查看: 5882|回复: 9
[基础教程] 小米多模网关拆机硬刷成功后反复重启变砖如何恢复?
发表于 2020-12-20 18:23:57 | 显示全部楼层 |阅读模式
采用论坛的方法,把小米多模网关拆机强刷后,刷机一路都没有任何问题,可是刷完后反复重启。。。无法正常使用。
求助大神。
下面是反复重启的日志:
[10:10:50.464] miio_client --- dead ---reboot
[10:10:50.484]
[10:10:50.581] miio_client_helper_nomqtt --- dead ---reboot
[10:10:50.581] miio_agent --- dead ---reboot
[10:10:50.702] basic_gw --- dead ---reboot
[10:10:50.794] firmware_ota --- dead ---reboot
[10:10:51.065]
[10:10:52.638] [   12.830000] store_tty0_enable buf=disable
[10:10:52.638] [   12.830000] , count=8
[10:10:52.651]
[10:10:53.565] [   13.770000] [rtl819x_gpio_request][42]: pin36
[10:10:53.578] [   13.780000] [rtl819x_gpio_pin_enable][277]: mask=0xf0000 mux=0x0 mux_reg=0xb8000844 val=0x10000,                         CNR_REG=0xfc00032f MUX_REG=0x10000
[10:10:53.611] [   14.020000] rtl819x_gpio: GPIO36 requests IRQ108
[10:10:53.826] [   14.040000] [rtl819x_gpio_direction_output][150]: set pin36 as output pin, default value=0, DIR_REG=0x3fffcd0 DAT_REG=0x3083800
[10:10:53.861]
[10:10:54.373] [   14.570000] device wlan0 entered promiscuous mode
[10:10:54.388] [   14.590000] br0: port 2(wlan0) entered forwarding state
[10:10:54.398] [   14.600000] br0: port 2(wlan0) entered forwarding state
[10:10:54.413] [   14.740000] WlanSupportAbility = 0x3
[10:10:54.548] [   14.750000] [ODM_software_init]
[10:10:54.564] [   14.750000] [97F] Bonding Type 97FS, PKG1
[10:10:54.564] [   14.750000] [97F] RFE type 0 PHY paratemters: DEFAULT
[10:10:54.589] [   14.750000] clock 40MHz
[10:10:54.589] [   14.750000] load efuse ok
[10:10:54.598] [   14.750000] rom_progress: 0x200006f
[10:10:54.623] [   14.750000] rom_progress: 0x400006f
[10:10:54.623] [   14.820000] [GetHwReg88XX][PHY_REG_PG_8197Fmp_Type0] size
[10:10:54.635] [   14.840000] [GetHwReg88XX][PHY_REG_PG_8197Fmp_Type0]
[10:10:54.647] [   15.060000] [GetHwReg88XX][rtl8197Ffw]
[10:10:54.866] [   15.070000] [GetHw
[10:10:54.880] Reg88XX][rtl8197Ffw size]
[10:10:54.880] [   15.510000] [97F] Default BB Swing=30
[10:10:55.308]
[10:10:55.839] uart ok
[10:10:55.839] strap pin:0x412b8ae2
[10:10:55.839] enable spi-nand
[10:10:55.839] ROM ver:v1.1, sig:455cc27, time:2016.01.04-18:42+0800, CPU(400 MHz), DDR2(533 MHz)
[10:10:55.858] load efuse ok
[10:10:55.875] init IP ok
[10:10:55.875] rom_progress: 0x0600006d
[10:10:55.887] load_data_from_storage(260): 0xbfe01540, 0x00000000, 0xbfd16f44
load_data_from_spi_nand_flash(70): 0xbfe01540, 0x00000000, 0xbfe03e18
[10:10:55.929] check_image_header(72): h(69,72,61,6d), s(69,72,61,6d)
[10:10:55.944] img sig ok
[10:10:55.957] rom_progress: 0x0c00006d
[10:10:55.957] load_data_from_spi_nand_flash(81) 0x00000004 0x000024ba
[10:10:55.969] load_data_from_spi_nand_flash(86): 0xbfe01d40, 0x00000001, 0xbfe03e18
[10:10:55.987] load_data_from_spi_nand_flash(86): 0xbfe02540, 0x00000002, 0xbfe03e18
[10:10:56.007] load_data_from_spi_nand_flash(86): 0xbfe02d40, 0x00000003, 0xbfe03e18
[10:10:56.027] load_data_from_spi_nand_flash(86): 0xbfe03540, 0x00000004, 0xbfe03e18
[10:10:56.047] load_data_from_spi_nand_flash(90) read done (size:9402)
[10:10:56.063] chksum ok
[10:10:56.073] rom_progress: 0x0e00006d
[10:10:56.083] load img ok
[10:10:56.083] rom_progress: 0x1000006d
[10:10:56.093] jump 0xbfe01550
[10:10:56.093]
[10:10:56.233] Booting...
