查看: 20742|回复: 9
[求助] 欧瑞博(ORVIBO)门磁SM10ZW接入zigbee2mqtt问题
发表于 2020-12-13 16:48:45 | 显示全部楼层 |阅读模式
上个月在网上买了一批欧瑞博的门磁,型号是SM10ZW,尝试了各种办法无法接入,版本从1.15.0切换到1.16.0再到最新的1.16.2,总是配对失败,其他设备都是没问题的,网上也查了很久,没有找到针对此问题的解决办法。
设备都是全新的,而且卖家也确实都能成功接入,相信不是设备的问题,想请论坛的大佬帮忙看看是哪里的问题
下面是配对失败的日志:
2020-12-13 08:55:15        stdout        Zigbee2MQTT:info  2020-12-13 08:55:15: MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0x00124b000cc9080c","ieee_address":"0x00124b000cc9080c","status":"failed"},"type":"device_interview"}'
2020-12-13 08:55:15        stdout        Zigbee2MQTT:error 2020-12-13 08:55:15: Failed to interview '0x00124b000cc9080c', device has not successfully been paired
2020-12-13 08:55:15        stdout        Zigbee2MQTT:debug 2020-12-13 08:55:15: Skipping message, definition is undefined and still interviewing
2020-12-13 08:55:15        stdout        Zigbee2MQTT:debug 2020-12-13 08:55:15: Received Zigbee message from '0x00124b000cc9080c', type 'readResponse', cluster 'ssIasZone', data '{"zoneState":0}' from endpoint 1 with groupID 0
2020-12-13 08:55:14        stdout        Zigbee2MQTT:debug 2020-12-13 08:55:14: Skipping message, definition is undefined and still interviewing
2020-12-13 08:55:14        stdout        Zigbee2MQTT:debug 2020-12-13 08:55:14: Received Zigbee message from '0x00124b000cc9080c', type 'readResponse', cluster 'genBasic', data '{}' from endpoint 1 with groupID 0
2020-12-13 08:55:14        stdout        Zigbee2MQTT:debug 2020-12-13 08:55:14: Received Zigbee message from '0x00124b000cc9080c', type 'readResponse', cluster 'genBasic', data '{"dateCode":"20151210        "}' from endpoint 1 with groupID 0
2020-12-13 08:55:14        stdout        Zigbee2MQTT:debug 2020-12-13 08:55:14: Received Zigbee message from '0x00124b000cc9080c', type 'readResponse', cluster 'genBasic', data '{"hwVersion":1}' from endpoint 1 with groupID 0
2020-12-13 08:55:13        stdout        Zigbee2MQTT:debug 2020-12-13 08:55:13: Skipping message, definition is undefined and still interviewing
2020-12-13 08:55:13        stdout        Zigbee2MQTT:debug 2020-12-13 08:55:13: Received Zigbee message from '0x00124b000cc9080c', type 'readResponse', cluster 'genBasic', data '{}' from endpoint 1 with groupID 0
2020-12-13 08:55:12        stdout        Zigbee2MQTT:debug 2020-12-13 08:55:12: Skipping message, definition is undefined and still interviewing
2020-12-13 08:55:12        stdout        Zigbee2MQTT:debug 2020-12-13 08:55:12: Received Zigbee message from '0x00124b000cc9080c', type 'readResponse', cluster 'genBasic', data '{"appVersion":"v1.13_20151212\u0000"}' from endpoint 1 with groupID 0
2020-12-13 08:55:12        stdout        Zigbee2MQTT:debug 2020-12-13 08:55:12: Received Zigbee message from '0x00124b000cc9080c', type 'readResponse', cluster 'genBasic', data '{"zclVersion":1}' from endpoint 1 with groupID 0
2020-12-13 08:55:12        stdout        Zigbee2MQTT:debug 2020-12-13 08:55:12: Received Zigbee message from '0x00124b000cc9080c', type 'readResponse', cluster 'genBasic', data '{"powerSource":3}' from endpoint 1 with groupID 0
