楼主: lidicn
[插件集成] 【真】人格分裂【百度TTS】7种人格可同时出现
发表于 2018-7-18 23:27:08 | 显示全部楼层
马可 一下以后看
发表于 2018-7-19 11:55:45 | 显示全部楼层
厉害了,先回复下看看
发表于 2018-7-27 11:45:12 | 显示全部楼层
学习学习
发表于 2018-7-27 15:27:24 | 显示全部楼层
学习一下
发表于 2018-7-30 13:17:08 | 显示全部楼层
好文章,赶紧学习试一试
发表于 2018-7-30 14:21:19 | 显示全部楼层
唉,给我看,都看不明白
发表于 2018-7-30 14:58:15 | 显示全部楼层
请教一下各位大大,遇到过这种错误码?
  File "/usr/local/lib/python3.6/site-packages/homeassistant/core.py", line 1007, in _event_to_service_call
    await service_handler.func(service_call)
  File "/usr/local/lib/python3.6/site-packages/homeassistant/components/tts/__init__.py", line 134, in async_say_handle
    options=options
  File "/usr/local/lib/python3.6/site-packages/homeassistant/components/tts/__init__.py", line 300, in async_get_url
    engine, key, message, use_cache, language, options)
  File "/usr/local/lib/python3.6/site-packages/homeassistant/components/tts/__init__.py", line 313, in async_get_tts_audio
    message, language, options)
  File "/usr/local/lib/python3.6/asyncio/futures.py", line 332, in __iter__
    yield self  # This tells Task to wait for completion.
  File "/usr/local/lib/python3.6/asyncio/tasks.py", line 250, in _wakeup
    future.result()
  File "/usr/local/lib/python3.6/asyncio/futures.py", line 245, in result
    raise self._exception
  File "/usr/local/lib/python3.6/concurrent/futures/thread.py", line 55, in run
  File "/usr/local/lib/python3.6/site-packages/homeassistant/components/tts/baidu.py", line 136, in get_tts_audio
    message, language, 1, speech_data
  File "/usr/local/lib/python3.6/site-packages/aip/speech.py", line 92, in synthesis
    result = self._request(self.__ttsUrl, data)
  File "/usr/local/lib/python3.6/site-packages/aip/base.py", line 91, in _request
    authObj = self._auth()
  File "/usr/local/lib/python3.6/site-packages/aip/base.py", line 167, in _auth
    ), proxies=self._proxies).json()
  File "/usr/local/lib/python3.6/site-packages/requests/sessions.py", line 521, in get
    return self.request('GET', url, **kwargs)
  File "/usr/local/lib/python3.6/site-packages/requests/sessions.py", line 508, in request
    resp = self.send(prep, **send_kwargs)
  File "/usr/local/lib/python3.6/site-packages/requests/sessions.py", line 618, in send
    r = adapter.send(request, **kwargs)
  File "/usr/local/lib/python3.6/site-packages/requests/adapters.py", line 502, in send
    raise ProxyError(e, request=request)
requests.exceptions.ProxyError: HTTPSConnectionPool(host='aip.baidubce.com', port=443): Max retries exceeded with url: /oauth/2.0/token?grant_type=client_credentials&client_id=HhuDCIKXfzPE1SXO8&client_secret=26VzFHAfXNL1A7HLFG9v0Ym6OoBQ2 (Caused by ProxyError('Cannot connect to proxy.', NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x7fc9019042b0>: Failed to establish a new connection: [Errno 111] Connection refused',)))
2018-07-30 14:49:14 ERROR (MainThread) [homeassistant.core] Error executing service <ServiceCall tts.baidu_say: message=我是中国人民解放军>
  File "/usr/local/lib/python3.6/site-packages/urllib3/connection.py", line 141, in _new_conn
    (self.host, self.port), self.timeout, **extra_kw)
  File "/usr/local/lib/python3.6/site-packages/urllib3/util/connection.py", line 83, in create_connection
    raise err
  File "/usr/local/lib/python3.6/site-packages/urllib3/util/connection.py", line 73, in create_connection
    sock.connect(sa)
ConnectionRefusedError: [Errno 111] Connection refused
发表于 2018-8-2 07:23:26 | 显示全部楼层
学习了 谢谢楼主
发表于 2018-8-5 16:27:01 | 显示全部楼层
看看大神帖子
发表于 2018-8-10 20:30:40 | 显示全部楼层
不选人格可以播放吗
GMT+8, 2026-1-15 07:52 , Processed in 0.248771 second(s), 10 queries , MemCached On.