[10:10:56.233]
[10:10:56.438] SPI NAND clock not enable
[10:10:56.438]
[10:10:56.438] SPI Nand ID=00efaa21
[10:10:56.447] SPI Nand die chipsize=0x08000000 byte
[10:10:56.456] SPI Nand dienum=1,
[10:10:56.465] SPI Nand blocksize=0x00020000 byte,
[10:10:56.476] SPI Nand pagesize=0x00000800 byte,
[10:10:56.485] SPI Nand oobsize=0x00000040 byte,
[10:10:56.494] [rtkn_scan_bbt, line 1812], RBA=51, this->RBA_PERCENT = 5,block_v2r_num=1024
[10:10:56.529] [rtkn_scan_bbt, line 1822] block_v2r_num 00000400
[10:10:56.529]
[rtk_scan_v2r_bbt]:678,RBA=00000033,2=00000400,
[10:10:56.547] [rtk_scan_v2r_bbt]:684,block_v2r_num=000003cd
[10:10:56.557] INFO: Stored BBT in Die 0: block=8 , block_status_p1=0x000000bb
[10:10:56.581]
load bbt v2r table:0 page:512
[10:10:56.594]
[10:10:56.604] [rtk_scan_v2r_bbt] have created v2r bbt table:0 on block 8, just loads it !!
[10:10:56.616]
[10:10:56.627] check v2r bbt table:0 OK
[10:10:56.627]
[rtk_nand_scan_bbt, line 393] mem_page_num=1 bbt_page 704
[10:10:56.646] INFO: Stored BBT in Die 0: block=11 , block_status_p1=0x000000bb
load bbt table:0 page:704
[10:10:56.678]
[10:10:56.687] [rtk_nand_scan_bbt] have created bbt table:0 on block 11, just loads it !!
[10:10:56.705]
check bbt table:0 OK
[10:10:56.715]
[dump_BBT] Nand BBT Content
[10:10:56.715]
Congratulation!! No BBs in this Nand.
[10:10:56.727]
[10:10:57.025] =>CPU Wake-up interrupt happen! GISR=09000084
[10:10:57.042]
[10:10:57.518] Realtek RTL8197F boot code at
[10:10:57.537]  2019.11.15-19:29+0800 v3.4T-pre2.1 (993MHz)
[10:10:57.537] -- version: 1.0.2.005 --
[10:10:57.548] Info: Load boot_info success!
[10:10:57.672] === bootloader for mijia_gw ===
[10:10:57.686] boot_info: ver:0
[10:10:57.699] kernel: newest:0, curr:0
[10:10:57.699] rootfs: newest:0, curr:0
[10:10:57.709] kernel[0]: sum:0xc8cf, size:2157572, fail:0
[10:10:57.718]       [1]: sum:0xc8cf, size:2157572, fail:0
[10:10:57.727] rootfs[0]: sum:0x62c6, size:8552452, fail:0
[10:10:57.745]       [1]: sum:0x62c6, size:8552452, fail:0
[10:10:57.754] root_sum_check: off
[10:10:57.764] watchdog_time: 0
[10:10:57.764]
boot_version: 1.0.2.005
[10:10:57.775] priv mode
[10:10:57.785] Info: loading kernel 0 ...
[10:10:59.829] Done
[10:10:59.829] Info: checking kernel 0 ... Success
[10:11:00.138] Info: select rootfs 0
[10:11:00.138] Info: booting...
[10:11:00.138] Jump to image start=0x80a00000...
[10:11:00.159] decompressing kernel:
[10:11:00.159] Uncompressing Linux...
[10:11:00.924]  done, booting the kernel.
[10:11:00.924] done decompressing kernel.
[10:11:00.942] start address: 0x8050cc40
[10:11:00.946] [    0.000000] Linux version 3.10.90 (liaozhaobao@compilex64-ipg) (gcc version 4.9.4 20151028 (prerelease) (Realtek MSDK-4.9.4p1 Build 2648) ) #68 Fri Apr 3 15:18:37 CST 2020
[10:11:00.998] [    0.000000] bootconsole [early0] enabled
[10:11:00.998] [    0.000000] CPU revision is: 00019385 (MIPS 24Kc)
[10:11:01.015] [    0.000000] Determined physical RAM map:
[10:11:01.024] [    0.000000]  memory: 04000000 @ 00000000 (usable)
[10:11:01.048] [    0.000000] Zone ranges:
[10:11:01.048] [    0.000000]   Normal   [mem 0x00000000-0x03ffffff]
[10:11:01.065] [    0.000000] Movable zone start for each node
[10:11:01.075] [    0.000000] Early memory node ranges
[10:11:01.098] [    0.000000]   node   0: [mem 0x00000000-0x03ffffff]
[10:11:01.098] [    0.000000] Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes.
