查看: 15356|回复: 6
[求助] 温湿度传感器天猫精灵无法读取问题
发表于 2020-11-1 10:27:54 | 显示全部楼层 |阅读模式
根据囧大神的帖子:传送门
接入了天猫精灵,接入步骤:
1:将灯,温湿度传感器等设备接入ha
2:在configuration.yaml的同一目录创建customize.yaml文件,在configuration.yaml文件中添加如下配置
homeassistant:
  customize: !include customize.yaml
customize.yaml内容如下,
light.rgblighta4cf12efbd20:
  friendly_name: 灯
  tmall_genie: true
sensor.temperatureraspberrypi:
  friendly_name: 温度
  tmall_genie:
    enabled: true
    attach_sensor:
      - entity_id: sensor.temperatureraspberrypi001
sensor.humidityraspberrypi:
  friendly_name: 湿度
  tmall_genie:
    enabled: true
    attach_sensor:
      - entity_id: sensor.humidityraspberrypi001
3:  让ha可以外网访问
4:生成长token
5:访问此链接填入论坛账号绑定的邮箱和ha外网地址,点击登录,跳转到ha登录页面,登录成功后,根据提示填写邮箱地址,ha外网地址,和长令牌
6:打开自己的天猫精灵APP,在添加设备页面搜索HASSMART,然后点击其中任意一个设备,然后点击下边的同步设备,就能看到设备
7:默认只能集成一个设备,需要在回复教程贴申请提升接入数量,申请通过后可接入三个。
今天天猫精灵接入设备数量权限终于开放了。
但是我的温湿度传感器天猫精灵无法读取,每次问天猫精灵都传感器无法获取温湿度数据。
我是通过python脚本获取的温湿度数据然后通过mqtt接入的,Python脚本如下
import paho.mqtt.client as mqtt
import time
import Adafruit_DHT
# 设置传感器类型
sensor=Adafruit_DHT.DHT11
# 设置GPIO引脚
gpio=17
# mqtt客户端
client = mqtt.Client()
# 链接上服务器后回调
def on_connect(client, userdata, flags, rc):
  print(f"Connected with result code {rc}")
# 设置链接成功后回调
client.on_connect = on_connect
# 链接mqtt服务器
client.connect("localhost", 1883, 60)
time.sleep(1)
# 注册温度传感器设备
client.publish('homeassistant/sensor/temperatureraspberrypi/config', payload='{"name":"temperatureraspberrypi","unique_id":"temperatureraspberrypi","state_topic":"dht11/state/dht11raspberrypi","value_template":"{{value_json.temperature}}","device_class":"temperature","unit_of_measurement":"°C"}', qos=0, retain=True)
# 注册湿度传感器设备
client.publish('homeassistant/sensor/humidityraspberrypi/config', payload='{"name":"humidityraspberrypi","unique_id":"humidityraspberrypi","state_topic":"dht11/state/dht11raspberrypi","value_template":"{{value_json.humidity}}","device_class":"humidity","unit_of_measurement":"%"}', qos=0, retain=True)
time.sleep(60)
while True:
  # 读取温度与湿度
  humidity, temperature = Adafruit_DHT.read_retry(sensor, gpio)
  # 要发送的json字符串
  payloadStr='{"temperature":"'+str(temperature)+'","humidity":"'+str(humidity)+'"}'
  print(payloadStr)
  client.loop(3)
  # 发送到mqtt
  client.publish('dht11/state/dht11raspberrypi', payload=payloadStr, qos=0, retain=True)
  time.sleep(60)
已经可以正常接入ha,也可以正常显示,也接入了天猫精灵,但是就是天猫精灵无法读取。请指点
发表于 2020-11-1 15:36:12 | 显示全部楼层
ha里怎么配置的?
发表于 2020-11-1 16:49:17 | 显示全部楼层
重点在你怎接的天猫精灵你没讲清楚呢
 楼主| 发表于 2020-11-1 17:13:21 | 显示全部楼层
囧 发表于 2020-11-1 15:36
ha里怎么配置的?
通过MQTT集成进去的,MQTT开启自动发现,通过向 homeassistant/sensor/temperatureraspberrypi/config主题发送一下内容集成温度传感器
像 homeassistant/sensor/humidityraspberrypi/config主题发送以下内容集成湿度传感器
customize.yaml 配置内容如下
  friendly_name: 灯
  tmall_genie: true
  friendly_name: 温度
  tmall_genie:
    enabled: true
    attach_sensor:
  friendly_name: 湿度
  tmall_genie:
    enabled: true
    attach_sensor:
 楼主| 发表于 2020-11-1 17:16:22 | 显示全部楼层
25989406 发表于 2020-11-1 16:49
重点在你怎接的天猫精灵你没讲清楚呢
根据囧大神的教程:https://bbs.hassbian.com/forum.p ... B%E7%B2%BE%E7%81%B5
发表于 2020-11-2 19:40:18 | 显示全部楼层
1.注意你的问法    客厅传感器的温度是多少
2.还不行那就认真看下他写的教程:
1.4 Customize高级设置
由于天猫精灵官方不支持同一位置多传感器,本技能通过高级设置可以达到虚拟传感器效果。具体代码如下
 楼主| 发表于 2020-11-4 20:53:58 | 显示全部楼层
检查了配置应该都正确,还是不行,所有配置都贴出来了,麻烦大神给看一下
GMT+8, 2025-12-23 03:24 , Processed in 0.382448 second(s), 13 queries , MemCached On.
