查看: 6105|回复: 4
ESP8266刷入ESPEasy 后无法连接 homeassistant的mqtt服务器
发表于 2020-11-5 10:50:58 | 显示全部楼层 |阅读模式
------------homeassistant的温度显示无法同步esp8266,但是我可以使用手机端的mqttclient模拟mqtt发送信息,可以使homeassistant上数值改变,因此我怀疑是ESP8266没有连接homeassistant,跪求大佬帮我解决--------------------
 楼主| 发表于 2020-11-5 10:52:14 | 显示全部楼层
------------------homeassistant的配置文件---------
mqtt:
  broker: 192.168.31.119
  port: 1883
  username: pi
  password: 123
  discovery: true
switch:
   - platform: mqtt
     state_topic: "/ESP3/deng/Switch"
     command_topic: "/ESP3/GPIO/13"
     payload_on: "1"
     payload_off: "0"
     qos: 0
     retain: true
   - platform: mqtt
     state_topic: "/ESP3/wen/Temperature"
     qos: 0
     unit_of_measurement: "℃"
   - platform: mqtt
     state_topic: "/ESP3/wen/Humidity"
     qos: 0
     unit_of_measurement: "%"
 楼主| 发表于 2020-11-5 10:56:31 | 显示全部楼层
 楼主| 发表于 2020-11-5 11:50:06 | 显示全部楼层
ms2 手机认证
发表于 2020-11-5 18:12:02 | 显示全部楼层
刷esphome多好呀,直接API通信,不需要MQTT。
GMT+8, 2025-12-30 04:09 , Processed in 0.981006 second(s), 21 queries , MemCached On.
