查看: 6311|回复: 3
[求助] 群晖docker zigbee2mqtt 无法启动,求助
发表于 2020-11-22 13:17:44 | 显示全部楼层 |阅读模式
日志如下:
date        stream        content
2020-11-22 05:06:06        stdout
2020-11-22 05:06:05        stdout        npm ERR!     /root/.npm/_logs/2020-11-22T05_06_05_694Z-debug.log
2020-11-22 05:06:05        stdout        npm ERR! A complete log of this run can be found in:
2020-11-22 05:06:05        stdout        npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
2020-11-22 05:06:05        stdout        npm ERR! Failed at the [email protected] start script.
2020-11-22 05:06:05        stdout        npm ERR! Exit status 1
2020-11-22 05:06:05        stdout        npm ERR! [email protected] start: `node index.js`
2020-11-22 05:06:05        stdout        npm ERR! errno 1
2020-11-22 05:06:05        stdout        npm ERR! code ELIFECYCLE
2020-11-22 05:06:05        stdout            at /app/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:242:12
2020-11-22 05:06:05        stdout            at SerialPort._error (/app/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:198:14)
2020-11-22 05:06:05        stdout            at SerialPort.<anonymous> (/app/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:134:49)
2020-11-22 05:06:05        stdout            at __awaiter (/app/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:23:12)
2020-11-22 05:06:05        stdout            at new Promise (<anonymous>)
2020-11-22 05:06:05        stdout            at /app/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:27:71
2020-11-22 05:06:05        stdout            at Generator.next (<anonymous>)
2020-11-22 05:06:05        stdout            at Znp.<anonymous> (/app/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:136:32)
2020-11-22 05:06:05        stdout        Zigbee2MQTT:error 2020-11-22 05:06:05: Error: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM0'
2020-11-22 05:06:05        stdout        Zigbee2MQTT:error 2020-11-22 05:06:05: Exiting...
2020-11-22 05:06:05        stdout        Zigbee2MQTT:error 2020-11-22 05:06:05: Failed to start zigbee
2020-11-22 05:06:05        stdout        Zigbee2MQTT:error 2020-11-22 05:06:05: Error while starting zigbee-herdsman
2020-11-22 05:06:04        stdout        Zigbee2MQTT:info  2020-11-22 05:06:04: Starting zigbee-herdsman...
2020-11-22 05:06:04        stdout        Zigbee2MQTT:info  2020-11-22 05:06:04: Starting Zigbee2MQTT version 1.16.1 (commit #6b32f30)
2020-11-22 05:06:04        stdout        Zigbee2MQTT:info  2020-11-22 05:06:04: Logging to console and directory: '/app/data/log/2020-11-22.05-06-03' filename: log.txt
2020-11-22 05:06:02        stdout
2020-11-22 05:06:02        stdout        > node index.js
2020-11-22 05:06:02        stdout        > [email protected] start /app
2020-11-22 05:05:58        stdout        Creating configuration file...
2020-11-22 05:05:58        stdout        Using '/app/data' as data directory
zkxa 手机认证
发表于 2021-1-19 11:26:49 | 显示全部楼层
你解决没,,我的好像也是这样的。
发表于 2021-1-30 23:29:08 | 显示全部楼层
这个错误一般来说是没改默认配置,server找不到串口
发表于 2021-1-31 00:16:56 | 显示全部楼层
zigbee2mqtt的configuration.yaml中有添加以下代码吗
homeassistant: true
permit_join: true
mqtt:
  base_topic: zigbee2mqtt
  server: 'mqtt://192.168.0.200:1883'
  user: mqtt的用户名
  password: mqtt的密码
serial:
  port: /dev/ttyACM0
GMT+8, 2025-12-22 23:13 , Processed in 0.050718 second(s), 9 queries , MemCached On.