[10:11:01.123] [    0.000000] Primary data cache 32kB, 4-way, PIPT, no aliases, linesize 32 bytes
[10:11:01.148] [    0.000000] Built 1 zonelists in Zone order, mobility grouping off.  Total pages: 4088
[10:11:01.165] [    0.000000] Kernel command line: root=/dev/mtdblock6 console=ttyS0,38400
[10:11:01.189] [    0.000000] PID hash table entries: 256 (order: -4, 1024 bytes)
[10:11:01.206] [    0.000000] Dentry cache hash table entries: 8192 (order: 1, 32768 bytes)
[10:11:01.223] [    0.000000] Inode-cache hash table entries: 4096 (order: 0, 16384 bytes)
[10:11:01.248] [    0.000000] Writing ErrCtl register=00000b50
[10:11:01.256] [    0.000000] Readback ErrCtl register=00000b50
[10:11:01.269] [    0.000000] Memory: 58208k/65536k available (5203k kernel code, 7328k reserved, 1002k data, 192k init, 0k highmem)
[10:11:01.302] [    0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[10:11:01.327] [    0.000000] NR_IRQS:192
[10:11:01.327] [    0.000000] Realtek GPIO IRQ init
[10:11:01.349] [    0.000000] Calibrating delay loop... 660.68 BogoMIPS (lpj=3303424)
[10:11:01.416] [
[10:11:01.431]     0.070000] pid_max: default: 32768 minimum: 301
[10:11:01.444] [    0.080000] Mount-cache hash table entries: 2048
[10:11:01.446] [    0.090000] [rtl819x_gpio_pin_enable][277]: mask=0xf00 mux=0x0 mux_reg=0xb8000844 val=0x100,                         CNR_REG=0xffffffbf MUX_REG=0x100
[10:11:01.487] [    0.100000] [rtl819x_gpio_direction_output][150]: set pin38 as output pin, default value=0, DIR_REG=0x40 DAT_REG=0x3000000
[10:11:01.528] [    0.110000] [rtl819x_gpio_pin_enable][277]: mask=0xf0 mux=0x100 mux_reg=0xb8000844 val=0x10,                         CNR_REG=0xffffff3f MUX_REG=0x110
[10:11:01.553] [    0.120000] [rtl819x_gpio_direction_output][150]: set pin39 as output pin, default value=0, DIR_REG=0xc0 DAT_REG=0x3000000
[10:11:01.587] [    0.130000] [rtl819x_gpio_pin_enable][277]: mask=0xf000000 mux=0x0 mux_reg=0xb8000848 val=0x4000000,                         CNR_REG=0xfffffb3f MUX_REG=0x4000000
[10:11:01.620] [    0.140000] [rtl819x_gpio_direction_output][150]: set pin42 as output pin, default value=0, DIR_REG=0x4c0 DAT_REG=0x3000000
[10:11:01.653] [    0.150000] [rtl819x_gpio_pin_enable][277]: mask=0xf00000 mux=0x4000000 mux_reg=0xb8000848 val=0x400000,                         CNR_REG=0xfffff33f MUX_REG=0x4400000
[10:11:01.694] [    0.160000] [rtl819x_gpio_direction_output][150]: set pin43 as output pin, default value=1, DIR_REG=0xcc0 DAT_REG=0x3000800
[10:11:01.727] [    0.170000] [rtl819x_gpio_pin_enable][277]: mask=0xf0000 mux=0x4400000 mux_reg=0xb8000848 val=0x60000,                         CNR_REG=0xffffe33f MUX_REG=0x4460000
[10:11:01.769] [    0.180000] [rtl819x_gpio_direction_output][150]: set pin44 as output pin, default value=1, DIR_REG=0x1cc0 DAT_REG=0x3001800
[10:11:01.802] [    0.190000] [rtl819x_gpio_pin_enable][277]: mask=0xf000 mux=0x4460000 mux_reg=0xb8000848 val=0x6000,                         CNR_REG=0xffffc33f MUX_REG=0x4466000
[10:11:01.835] [    0.200000] [rtl819x_gpio_direction_output][150]: set pin45 as output pin, default value=1, DIR_REG=0x3cc0 DAT_REG=0x3003800
[10:11:01.868] [    0.210000] [rtl819x_gpio_pin_enable][277]: mask=0xf000000 mux=0x11111000 mux_reg=0xb8000820 val=0x6000000,                         CNR_REG=0xffff833f MUX_REG=0x16111000
[10:11:01.918] [    0.220000] [rtl819x_gpio_direction_output][150]: set pin46 as output pin, defau
[10:11:01.935] lt value=1, DIR_REG=0x7cc0 DAT_REG=0x3007800
[10:11:01.946] [    0.230000] [rtl819x_gpio_pin_enable][277]: mask=0xf0000000 mux=0x16111000 mux_reg=0xb8000820 val=0x60000000,                         CNR_REG=0xffff033f MUX_REG=0x66111000
[10:11:01.985] [    0.240000] [rtl819x_gpio_direction_output][150]: set pin47 as output pin, default value=0, DIR_REG=0xfcc0 DAT_REG=0x3007800
[10:11:02.018] [    0.250000] [rtl819x_gpio_pin_enable][277]: mask=0xf00000 mux=0x66111000 mux_reg=0xb8000820 val=0x600000,                         CNR_REG=0xfffe033f MUX_REG=0x66611000
[10:11:02.059] [    0.260000] [rtl819x_gpio_direction_output][150]: set pin48 as output pin, default value=1, DIR_REG=0x1fcc0 DAT_REG=0x3017800
