查看: 26800|回复: 21
[进阶教程] 在Orange Pi Zero上安装Home Assistant
发表于 2017-5-14 12:58:36 | 显示全部楼层 |阅读模式
这个教程是关于如何在Orange Pi Zero上安装Home Assistant。就像在Raspberry Pi Zero上的设置一样简单,只需要几分钟的时间就能得到很便宜的HASS网关
下载Armbian并用Etcher创建SD卡。
然后通过有线网络设置。
在Orange Pi Zero运行后,等系统启动,并通过Fing等工具获取其IP地址。主机名是orangepizero。
通过得到的IP地址,使用SSH客户端连接到Orange Pi Zero。默认密码为1234。
$ ssh [email protected]
[email protected]'s password:
You are required to change your password immediately (root enforced)
  ___                               ____  _   _____
 / _ \ _ __ __ _ _ __   __ _  ___  |  _ \(_) |__  /___ _ __ ___
| | | | '__/ _` | '_ \ / _` |/ _ \ | |_) | |   / // _ \ '__/ _ \
| |_| | | | (_| | | | | (_| |  __/ |  __/| |  / /|  __/ | | (_) |
 \___/|_|  \__,_|_| |_|\__, |\___| |_|   |_| /____\___|_|  \___/
                       |___/
Welcome to ARMBIAN 5.27.170514 nightly Ubuntu 16.04.2 LTS 4.11.0-sun8i
System load:   0.86 0.35 0.13          Up time:       9 min
Memory usage:  5 % of 496MB          IP:            192.168.0.151
CPU temp:      39°C
Usage of /:    16% of 7.1G
[ General system configuration: armbian-config ]
New to Armbian? Check the documentation first: https://docs.armbian.com
Changing password for root.
(current) UNIX password:
Enter new UNIX password:
Retype new UNIX password:
You are using Armbian nightly build.
It is provided AS IS with NO WARRANTY and NO END USER SUPPORT.
Creating a new user account. Press <Ctrl-C> to abort
Please provide a username (eg. your forename): ha
Trying to add user ha
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
        LANGUAGE = "en_US.UTF-8",
        LC_ALL = (unset),
        LC_PAPER = "de_CH.UTF-8",
        LC_MONETARY = "de_CH.UTF-8",
        LC_NUMERIC = "de_CH.UTF-8",
        LC_MESSAGES = "en_US.UTF-8",
        LC_MEASUREMENT = "de_CH.UTF-8",
        LC_TIME = "de_CH.UTF-8",
        LANG = "en_US.UTF-8"
    are supported and installed on your system.
perl: warning: Falling back to a fallback locale ("en_US.UTF-8").
Adding user `ha' ...
Adding new group `ha' (1000) ...
Adding new user `ha' (1000) with group `ha' ...
Creating home directory `/home/ha' ...
Copying files from `/etc/skel' ...
passwd: password updated successfully
Changing the user information for ha
Enter the new value, or press ENTER for the default
        Full Name []: homeassistant
        Room Number []:
        Work Phone []:
        Home Phone []:
        Other []:
Is the information correct? [Y/n] y
Dear homeassistant, your account ha has been created and is sudo enabled.
Please use this account for your daily work from now on.
root@orangepizero:~#
获取更新软件包
root@orangepizero:~# apt-get update
Hit:1 http://ports.ubuntu.com xenial InRelease
Get:2 http://ports.ubuntu.com xenial-security InRelease [102 kB]
Hit:3 http://beta.armbian.com xenial InRelease
Get:4 http://ports.ubuntu.com xenial-updates InRelease [102 kB]
Get:5 http://ports.ubuntu.com xenial-backports InRelease [102 kB]
Get:6 http://ports.ubuntu.com xenial-updates/main armhf Packages [479 kB]
Get:7 http://ports.ubuntu.com xenial-updates/universe armhf Packages [419 kB]
Fetched 1205 kB in 7s (158 kB/s)
Reading package lists... Done
运行升级,以确保所有可用的包是最新的。
root@orangepizero:~# apt-get upgrade
安装家庭助理的依赖
root@orangepizero:~# apt-get install python3-dev python3-pip python3-venv
安装Home Assistant的步骤也在文档和指南中venv进行了介绍。切换到创建用户ha,并执行其余的安装步骤,减少到以下:
ha@orangepizero:~$ pyvenv-3.5 homeassistant
ha@orangepizero:~$ cd homeassistant && source bin/activate
(homeassistant) ha@orangepizero:~/homeassistant$ pip3 install --upgrade pip
(homeassistant) ha@orangepizero:~/homeassistant$ pip3 install homeassistant
(homeassistant) ha@orangepizero:~/homeassistant$ hass
为了日常使用,加入init.d或systemd自启动即可,加入方法在老高和八哥的教程里有,在这里不在赘述
wqqs 手机认证
活跃会员
发表于 2017-5-14 13:39:11 来自手机 | 显示全部楼层
谢谢分享!!!
发表于 2017-5-14 14:45:39 来自手机 | 显示全部楼层
拿分走人^_^^_^
活跃会员
发表于 2017-5-14 15:16:01 | 显示全部楼层
准备入手一个研究研究
发表于 2017-5-14 20:31:17 | 显示全部楼层
谢谢分享!!!!!!
soc
发表于 2017-5-15 16:19:19 | 显示全部楼层
wqqs 发表于 2017-5-14 13:39
谢谢分享!!!
谢谢分享!!群友支持大神!
发表于 2017-5-16 10:43:55 | 显示全部楼层
成本大大降低
PAUL 手机认证
发表于 2017-5-16 13:40:10 | 显示全部楼层
安装之后,每次重启orange pi的IP地址都不一样,为啥?
发表于 2017-5-17 14:00:27 | 显示全部楼层
两个办法
1、在主路由里给orangePi分配固定ip
2、在orangePi里配置固定ip
推荐方法1
PAUL 手机认证
发表于 2017-5-17 14:12:43 | 显示全部楼层
阿东 发表于 2017-5-17 14:00
两个办法
分配过了,奇怪的是每次MAC地址也跟着变。。
GMT+8, 2026-1-18 02:01 , Processed in 0.179719 second(s), 10 queries , MemCached On.