2020-12-13 08:55:06        stdout        Zigbee2MQTT:debug 2020-12-13 08:55:06: Skipping message, definition is undefined and still interviewing
2020-12-13 08:55:06        stdout        Zigbee2MQTT:debug 2020-12-13 08:55:06: Received Zigbee message from '0x00124b000cc9080c', type 'readResponse', cluster 'genBasic', data '{"manufacturerName":"中性"}' from endpoint 1 with groupID 0
2020-12-13 08:54:48        stdout        Zigbee2MQTT:debug 2020-12-13 08:54:48: Skipping message, definition is undefined and still interviewing
2020-12-13 08:54:48        stdout        Zigbee2MQTT:debug 2020-12-13 08:54:48: Received Zigbee message from '0x00124b000cc9080c', type 'attributeReport', cluster 'genIdentify', data '{"1989":"0x00124b000cc9080c"}' from endpoint 1 with groupID 0
2020-12-13 08:54:47        stdout        Zigbee2MQTT:info  2020-12-13 08:54:47: MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"message":"announce","meta":{"friendly_name":"0x00124b000cc9080c"},"type":"device_announced"}'
2020-12-13 08:54:47        stdout        Zigbee2MQTT:info  2020-12-13 08:54:47: MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0x00124b000cc9080c","ieee_address":"0x00124b000cc9080c"},"type":"device_announce"}'
2020-12-13 08:54:47        stdout        Zigbee2MQTT:debug 2020-12-13 08:54:47: Device '0x00124b000cc9080c' announced itself
2020-12-13 08:54:46        stdout        Zigbee2MQTT:info  2020-12-13 08:54:46: MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"message":"interview_started","meta":{"friendly_name":"0x00124b000cc9080c"},"type":"pairing"}'
2020-12-13 08:54:46        stdout        Zigbee2MQTT:info  2020-12-13 08:54:46: MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"message":{"friendly_name":"0x00124b000cc9080c"},"type":"device_connected"}'
2020-12-13 08:54:46        stdout        Zigbee2MQTT:info  2020-12-13 08:54:46: MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0x00124b000cc9080c","ieee_address":"0x00124b000cc9080c","status":"started"},"type":"device_interview"}'
2020-12-13 08:54:46        stdout        Zigbee2MQTT:info  2020-12-13 08:54:46: MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0x00124b000cc9080c","ieee_address":"0x00124b000cc9080c"},"type":"device_joined"}'
2020-12-13 08:54:46        stdout        Zigbee2MQTT:info  2020-12-13 08:54:46: Starting interview of '0x00124b000cc9080c'
看这几个z2m的版本里都是支持这款门磁的
        zigbeeModel: ['fdd76effa0e146b4bdafa0c203a37192', 'c670e231d1374dbc9e3c6a9fffbd0ae6'],
        model: 'SM10ZW',
        vendor: 'ORVIBO',
        description: 'Door or window contact switch',
        fromZigbee: [fz.ias_contact_alarm_1, fz.battery],
        toZigbee: [],
        exposes: [e.contact(), e.battery_low(), e.tamper(), e.battery()],
 楼主| 发表于 2020-12-13 17:02:35 | 显示全部楼层
对比了卖家那边成功配对的日志,发现有一点差异的地方:
就是他的能收到modelID这条消息,进而识别到SM10ZW的型号信息,我这个不知道为啥一直没看到这条日志
2020-12-02 10:55:39        stdout        Zigbee2MQTT:debug 2020-12-02 10:55:39: No converter available for 'SM10ZW' with cluster 'ssIasZone' and type 'readResponse' and data '{"zoneState":0}'