[10:11:02.092] [    0.270000] [rtl819x_gpio_pin_enable][277]: mask=0xf0000 mux=0x66611000 mux_reg=0xb8000820 val=0x70000,                         CNR_REG=0xfffc033f MUX_REG=0x66671000
[10:11:02.125] [    0.280000] [rtl819x_gpio_direction_output][150]: set pin49 as output pin, default value=1, DIR_REG=0x3fcc0 DAT_REG=0x3037800
[10:11:02.159] [    0.290000] [rtl819x_gpio_pin_enable][277]: mask=0xf000 mux=0x66671000 mux_reg=0xb8000820 val=0x7000,                         CNR_REG=0xfff8033f MUX_REG=0x66677000
[10:11:02.209] [    0.300000] [rtl819x_gpio_direction_output][150]: set pin50 as output pin, default value=0, DIR_REG=0x7fcc0 DAT_REG=0x3037800
[10:11:02.233] [    0.310000] [rtl819x_gpio_pin_enable][277]: mask=0xf0000000 mux=0x100000 mux_reg=0xb8000824 val=0x20000000,                         CNR_REG=0xfff0033f MUX_REG=0x20100000
[10:11:02.275] [    0.320000] [rtl819x_gpio_direction_output][150]: set pin51 as output pin, default value=1, DIR_REG=0xffcc0 DAT_REG=0x30b7800
[10:11:02.308] [    0.330000] [rtl819x_gpio_pin_enable][277]: mask=0xf000000 mux=0x20100000 mux_reg=0xb8000824 val=0x1000000,                         CNR_REG=0xffe0033f MUX_REG=0x21100000
[10:11:02.349] [    0.340000] [rtl819x_gpio_direction_output][150]: set pin52 as output pin, default value=0, DIR_REG=0x1ffcc0 DAT_REG=0x30b7800
[10:11:02.382] [    0.350000] [rtl819x_gpio_pin_enable][277]: mask=0xf00000 mux=0x21100000 mux_reg=0xb8000824 val=0x0,                         CNR_REG=0xffc0033f MUX_REG=0x21000000
[10:11:02.416] [    0.360000] [rtl819x_gpio_direction_output][150]: set pin53 as output
[10:11:02.449]  pin, default value=0, DIR_REG=0x3ffcc0 DAT_REG=0x30b7800
[10:11:02.449] [    0.370000] [rtl819x_gpio_pin_enable][277]: mask=0xf000000 mux=0x33320000 mux_reg=0xb8000834 val=0x3000000,                         CNR_REG=0xff40033f MUX_REG=0x33320000
[10:11:02.498] [    0.380000] [rtl819x_gpio_direction_output][150]: set pin55 as output pin, default value=0, DIR_REG=0xbffcc0 DAT_REG=0x30b7800
[10:11:02.524] [    0.390000] NET: Registered protocol family 16
[10:11:02.536] [    0.400000] <<<<<Register PCI Controller>>>>>
[10:11:02.551] [    0.420000] Do MDIO_RESET
[10:11:02.570] [    0.450000] 40MHz
[10:11:02.605]
[10:11:02.971] [    0.810000] PCIE ->  Cannot LinkUP
[10:11:02.989] [    0.820000] Realtek GPIO controller driver init
[10:11:02.989] [    0.830000] INFO: initializing i2c devices ...
[10:11:03.006] [    0.840000] INFO: registering sheipa spi device
[10:11:03.016] [    0.860000] bio: create slab <bio-0> at 0
[10:11:03.044] [    0.870000] SCSI subsystem initialized
[10:11:03.069] [    0.880000] INFO: sheipa spi driver register
[10:11:03.069] [    0.890000] INFO: sheipa spi probe
[10:11:03.079] [    0.900000] cfg80211: Calling CRDA to update world regulatory domain
[10:11:03.107] [    0.910000] Switching to clocksource MIPS
[10:11:03.114] [    0.920000] NET: Registered protocol family 2
[10:11:03.132] [    0.930000] TCP established hash table entries: 2048 (order: 0, 16384 bytes)
[10:11:03.157] [    0.950000] TCP bind hash table entries: 2048 (order: -1, 8192 bytes)
[10:11:03.174] [    0.970000] TCP: Hash tables configured (established 2048 bind 2048)
[10:11:03.199] [    0.990000] TCP: reno registered
[10:11:03.199] [    1.000000] UDP hash table entries: 1024 (order: 0, 16384 bytes)
[10:11:03.215] [    1.020000] UDP-Lite hash table entries: 1024 (order: 0, 16384 bytes)
[10:11:03.249] [    1.040000] NET: Registered protocol family 1
[10:11:03.249] [    1.050000] RPC: Registered named UNIX socket transport module.
[10:11:03.265] [    1.070000] RPC: Registered udp transport module.
[10:11:03.282] [    1.080000] RPC: Registered tcp transport module.
[10:11:03.298] [    1.100000] RPC: Registered tcp NFSv4.1 backchannel transport module.
[10:11:03.314] [    1.130000] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[10:11:03.344] [    1.150000] NFS: Registering the id_resolver key type
[10:11:03.362] [    1.160000] Key type id_resolver registered
[10:11:03.379] [    1.180000] Key type id_legacy registered
[10:11:03.387] [    1.190000] NTFS driver 2.1.30 [Flags: R/W DEBUG].
