查看: 17760|回复: 1
[求助] Error while setting up vlc platform for media_player
发表于 2020-10-31 17:45:00 | 显示全部楼层 |阅读模式
环境:
服务器:VMware创建的虚拟机 Centos7
Docker:19.03.13
HomeAssistant:0.116.4
HomeAssistant部署在Docker上
已经在服务器上安装好了VLC,并且可以正常播放
configuration.yaml配置
media_player:
  - platform: vlc
异常信息
ERROR (MainThread) [homeassistant.components.media_player] Error while setting up vlc platform for media_player
  File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 193, in _async_setup_platform
    await asyncio.shield(task)
  File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run
  File "/usr/src/homeassistant/homeassistant/components/vlc/media_player.py", line 46, in setup_platform
    [VlcDevice(config.get(CONF_NAME, DEFAULT_NAME), config.get(CONF_ARGUMENTS))]
  File "/usr/src/homeassistant/homeassistant/components/vlc/media_player.py", line 55, in __init__
    self._instance = vlc.Instance(arguments)
  File "/usr/local/lib/python3.8/site-packages/vlc.py", line 1551, in __new__
    return libvlc_new(len(args), args)
  File "/usr/local/lib/python3.8/site-packages/vlc.py", line 3902, in libvlc_new
    _Cfunction('libvlc_new', ((1,), (1,),), class_result(Instance),
  File "/usr/local/lib/python3.8/site-packages/vlc.py", line 246, in _Cfunction
    raise NameError('no function %r' % (name,))
NameError: no function 'libvlc_new'
发表于 2021-3-20 17:03:24 | 显示全部楼层
请问一下,你解决问题了吗?求分享
GMT+8, 2025-12-22 21:15 , Processed in 0.308043 second(s), 17 queries , MemCached On.
