查看: 7969|回复: 7
[已解决] 设置了custom ui chrome下显示空白
发表于 2017-9-9 14:17:24 | 显示全部楼层 |阅读模式
chrome 下显示空白  firefox显示正常!大家有这个情况吗?
解决了 !浏览器的问题。 作者也更新了  附上我测试的配置
homeassistant:
  # Name of the location where Home Assistant is running
  # Location required to calculate the time the sun rises and sets
  latitude: 23.1167
  longitude: 113.25
  # Impacts weather/sunrise data (altitude above sea level in meters)
  elevation: 14
  # metric for Metric, imperial for Imperial
  unit_system: metric
  # Pick yours from here: [url=http://en.wikipedia.org/wiki/List_of_tz_database_time_zones]http://en.wikipedia.org/wiki/List_of_tz_database_time_zones[/url]
  time_zone: Asia/Shanghai
  customize: !include customized.yaml
  customize_glob:
      custom_ui_state_card: custom-ui
    group.a:
      state_card_mode: badges
    group.my_group:
      badges_list:
        - sensor.aqi_pm25
        - sensor.aqi_qlty
    sensor.aqi_pm25:
       group:
         group.my_group:
           hidden: true
    sensor.aqi_qlty:
       group:
         group.my_group:
           hidden: true
customizer:
  panel: true
  hide_customui_attributes: false
  hide_attributes:
    - node_id
    - value_index
# Show links to resources in log and frontend
introduction:
# Enables the frontend
frontend:
# Enables configuration UI
config:
http:
  # Uncomment this to add a password (recommended!)
  # api_password: PASSWORD
  # Uncomment this if you are using SSL/TLS, running in Docker container, etc.
  # base_url: example.duckdns.org:8123
# Checks for available updates
# Note: This component will send some information about your system to
# the developers to assist with development of Home Assistant.
# For more information, please see:
# [url=https://home-assistant.io/blog/2016/10/25/explaining-the-updater/]https://home-assistant.io/blog/2016/10/25/explaining-the-updater/[/url]
updater:
  # Optional, allows Home Assistant developers to focus on popular components.
  # include_used_components: true
# Discover some devices automatically
discovery:
# Allows you to issue voice commands from the frontend in enabled browsers
conversation:
# Enables support for tracking state changes over time
history:
# View all events in a logbook
logbook:
# Track the sun
sun:
# Weather prediction
sensor: !include sensor.yaml
# Text to speech
tts:
  - platform: google
group:
  a:
    control: hidden
    entities:
      - sensor.1hour_pop
      - sensor.1hour_weather
  b:
    entities:
      - group.a
      - sensor.aqi_qlty
  my_group:
    entities:
      - sensor.aqi_pm25
      - sensor.aqi_qlty
      - group.my_group
script: !include scripts.yaml
发表于 2017-9-12 00:22:20 | 显示全部楼层
对的,要激活下才能用。不然就是空白。你应该是激活了。
soso
发表于 2017-9-20 16:54:08 | 显示全部楼层
我也遇到这个问题,这里激活是指激活哪里,怎么激活,谢谢
soso
发表于 2017-9-20 16:55:40 | 显示全部楼层
可以怎么设置~~
发表于 2018-1-16 18:46:49 | 显示全部楼层
同求,如何激活
 楼主| 发表于 2018-1-19 11:27:04 | 显示全部楼层
customize_glob:
      custom_ui_state_card: custom-ui   全局激活
发表于 2018-4-24 19:03:38 | 显示全部楼层
楼主你的坐标就在我附近
 楼主| 发表于 2018-4-26 10:16:30 | 显示全部楼层
这么近
GMT+8, 2025-12-25 03:55 , Processed in 0.413823 second(s), 7 queries , MemCached On.