[10:11:03.405] [    1.200000] msgmni has been set to 113
[10:11:03.413] [    1.220000] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 254)
[10:11:03.437] [    1.240000] io scheduler noop registered (default)
[10:11:03.454] [    1.250000] pwm_probe
[10:11:03.469] [    1.260000] add buzzer dev!!!!!!!!!!!!!!!!
[10:11:03.469]
[10:11:03.598] [    1.380000] Serial: 8250/16550 driver, 3 ports, IRQ sharing disabled
[10:11:03.612] [    1.400000] serial8250: ttyS0 at MMIO 0x18147000 (irq = 17) is a 16550A
[    1.420000] console [ttyS0] enabled, bootconsole disabled
[10:11:03.648] [    1.420000] console [ttyS0] enabled, bootconsole disabled
[10:11:03.657] [    1.450000] serial8250: ttyS1 at MMIO 0x18147400 (irq = 46) is a 16550A
[10:11:03.674] [    1.480000] serial8250: ttyS2 at MMIO 0x18147800 (irq = 47) is a 16550A
[10:11:03.694] [    1.500000] Realtek GPIO Driver for Flash Reload Default
[10:11:03.719] [    1.510000] Load Kernel firmware information Driver
[10:11:03.726] [    1.530000] id_chain value=efaa21ff
[10:11:03.752] [    1.540000] id_chain value=efaa21ff
[10:11:03.760] [    1.550000] NAND device: Manufacturer ID: 0xef, Chip ID: 0xaa (Unknown W25M01GV 1G SPI NAND), 128MiB, page size: 2048, OOB size: 64
[10:11:03.785] [    1.580000] [rtkn_scan_bbt, line 1812], RBA=51, this->RBA_PERCENT = 5,block_v2r_num=1024
[10:11:03.818] [    1.610000] [rtkn_scan_bbt, line 1822] block_v2r_num 400
[10:11:03.826] [rtk_scan_v2r_bbt]:678,RBA=33,2=400,
[10:11:03.835] [    1.640000] [rtk_scan_v2r_bbt]:684,block_v2r_num=3cd
[10:11:03.849] [    1.660000] INFO: Stored BBT in Die 0: block=8 , block_status_p1=0xbb
[10:11:03.878] [    1.680000] load bbt v2r table:0 page:512
[10:11:03.886] [rtk_scan_v2r_bbt] have created v2r bbt table:0 on block 8, just loads it !!
[10:11:03.908] check v2r bbt table:0 OK
[10:11:03.917] [rtk_nand_scan_bbt, line 393] mem_page_num=1 bbt_page 704
[10:11:03.932] [    1.740000] INFO: Stored BBT in Die 0: block=11 , block_status_p1=0xbb
[10:11:03.968] [    1.760000] load bbt table:0 page:704
[10:11:03.968] [rtk_nand_scan_bbt] have created bbt table:0 on block 11, just loads it !!
[10:11:03.994] check bbt table:0 OK
[10:11:04.003] [dump_BBT] Nand BBT Content
[10:11:04.019] [    1.800000] Congratulation!! No BBs in this Nand.
[10:11:04.019] [    1.820000] 11 rtkxxpart partitions found on MTD device rtk_nand
[10:11:04.036] [    1.840000] Creating 11 MTD partitions on "rtk_nand":
[10:11:04.051] [    1.870000] Realtek WLAN driver - version 1.7 (2015-10-30)(SVN:Unversioned directory)
[10:11:04.098] [    1.890000] Adaptivity function - v
[10:11:04.107] ersion 9.3.4
[10:11:04.107] [    1.900000] Device Name = RTKWiFi0
[10:11:04.120] [    1.910000] VIF_NUM=9
[10:11:04.129] [    1.920000] MACHAL_version_init
[10:11:04.136] [    1.930000] RFE TYPE =0
[10:11:04.149] [    1.940000] RFE TYPE =0
[10:11:04.149] [    1.950000] RFE TYPE =0
[10:11:04.158] [    1.960000] RFE TYPE =0
[10:11:04.167] [    1.970000] RFE TYPE =0
[10:11:04.176] [    1.980000] RFE TYPE =0
[10:11:04.185] [    1.990000] RFE TYPE =0
[10:11:04.195] [    2.000000] RFE TYPE =0
[10:11:04.204] [    2.000000] RFE TYPE =0
[10:11:04.219] [    2.010000] RFE TYPE =0
[10:11:04.219] [    2.020000] RFE TYPE =0
[10:11:04.228] [    2.030000] lumi_btn_probe reset btn=7
[10:11:04.245] [    2.040000] [rtl819x_gpio_request][42]: pin7
[10:11:04.255] [    2.050000] [rtl819x_gpio_pin_enable][277]: mask=0xf00000 mux=0x13000000 mux_reg=0xb8000800 val=0x600000,                         CNR_REG=0xffffff7f MUX_REG=0x13600000
[10:11:04.295] [    2.090000] [rtl819x_gpio_direction_input][120]: set pin7 as input pin, DIR_REG=0xff000000
[10:11:04.329] [    2.120000] rtl819x_gpio: GPIO7 requests IRQ79