2020-12-02 10:55:39        stdout        Zigbee2MQTT:debug 2020-12-02 10:55:39: Received Zigbee message from '0x00124b0009fe1224', type 'readResponse', cluster 'ssIasZone', data '{"zoneState":0}' from endpoint 1 with groupID 0
2020-12-02 10:55:38        stdout        Zigbee2MQTT:debug 2020-12-02 10:55:38: No converter available for 'SM10ZW' with cluster 'genBasic' and type 'readResponse' and data '{}'
2020-12-02 10:55:38        stdout        Zigbee2MQTT:debug 2020-12-02 10:55:38: Received Zigbee message from '0x00124b0009fe1224', type 'readResponse', cluster 'genBasic', data '{}' from endpoint 1 with groupID 0
2020-12-02 10:55:38        stdout        Zigbee2MQTT:debug 2020-12-02 10:55:38: No converter available for 'SM10ZW' with cluster 'genBasic' and type 'readResponse' and data '{"dateCode":"20151210        "}'
2020-12-02 10:55:38        stdout        Zigbee2MQTT:debug 2020-12-02 10:55:38: Received Zigbee message from '0x00124b0009fe1224', type 'readResponse', cluster 'genBasic', data '{"dateCode":"20151210        "}' from endpoint 1 with groupID 0
2020-12-02 10:55:38        stdout        Zigbee2MQTT:debug 2020-12-02 10:55:38: No converter available for 'SM10ZW' with cluster 'genBasic' and type 'readResponse' and data '{"hwVersion":1}'
2020-12-02 10:55:38        stdout        Zigbee2MQTT:debug 2020-12-02 10:55:38: Received Zigbee message from '0x00124b0009fe1224', type 'readResponse', cluster 'genBasic', data '{"hwVersion":1}' from endpoint 1 with groupID 0
2020-12-02 10:55:37        stdout        Zigbee2MQTT:debug 2020-12-02 10:55:37: No converter available for 'SM10ZW' with cluster 'genBasic' and type 'readResponse' and data '{}'
2020-12-02 10:55:37        stdout        Zigbee2MQTT:debug 2020-12-02 10:55:37: Received Zigbee message from '0x00124b0009fe1224', type 'readResponse', cluster 'genBasic', data '{}' from endpoint 1 with groupID 0
2020-12-02 10:55:37        stdout        Zigbee2MQTT:debug 2020-12-02 10:55:37: No converter available for 'SM10ZW' with cluster 'genBasic' and type 'readResponse' and data '{"appVersion":"v1.13_20151212\u0000"}'
2020-12-02 10:55:37        stdout        Zigbee2MQTT:debug 2020-12-02 10:55:37: Received Zigbee message from '0x00124b0009fe1224', type 'readResponse', cluster 'genBasic', data '{"appVersion":"v1.13_20151212\u0000"}' from endpoint 1 with groupID 0
2020-12-02 10:55:37        stdout        Zigbee2MQTT:debug 2020-12-02 10:55:37: No converter available for 'SM10ZW' with cluster 'genBasic' and type 'readResponse' and data '{"zclVersion":1}'
2020-12-02 10:55:37        stdout        Zigbee2MQTT:debug 2020-12-02 10:55:37: Received Zigbee message from '0x00124b0009fe1224', type 'readResponse', cluster 'genBasic', data '{"zclVersion":1}' from endpoint 1 with groupID 0
2020-12-02 10:55:37        stdout        Zigbee2MQTT:debug 2020-12-02 10:55:37: No converter available for 'SM10ZW' with cluster 'genBasic' and type 'readResponse' and data '{"powerSource":3}'
