查看: 7014|回复: 3
[已解决] homekit里只有网关灯,不显示传感器
发表于 2017-9-10 21:15:14 | 显示全部楼层 |阅读模式
安装hassbian,然后将二代网关接入HA,但是homekit中只显示网关灯,不显示人体传感器、温湿度传感器。。但HASS里有。
已经解决,忘记在HB-HA插件config.json中"supported_types"添加 "binary_sensor", "sensor",真是大失误,哈哈哈。。感谢myron412
configuration.yaml配置文件
homeassistant:
  # Name of the location where Home Assistant is running
  # Location required to calculate the time the sun rises and sets
  latitude: 36.68524
  longitude: 117.1772
  # Impacts weather/sunrise data (altitude above sea level in meters)
  elevation: 93
  # metric for Metric, imperial for Imperial
  unit_system: metric
  # Pick yours from here: [url=http://en.wikipedia.org/wiki/List_of_tz_database_time_zones]http://en.wikipedia.org/wiki/List_of_tz_database_time_zones[/url]
  time_zone: Asia/Shanghai
  # Customization file
  customize: !include customize.yaml
# Show links to resources in log and frontend
introduction:
# Enables the frontend
frontend:
# Enables configuration UI
config:
http:
  # Uncomment this to add a password (recommended!)
  # api_password: PASSWORD
  # Uncomment this if you are using SSL/TLS, running in Docker container, etc.
  # base_url: example.duckdns.org:8123
# Checks for available updates
# Note: This component will send some information about your system to
# the developers to assist with development of Home Assistant.
# For more information, please see:
# [url=https://home-assistant.io/blog/2016/10/25/explaining-the-updater/]https://home-assistant.io/blog/2016/10/25/explaining-the-updater/[/url]
updater:
  # Optional, allows Home Assistant developers to focus on popular components.
  # include_used_components: true
# Discover some devices automatically
discovery:
# Allows you to issue voice commands from the frontend in enabled browsers
conversation:
# Enables support for tracking state changes over time
history:
# View all events in a logbook
logbook:
# Track the sun
sun:
# Weather prediction
  - platform: yr
# Text to speech
tts:
  - platform: google
group: !include groups.yaml
script: !include scripts.yaml
xiaomi:
  gateways:
      - mac: F0B429CC08E9
        key: 93945111658C425B
light:
  - platform: yeelight
    devices:
      192.168.50.100:
        name: Living Room 2
        transition: 1000
        save_on_change: True
customize.yaml配置文件
binary_sensor.motion_sensor_158d000171bd41:
  friendly_name: 客厅人体感应器
  homebridge_hidden: false
light.gateway_light_f0b429cc08e9:
  friendly_name: 客厅小夜灯
light.living_room_2:
  friendly_name: 卧室吸顶灯
sensor.humidity_158d00016feb03:
  friendly_name: 客厅湿度
sensor.temperature_158d00016feb03:
  friendly_name: 客厅温度
config.json配置文件
    "bridge": {
        "name": "Homebridge",
        "username": "B8:27:EB:FD:0C:42",
        "port": 51826,
        "pin": "123-45-678"
    "platforms": [
    "platform": "HomeAssistant",
    "name": "HomeAssistant",
    "host": "http://192.168.50.65:8123",
    "password": "147159123",
    "supported_types": ["fan", "garage_door", "input_boolean", "light", "lock", "media_player", "rollershutter", "scene",$
    "default_visibility":"visible"
log
2017-09-10 12:16:51 ERROR (Thread-11) [homeassistant.components.light.yeelight] Unable to update bulb status: Bulb closed the connection.
2017-09-10 12:17:13 WARNING (Thread-2) [netdisco.ssdp] Error fetching description at 192.168.50.164
2017-09-10 12:18:20 ERROR (Thread-7) [homeassistant.components.light.yeelight] Flash supported currently only in RGB mode.
2017-09-10 12:43:46 ERROR (MainThread) [homeassistant.core] Error doing job: Fatal read error on socket transport
  File "/usr/lib/python3.4/asyncio/selector_events.py", line 582, in _read_ready
    data = self._sock.recv(self.max_size)
TimeoutError: [Errno 110] Connection timed out
发表于 2017-9-10 21:57:47 | 显示全部楼层
看不懂,一起学习。你看看在配置文件里每个传感器下的homebridge_hidden: false是不是false?
发表于 2017-9-11 02:16:47 | 显示全部楼层
研究了下,应该是缺少插件或则config.json里缺少功能配置导致,具体怎么解决看大神的吧
 楼主| 发表于 2017-9-11 07:16:20 | 显示全部楼层
myron412 发表于 2017-9-11 02:16
研究了下,应该是缺少插件或则config.json里缺少功能配置导致,具体怎么解决看大神的吧 ...
非常感谢您那么晚还一直帮我研究。。我也找到了,复制代码时,忘了在home bridge的config.json中"supported_types"添加 "binary_sensor", "sensor",那肯定就没有啦,谢谢!
GMT+8, 2025-12-25 15:53 , Processed in 0.440029 second(s), 9 queries , MemCached On.