[10:11:04.337] [    2.130000] input: lumi_key as /devices/virtual/input/input0
[10:11:04.355] [    2.150000] i2c /dev entries driver
[10:11:04.365] [    2.160000] [rtl819x_gpio_request][42]: pin57
[10:11:04.374] [    2.170000] [rtl819x_gpio_pin_enable][277]: mask=0xf0000 mux=0x33320000 mux_reg=0xb8000834 val=0x20000,                         CNR_REG=0xfd40033f MUX_REG=0x33320000
[10:11:04.414] [    2.210000] [rtl819x_gpio_direction_output][150]: set pin57 as output pin, default value=1, DIR_REG=0x2bffcc0 DAT_REG=0x30b7800
[10:11:04.448] [    2.250000] rtl819x_gpio: GPIO57 requests IRQ129
[10:11:04.464] [    2.260000] [rtl819x_gpio_request][42]: pin56
[10:11:04.473] [    2.270000] [rtl819x_gpio_pin_enable][277]: mask=0xf00000 mux=0x33320000 mux_reg=0xb8000834 val=0x300000,                         CNR_REG=0xfc40033f MUX_REG=0x33320000
[10:11:04.515] [    2.310000] [rtl819x_gpio_direction_output][150]: set pin56 as output pin, default value=1, DIR_REG=0x3bffcc0 DAT_REG=0x30b7800
[10:11:04.548] [    2.350000] rtl819x_gpio: GPIO56 requests IRQ128
[10:11:04.565] [    2.360000] [rtl819x_gpio_request][42]: pin54
[10:11:04.573] [    2.380000] [rtl819x_gpio_pin_enable][277]: mask=0xf0000000 mux=0x33320000 mux_reg=0xb8000834 val=0x30000000,                         CNR_REG=0xfc00
[10:11:04.615] 033f MUX_REG=0x33320000
[10:11:04.615] [    2.420000] [rtl819x_gpio_direction_output][150]: set pin54 as output pin, default value=0, DIR_REG=0x3fffcc0 DAT_REG=0x30b7800
[10:11:04.649] [    2.450000] rtl819x_gpio: GPIO54 requests IRQ126
[10:11:04.663] [    2.470000] TCP: cubic registered
[10:11:04.674] [    2.480000] NET: Registered protocol family 10
[10:11:04.689] [    2.490000] sit: IPv6 over IPv4 tunneling driver
[10:11:04.705] [    2.510000] NET: Registered protocol family 17
[10:11:04.722] [    2.520000] Key type dns_resolver registered
[10:11:04.738] [    2.530000]
[10:11:04.738] [    2.530000] Probing RTL819X NIC-kenel stack size order[0]...
[10:11:04.754]
[10:11:05.435] [    3.230000] eth0 added. vid=9 Member port 0x110...
[10:11:05.451] [    3.240000] eth1 added. vid=8 Member port 0x0...
[10:11:05.465] [    3.260000] Key type encrypted registered
[10:11:05.476] [    3.290000] VFS: Mounted root (squashfs filesystem) readonly on device 31:6.
[10:11:05.519] [    3.310000] Freeing unused kernel memory: 192K (80610000 - 80640000)
[10:11:05.527]
[10:11:06.035]
init started: BusyBox v1.22.1 (2020-03-19 12:38:22 CST)
[10:11:06.054] [    4.250000] WlanSupportAbility = 0x3
[10:11:06.479] [    4.270000] [ODM_software_init]
[10:11:06.479] [    4.270000] [97F] Bonding Type 97FS, PKG1
[10:11:06.488] [    4.270000] [97F] RFE type 0 PHY paratemters: DEFAULT
[10:11:06.504] [    4.270000] clock 40MHz
[10:11:06.519] [    4.270000] load efuse ok
[10:11:06.529] [    4.270000] rom_progress: 0x200006f
[10:11:06.529] [    4.270000] rom_progress: 0x400006f
[10:11:06.537]
[10:11:06.546] [    4.340000] [GetHwReg88XX][PHY_REG_PG_8197Fmp_Type0] size
[10:11:06.555] [    4.360000] [GetHwReg88XX][PHY_REG_PG_8197Fmp_Type0]
[10:11:06.572] [    4.570000] [GetHwReg88XX][rtl8197Ffw]
[10:11:06.801] [    4.590000] [GetHwReg88XX][rtl8197Ffw size]
[10:11:06.801]
[10:11:07.227] [    5.020000] [97F] Default BB Swing=30
[10:11:07.237] [    5.070000] device eth0 entered promiscuous mode
[10:11:07.283] [    5.120000] device wlan0 entered promiscuous mode
[10:11:07.336] [    5.140000] br0: port 2(wlan0) entered forwarding state
[10:11:07.353] [    5.150000] br0: port 2(wlan0) entered forwarding state
[10:11:07.368] === Linux Firmware ===
[10:11:07.384] version=1.4.6_0012
[10:11:07.394] branch=aqara-rtl8197-gateway
[10:11:07.404] *try mount ubi0!!!
