查看: 11459|回复: 6
[求助] hassos中如何和nodered联动或者说创建custom_components
发表于 2020-12-10 10:04:20 | 显示全部楼层 |阅读模式
nodered中的sensor信息到ha中,提示Attention: This node requires Node-RED custom integration to be installed in Home Assistant for it to function.
Installation
This integration is available in [color=var(--color-text-link)]HACS (Home Assistant Community Store)
  • Using the tool of choice open the directory (folder) for your HA configuration (where you find configuration.yaml).
  • If you do not have a custom_components directory (folder) there, you need to create it.
  • In the custom_components directory (folder) create a new folder called nodered.
  • Download all the files from the custom_components/nodered/ directory (folder) in this repository.
  • Place the files you downloaded in the new directory (folder) you created.
  • Restart Home Assistant
  • In the HA UI go to "Configuration" -> "Integrations" click "+" and search for "Node-RED"
我再config下面创建了custom_components,并把相关的文件都放到这个文件夹中了,就是第一步不知道在configuration中需要如何修改,是加一个nodered:  ?  但是重启后HA中的集成还是搜不到nodered
日志提示如下错误:
Logger: homeassistant.components.websocket_api.http.connection.140612763282352
Source: components/websocket_api/connection.py:84
Integration: Home Assistant WebSocket API ([color=var(--primary-color)]documentation
, [color=var(--primary-color)]issues
First occurred: 下午12:46:28 (3 occurrences)
Last logged: 下午12:46:29
Received invalid command: nodered/version
发表于 2020-12-10 11:08:16 | 显示全部楼层
集成里怎么可能有nodered nodered不是插件,而是一个addon
 楼主| 发表于 2020-12-10 11:56:34 | 显示全部楼层
addon在哪里。。
实体注册表也没有
 楼主| 发表于 2020-12-10 12:49:14 | 显示全部楼层
Integration: Home Assistant WebSocket API (documentation, issues)
 楼主| 发表于 2020-12-10 13:28:09 | 显示全部楼层
搞定了。。原来要在集成那边手动添加下
007 手机认证
发表于 2021-1-21 10:13:39 | 显示全部楼层
guitengyue 发表于 2020-12-10 13:28
搞定了。。原来要在集成那边手动添加下
怎么手动添加?
 楼主| 发表于 2021-1-21 11:42:11 | 显示全部楼层
007 发表于 2021-1-21 10:13
怎么手动添加?
集成那边手动添加一下,右下角有一个+号
GMT+8, 2025-12-23 03:28 , Processed in 0.252057 second(s), 12 queries , MemCached On.
