hyd-znlyj1:1",
            "properties": [
                    "iid": 1,
                    "type": "urn:miot-spec-v2:property:manufacturer:00000001:hyd-znlyj1:1",
                    "format": "string",
                    "access": [
                        "read"
                    "iid": 2,
                    "type": "urn:miot-spec-v2:property:model:00000002:hyd-znlyj1:1",
                    "format": "string",
                    "access": [
                        "read"
                    "iid": 3,
                    "type": "urn:miot-spec-v2:property:serial-number:00000003:hyd-znlyj1:1",
                    "format": "string",
                    "access": [
                        "read"
                    "iid": 4,
                    "type": "urn:miot-spec-v2:property:firmware-revision:00000005:hyd-znlyj1:1",
                    "format": "string",
                    "access": [
                        "read"
            "iid": 2,
            "type": "urn:miot-spec-v2:service:airer:00007817:hyd-znlyj1:1",
            "properties": [
                    "iid": 1,
                    "type": "urn:miot-spec-v2:property:fault:00000009:hyd-znlyj1:1",
                    "description": "Device Fault",
                    "format": "uint8",
                    "access": [
                        "read",
                        "notify"
                    "unit": "none",
                    "value-list": [
                            "value": 0,
                            "description": "No Faults"
                            "value": 1,
                            "description": "Obstruction"
                            "value": 2,
                            "description": "Overweight"
                            "value": 3,
                            "description": "Overheated"
                    "iid": 2,
                    "type": "urn:miot-spec-v2:property:motor-control:00000038:hyd-znlyj1:1",
                    "format": "uint8",
                    "access": [
                        "write"
                    "unit": "none",
                    "value-list": [
                            "value": 0,
                            "value": 1,
                            "description": "Up"
                            "value": 2,
                    "iid": 3,
                    "type": "urn:miot-spec-v2:property:current-position:00000039:hyd-znlyj1:1",
                    "description": "Current Position",
                    "format": "uint8",
                    "access": [
                        "read",
                        "notify"
                    "unit": "none",
                    "value-range": [
                        0,
                        2,
                    "iid": 4,
                    "type": "urn:miot-spec-v2:property:status:00000007:hyd-znlyj1:1",
                    "description": "Status",
                    "format": "uint8",
                    "access": [
                        "read",
                        "notify"
                    "unit": "none",
                    "value-list": [
                            "value": 0,
                            "description": "Stopped"
                            "value": 1,
                            "description": "Up"
                            "value": 2,
                            "value": 3,
            "iid": 3,
            "type": "urn:miot-spec-v2:service:light:00007802:hyd-znlyj1:1",
            "properties": [
                    "iid": 1,
                    "type": "urn:miot-spec-v2:property:on:00000006:hyd-znlyj1:1",
                    "format": "bool",
                    "access": [
                        "read",
                        "write",
                        "notify"
                    "unit": "none"
两款只是功能上有点差别,这个也是很接近的。特别是灯应该是一样的,但是直接用插件都没办法显示状态或控制。
用命令行猜也全是 code:-4004 05.jpg
要原因可能还是我没搞懂这些控制命令怎么用的。
发表于 2021-1-6 23:59:53 | 显示全部楼层
大神应该出一个详细的教程,相信可以帮助很多小白!拜托拜托!
3万
 楼主| 发表于 2021-1-9 01:05:51 | 显示全部楼层
原来这个小米晾衣架这些命令可以本地控制,但不能本地获取状态。
发表于 2021-2-2 17:39:52 | 显示全部楼层
作为只会用hacs 点点点的小白表示围观。
发表于 2021-4-23 12:40:51 来自手机 | 显示全部楼层
大神给小白们这个教程呀,感谢
GMT+8, 2025-12-22 17:16 , Processed in 1.633728 second(s), 13 queries , MemCached On.
