查看: 6966|回复: 4
[已解决] ESP01编译upload出错,小白求教
发表于 2020-12-10 17:55:04 | 显示全部楼层 |阅读模式
esphome:
  platform: ESP8266
  board: esp01_1m
wifi:
  ssid: "SJZN"
  password: "1335588"
  ap:
    ssid: "Bg01 Fallback Hotspot"
    password: "OMfezwCoy6Pd"
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
  password: "1"
ota:
  password: "1"
上面是esphome后台自己生成的,是否还需要改呢?
upload出现如下错误
INFO Reading configuration /config/esphome/bg01.yaml...
INFO Generating C++ source...
INFO Compiling app...
INFO Running:  platformio run -d /config/esphome/bg01
Processing bg01 (board: esp01_1m; framework: arduino; platform: [email protected])
HARDWARE: ESP8266 80MHz, 80KB RAM, 1MB Flash
PACKAGES:
 - framework-arduinoespressif8266 3.20704.0 (2.7.4)
 - tool-esptool 1.413.0 (4.13)
 - tool-esptoolpy 1.20800.0 (2.8.0)
 - toolchain-xtensa 2.40802.200502 (4.8.2)
Dependency Graph
|-- <ESPAsyncTCP-esphome> 1.2.3
|   |-- <ESP8266WiFi> 1.0
|-- <ESP8266mDNS> 1.2
|-- <ESPAsyncWebServer-esphome> 1.2.7
|   |-- <Hash> 1.0
|-- <DNSServer> 1.1.1
Compiling /data/bg01/.pioenvs/bg01/src/main.cpp.o
Linking /data/bg01/.pioenvs/bg01/firmware.elf
Retrieving maximum program size /data/bg01/.pioenvs/bg01/firmware.elf
Building /data/bg01/.pioenvs/bg01/firmware.bin
Checking size /data/bg01/.pioenvs/bg01/firmware.elf
RAM:   [====      ]  44.4% (used 36348 bytes from 81920 bytes)
Flash: [====      ]  38.0% (used 388740 bytes from 1023984 bytes)
Creating BIN file "/data/bg01/.pioenvs/bg01/firmware.bin" using "/root/.platformio/packages/framework-arduinoespressif8266/bootloaders/eboot/eboot.elf" and "/data/bg01/.pioenvs/bg01/firmware.elf"
========================= [SUCCESS] Took 33.32 seconds =========================
INFO Successfully compiled program.
INFO Resolving IP address of bg01.local
ERROR Error resolving IP address of bg01.local. Is it connected to WiFi?
ERROR (If this error persists, please set a static IP address: https://esphome.io/components/wifi.html#manual-ips)
ERROR Error resolving IP address: Error resolving address with mDNS: Did not respond. Maybe the device is offline., [Errno -5] No address associated with hostname
 楼主| 发表于 2020-12-10 17:57:44 | 显示全部楼层
要设置静态地址? 模块还要先联网吗?新手迷糊~~~
 楼主| 发表于 2020-12-10 17:59:23 | 显示全部楼层
PACKAGES:
Dependency Graph
|   |-- <Hash> 1.0
========================= [SUCCESS] Took 14.13 seconds =========================
明白了,不能点upload,要先Compiling
发表于 2020-12-10 18:52:03 | 显示全部楼层
需要mDNS,不支持的要指定ip就可以了
发表于 2020-12-10 23:01:09 | 显示全部楼层
把你的wifi那一行填对再试试
你这一看就不对,,,wifi密码就没有7位数,,必须8位数以上
GMT+8, 2025-12-23 01:19 , Processed in 1.560427 second(s), 6 queries , MemCached On.
