查看: 18636|回复: 3
[基础教程] 求助Win10 Docker Desktop 安装 Home-assistant没有Supervisor
发表于 2020-12-20 09:25:40 | 显示全部楼层 |阅读模式
环境:Win10 专业版1909
用Docker Desktop(https://docs.docker.com/)参照官网推荐的Docker方式安装,https://www.home-assistant.io/docs/installation/docker/,运行后只有基本的OS。
Supervisor的镜像也下载了,但是同时运行就自动关了。
搜了论坛好几天,基本都是在非Win的操作系统或者win的虚拟机里,Windows Docker Desktop下的安装还请大家指点。
原因:Ubuntu 20.04 安装 Home-assistant,正常运行3个月。进入12月后一次系统更新后发现Supervisor不能用了,在官网发现不维护Ubuntu了,建议用Debian10.
https://community.home-assistant.io/t/installing-home-assistant-supervised-on-ubuntu-18-04-4/200020
This guide is now deprecated and will no longer be updated or maintained. It is highly recommended to follow the Debian 10 guide HERE
[size=0.7579em]2.3k
to have a supported Supervised install.
There is no need to use Ubuntu and continued changes being made to Home Assistant Supervised make its continued use at your own risk and it may fail to work at any time. Please do not post for support if you face an issue.Ubuntu 18.04 does not have the minimum version of network-manager required by for a Supervised install, and as from supervisor 2020.12.06 you will get errors about having an “unsupported” installation and an “unhealthy” system. This may/will prevent you updating Home Assistant.但是自己笔记本太老,装了Debian10进不了系统。
有个树莓派3B+,感觉运行速度太慢了。
用Docker Desktop又不知道怎么同时运行Supervisor容器。
佑桑
发表于 2020-12-20 16:30:24 | 显示全部楼层
https://www.home-assistant.io/hassio/installation/
下載 vhdx 使用 Hyper-V 就會有了
发表于 2021-3-5 21:04:45 | 显示全部楼层
折腾了一天了,不知道什么用
发表于 2021-3-5 21:08:57 | 显示全部楼层
Win10 Docker Homeassistant
明天继续,希望可以折腾出来
GMT+8, 2025-12-29 08:22 , Processed in 0.297784 second(s), 9 queries , MemCached On.