2020-12-02 10:55:37        stdout        Zigbee2MQTT:debug 2020-12-02 10:55:37: Received Zigbee message from '0x00124b0009fe1224', type 'readResponse', cluster 'genBasic', data '{"powerSource":3}' from endpoint 1 with groupID 0
2020-12-02 10:55:36        stdout        Zigbee2MQTT:debug 2020-12-02 10:55:36: No converter available for 'SM10ZW' with cluster 'genBasic' and type 'readResponse' and data '{"manufacturerName":"中性"}'
2020-12-02 10:55:36        stdout        Zigbee2MQTT:debug 2020-12-02 10:55:36: Received Zigbee message from '0x00124b0009fe1224', type 'readResponse', cluster 'genBasic', data '{"manufacturerName":"中性"}' from endpoint 1 with groupID 0
2020-12-02 10:55:36        stdout        Zigbee2MQTT:debug 2020-12-02 10:55:36: No converter available for 'SM10ZW' with cluster 'genBasic' and type 'readResponse' and data '{"modelId":"fdd76effa0e146b4bdafa0c203a37192"}'
2020-12-02 10:55:36        stdout        Zigbee2MQTT:debug 2020-12-02 10:55:36: Received Zigbee message from '0x00124b0009fe1224', type 'readResponse', cluster 'genBasic', data '{"modelId":"fdd76effa0e146b4bdafa0c203a37192"}' from endpoint 1 with groupID 0
2020-12-02 10:55:35        stdout        Zigbee2MQTT:debug 2020-12-02 10:55:35: Skipping message, definition is undefined and still interviewing
2020-12-02 10:55:35        stdout        Zigbee2MQTT:debug 2020-12-02 10:55:35: Received Zigbee message from '0x00124b0009fe1224', type 'attributeReport', cluster 'genIdentify', data '{"1989":"0x00124b0009fe1224"}' from endpoint 1 with groupID 0
2020-12-02 10:55:34        stdout        Zigbee2MQTT:info  2020-12-02 10:55:34: MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"message":"announce","meta":{"friendly_name":"0x00124b0009fe1224"},"type":"device_announced"}'
2020-12-02 10:55:34        stdout        Zigbee2MQTT:debug 2020-12-02 10:55:34: Device '0x00124b0009fe1224' announced itself
2020-12-02 10:55:34        stdout        Zigbee2MQTT:info  2020-12-02 10:55:34: MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"message":"interview_started","meta":{"friendly_name":"0x00124b0009fe1224"},"type":"pairing"}'
2020-12-02 10:55:34        stdout        Zigbee2MQTT:info  2020-12-02 10:55:34: MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"message":{"friendly_name":"0x00124b0009fe1224"},"type":"device_connected"}'
2020-12-02 10:55:34        stdout        Zigbee2MQTT:info  2020-12-02 10:55:34: Starting interview of '0x00124b0009fe1224'
发表于 2020-12-13 19:48:08 | 显示全部楼层
我的ORVIBO,能正常接入。多配对几次看看。
 楼主| 发表于 2020-12-13 21:58:59 | 显示全部楼层
从上个月到现在尝试了很多次了,每次都是一样的现象,缺少下面这个数据的上报
不知道是不是我的网关和这个设备的配合有点问题,丢消息了
发表于 2020-12-14 16:58:20 | 显示全部楼层
我用的一批盛世的,会有个别设备这样,没啥好办法 就是重复的配对 配对 再配对
配上了就好了
 楼主| 发表于 2020-12-14 23:09:44 | 显示全部楼层
配上了就好了 ...
好的,感谢指导,我再配对尝试一下
发表于 2020-12-22 15:45:53 | 显示全部楼层
我手头也有几个安居宝的zigbee设备,也是用不了
 楼主| 发表于 2020-12-22 22:25:17 | 显示全部楼层
这个也是尝试了很多次了,就是缺了那一条关键的数据上报,正在考虑换一个网关试试
发表于 2021-5-31 08:33:00 来自手机 | 显示全部楼层
哪里可以买到盛世zigbee门磁呢?
发表于 2023-2-28 01:17:20 | 显示全部楼层
zigbee2mqtt网关接入后原来的面版还能用吗
GMT+8, 2025-12-16 23:15 , Processed in 1.372918 second(s), 6 queries , MemCached On.