[10:11:07.404] test for jacky![    5.230000] UBI: attaching mtd10 to ubi0
[10:11:07.446]
[10:11:07.446]
[10:11:08.765] [    6.550000] UBI: scanning is finished
[10:11:08.765] [    6.600000] UBI: attached mtd10 (name "AppData", size 56 MiB) to ubi0
[10:11:08.824] [    6.620000] UBI: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[10:11:08.849] [    6.640000] UBI: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
[10:11:08.866] [    6.660000] UBI: VID header offset: 2048 (aligned 2048), data offset: 4096
[10:11:08.883] [    6.680000] UBI: good PEBs: 449, bad PEBs: 0, corrupted PEBs: 0
[10:11:08.899] [    6.700000] UBI: user volume: 1, internal volumes: 1, max. volumes count: 128
[10:11:08.924] [    6.720000] UBI: max/mean erase counter: 113/30, WL threshold: 4096, image sequence number: 2629030426
[10:11:08.949] [    6.750000] UBI: available PEBs: 0, total reserved PEBs: 449, PEBs reserved for bad PEB handling: 20
[10:11:08.975] [    6.780000] UBI: background thread "ubi_bgt0d" started, PID 932
[10:11:08.993] UBI device number 0, total 449 LEBs (57012224 by[    6.820000] UBIFS: parse sync
[10:11:09.039] tes, 54.4 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB)
[10:11:09.058] [    6.940000] UBIFS: background thread "ubifs_bgt0_0" started, PID 939
[10:11:09.156]
[10:11:09.263] [    7.050000] UBIFS: recovery needed
[10:11:09.263]
[10:11:09.996] [    7.790000] UBIFS: recovery completed
[10:11:10.013] [    7.800000] UBIFS: mounted UBI device 0, volume 0, name "ubifs1"
[10:11:10.029] [    7.820000] UBIFS: LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[10:11:10.045] [    7.850000] UBIFS: FS size: 52695040 bytes (50 MiB, 415 LEBs), journal size 2666496 bytes (2 MiB, 21 LEBs)
[10:11:10.079] [    7.870000] UBIFS: reserved for root: 2488917 bytes (2430 KiB)
[10:11:10.096] [    7.890000] UBIFS: media format: w4/r0 (latest is w4/r0), UUID 548CA61C-2047-4061-BDF0-F2C2C5A3191B, small LPT model
[10:11:10.123] is old unecrypt [    8.030000] [rtl819x_gpio_request][42]: pin18
[10:11:10.255] dir!
[10:11:10.255] [    8.050000] [rtl819x_gpio_pin_enable][277]: mask=0xf00 mux=0x455000 mux_reg=0xb8000808 val=0x600,                         CNR_REG=0xfffbff7f MUX_REG=0x455600
[10:11:10.290] [    8.090000] rtl819x_gpio: GPIO18 requests IRQ90
[10:11:10.303] [    8.110000] [rtl819x_gpio_direction_output][150]: set pin18 as output pin, default value=0, DIR_REG=0xff040000 DAT_REG=0x40080
[10:11:10.339] [    8.140000] [rtl819x_gpio_request][42]: pin9
[10:11:10.359] [    8.160000] [rtl819x_gpio_pin_enable][277]: mask=0xf0000 mux=0x455600 mux_reg=0xb8000808 val=0xa0000,                         CNR_REG=0xfffbfd7f MUX_REG=0x4a5600
[10:11:10.408] [    8.200000] rtl819x_gpio: GPIO9 requests IRQ81
[10:11:10.408] [    8.220000] [rtl819x_gpio_direction_output][150]: set pin9 as output pin, default value=0, DIR_REG=0xff040200 DAT_REG=0x40080
[10:11:10.448] MAC=5C:E5:0C:C4:0E:AA
[10:11:10.466]
[10:11:10.525] [    8.320000] [rtl819x_gpio_request][42]: pin31
[10:11:10.540] [    8.330000] [rtl819x_gpio_pin_enable][277]: mask=0xf0 mux=0x22220077 mux_reg=0xb800083c val=0x70,                         CNR_REG=0x7ffbfd7f MUX_REG=0x22220077
[10:11:10.568] [    8.510000] rtl819x_gpio: GPIO31 requests IRQ103
[10:11:10.726] [    8.520000] [rtl819x_gpio_direction_output][150]: set pin31 as output pin, default value=0, DIR_REG=0xff040200 DAT_REG=0x40280
[10:11:10.754] === RootFS Firmware ===
[10:11:10.891] product=aqara-rtl8197-gateway
[10:11:10.914] branch=develop
[10:11:10.932] VERSION=1.4.6_0012
[10:11:10.937] version=1.4.6_0012
[10:11:10.937] Will Start OT!!
[10:11:10.967] device br0 already exists; can't create bridge with the same name
[10:11:10.994] device wlan0 is already a member of a bridge; can't enslave it to bridge br0.
