楼主: kingwell
小米多模网关任意版本固件接入HomeAssistant——刷机篇
发表于 2021-1-26 19:27:45 | 显示全部楼层
zhizhi1991 发表于 2020-12-17 10:58
三大妈的帖子,原帖的RX和TX接线点好像标错了,昨晚按原帖标注的接不行,调换一下就可以了 ...
还好有看到你,我也是弄了好久
发表于 2021-2-2 23:03:31 来自手机 | 显示全部楼层
学习学习
发表于 2021-2-3 00:10:08 | 显示全部楼层
谢谢分享
发表于 2021-2-19 04:40:20 | 显示全部楼层
打个卡,收藏以后试试
发表于 2021-2-20 12:45:23 | 显示全部楼层
这个固件能支持小米人体传感器5S检测一次吗?
发表于 2021-2-26 23:55:33 | 显示全部楼层
==MGL03 UART Recovery v231120_01==
   >>Power ON Gateway NOW!<<
art ok
strap pin:0x412b8ae2
enable spi-nand
ROM ver:v1.1, sig:455cc27, time:2016.01.04-18:42+0800, CPU(400 MHz), DDR2(533 MHz)
load efuse ok
init IP ok
rom_progress: 0x0600006d
load_data_from_storage(260): 0xbfe01540, 0x00000000, 0xbfd16f44
load_data_from_spi_nand_flash(70): 0xbfe01540, 0x00000000, 0xbfe03e18
check_image_header(72): h(69,72,61,6d), s(69,72,61,6d)
img sig ok
rom_progress: 0x0c00006d
load_data_from_spi_nand_flash(81) 0x00000004 0x000024ba
load_data_from_spi_nand_flash(86): 0xbfe01d40, 0x00000001, 0xbfe03e18
load_data_from_spi_nand_flash(86): 0xbfe02540, 0x00000002, 0xbfe03e18
load_data_from_spi_nand_flash(86): 0xbfe02d40, 0x00000003, 0xbfe03e18
load_data_from_spi_nand_flash(86): 0xbfe03540, 0x00000004, 0xbfe03e18
load_data_from_spi_nand_flash(90) read done (size:9402)
chksum ok
rom_progress: 0x0e00006d
load img ok
rom_progress: 0x1000006d
jump 0xbfe01550
Booting...
SPI NAND clock not enable
SPI Nand ID=00efaa21
SPI Nand die chipsize=0x08000000 byte
SPI Nand dienum=1,
SPI Nand blocksize=0x00020000 byte,
SPI Nand pagesize=0x00000800 byte,
SPI Nand oobsize=0x00000040 byte,
[rtkn_scan_bbt, line 1812], RBA=51, this->RBA_PERCENT = 5,block_v2r_num=1024
[rtkn_scan_bbt, line 1822] block_v2r_num 00000400
[rtk_scan_v2r_bbt]:678,RBA=00000033,2=00000400,
[rtk_scan_v2r_bbt]:684,block_v2r_num=000003cd
INFO: Stored BBT in Die 0: block=8 , block_status_p1=0x000000bb
load bbt v2r table:0 page:512
[rtk_scan_v2r_bbt] have created v2r bbt table:0 on block 8, just loads it !!
check v2r bbt table:0 OK
[rtk_nand_scan_bbt, line 393] mem_page_num=1 bbt_page 704
INFO: Stored BBT in Die 0: block=11 , block_status_p1=0x000000bb
load bbt table:0 page:704
TERA上提示的是这些信息。
发表于 2021-3-8 09:31:19 来自手机 | 显示全部楼层
我是来学习的 哈
发表于 2023-10-1 10:19:48 | 显示全部楼层
学习学习
发表于 2024-6-5 14:47:22 | 显示全部楼层
请问现在的固件文件都是zip格式吗?里面有三个文件,看起来应该是无线刷机用的。改文件后缀为uart,导入报错,文件错误。请问有uart文件发布页链接吗?卡了我3天了。。。
发表于 2024-6-5 15:14:42 | 显示全部楼层
连接 UART:
UART Tx <--> TP4 (Gateway Rx)
UART Rx <--> TP11 (Gateway Tx)
UART GND <--> TP8 (Gateway GND)
GMT+8, 2026-1-15 08:36 , Processed in 0.943793 second(s), 11 queries , MemCached On.