[10:11:11.019] bridge name        bridge id                STP enabled        interfaces
[10:11:11.028] br0                8000.5ce50cc40eaa        no                eth0
[10:11:11.036]
[10:11:11.036]                                                         wlan0
[10:11:11.036] killall: miio_agent: no process killed
[10:11:11.049] killall: miio_client: no process killed
[10:11:11.069] killall: miio_client_helper_nomqtt.sh: no process killed
[10:11:11.069] killall: basic_app: no process killed
[10:11:11.086] killall: basic_gw: no process killed
[10:11:11.099] killall: wpa_supplicant: no process killed
[10:11:11.106] killall: udhcpd: no process killed
[10:11:11.120] killall: udhcpc: no process killed
[10:11:11.120] killall: hostapd: no process killed
[10:11:11.136] killall: eth0_start.sh: no process killed
[10:11:11.144] killall: wifi_start.sh: no process killed
[10:11:11.156] killall: wpa_supplicant: no process killed
[10:11:11.173] killall: udhcpd: no process killed
[10:11:11.186] killall: hostapd: no process killed
[10:11:11.197] killall: udhcpc: no process killed
[10:11:11.207] [    9.000000] br0: port 2(wlan0) entered disabled state
[10:11:11.223] [    9.020000] WlanSupportAbility = 0x3
[10:11:11.239] [    9.030000] [ODM_software_init]
[10:11:11.239] [    9.030000] [97F] Bonding Type 97FS, PKG1
[10:11:11.256] [    9.030000] [97F] RFE type 0 PHY paratemters: DEFAULT
[10:11:11.267] [    9.030000] clock 40MHz
[10:11:11.275] [    9.030000] load efuse ok
[10:11:11.283] [    9.030000] rom_progress: 0x200006f
[10:11:11.298] [    9.030000] rom_progress: 0x400006f
[10:11:11.307] [    9.100000] [GetHwReg88XX][PHY_REG_PG_8197Fmp_Type0] size
[10:11:11.324] [    9.120000] [GetHwReg88XX][PHY_REG_PG_8197Fmp_Type0]
[10:11:11.333]
[10:11:11.543] [    9.340000] [GetHwReg88XX][rtl8197Ffw]
[10:11:11.562] [    9.350000] [GetHwReg88XX][rtl8197Ffw size]
[10:11:11.568] [    9.780000] [97F] Default BB Swing=30
[10:11:11.998] [    9.790000] br0: port 2(wlan0) entered forwarding state
[10:11:12.015] [    9.810000] br0: port 2(wlan0) entered forwarding state
[10:11:12.033]
[10:11:12.071] [    9.870000] device wlan0 left promiscuous mode
[10:11:12.088] [    9.880000] br0: port 2(wlan0) entered disabled state
[10:11:12.098] [    9.920000] WlanSupportAbility = 0x3
[10:11:12.134] [    9.940000] [ODM_software_init]
[10:11:12.159] [    9.940000] [97F] Bonding Type 97FS, PKG1
[10:11:12.159] [    9.940000] [97F] RFE type 0 PHY paratemters: DEFAULT
[10:11:12.175] [    9.940000] clock 40MHz
[10:11:12.186] [    9.940000] load efuse ok
[10:11:12.197] [    9.940000] rom_progress: 0x200006f
[10:11:12.205] [    9.940000] rom_progress: 0x400006f
[10:11:12.218] [   10.010000] [GetHwReg88XX][PHY_REG_PG_8197Fmp_Type0] size
[10:11:12.226] [   10.030000] [GetHwReg88XX][PHY_REG_PG_8197Fmp_Type0]
[10:11:12.242] [   10.240000] [GetHwReg88XX][rtl8197Ffw]
[10:11:12.458] [   10.250000] [GetHwReg88XX][rtl8197Ffw size]
[10:11:12.471]
[10:11:12.897] [   10.690000] [97F] Default BB Swing=30
[10:11:12.907] miio_client --- dead ---reboot
[10:11:12.966] miio_client_helper_nomqtt --- dead ---reboot
[10:11:13.126] miio_agent --- dead ---reboot
[10:11:13.294]
[10:11:13.438] basic_gw --- dead ---reboot
[10:11:13.438] firmware_ota --- dead ---reboot
发表于 2020-12-20 22:06:19 | 显示全部楼层
试下刷自定义固件
 楼主| 发表于 2020-12-20 23:13:20 | 显示全部楼层
lipwah 发表于 2020-12-20 22:06
试下刷自定义固件
我就是刷的自定义固件,也尝试刷过老版本,都不行,刷的时候很愉快。。。没问题。
发表于 2020-12-21 09:56:49 | 显示全部楼层
BootLoader和系统版本不对照?
发表于 2020-12-21 10:37:42 | 显示全部楼层
后面应该还有日志,没有后面日志,只能猜它好像进入配对模式了。
有多少日志就多贴吧。
 楼主| 发表于 2020-12-26 21:55:10 | 显示全部楼层
有多少日志就多贴吧。 ...
后面就重启了。。。跟贴出来的日志一样的。
 楼主| 发表于 2020-12-26 22:56:27 | 显示全部楼层
AnyLine 发表于 2020-12-21 09:56
BootLoader和系统版本不对照?
对照都哦,老俄github下的版本。
 楼主| 发表于 2021-1-16 14:36:54 | 显示全部楼层
哪位有救砖大法不哈?
发表于 2021-1-17 01:10:52 | 显示全部楼层
重刷………………
发表于 2024-2-4 22:05:09 | 显示全部楼层
dotlife 发表于 2021-1-16 14:36
哪位有救砖大法不哈?
你的问题解决了不
GMT+8, 2026-1-15 20:05 , Processed in 0.996040 second(s), 10 queries , MemCached On.
