查看: 17132|回复: 11
[求助] ESPHOME配置代码求助!!!求大神帮忙
发表于 2020-10-30 16:59:56 | 显示全部楼层 |阅读模式
需求保证所有开关在7:30-23:30之间开,其余时间是关闭的模块由于偶尔有时候自己会重启,导致大半夜的开关打开了,此处想加个模块启动比对时间决定开关的状态
以下附上代码
对于lambda实在无能为力,求助求助
esphome:
  platform: esp8266
  board: d1_mini
  esp8266_restore_from_flash: true
  on_boot:
    priority: -10
    then:
      if:
        condition:
          lambda: |-
            //此处需要判断系统时间是否在7:30至23:30之间,求大神帮忙
        then:
          - switch.turn_on: switch86
          - switch.turn_on: switch55
          - switch.turn_on: switchbeiyong
        else:
          - switch.turn_off: switch86
          - switch.turn_off: switch55
          - switch.turn_off: switchbeiyong
wifi:
  ssid: "ZZCJ-Power"
  password: "我是密码"
  reboot_timeout: 60s
  manual_ip:
    static_ip: 10.16.9.10
    gateway: 10.16.8.5
    subnet: 255.255.252.0
    dns1: 222.246.129.80
    dns2: 114.114.114.114
# Enable logging
logger:
# Enable Home Assistant API
api:
  password: "我是密码"
  reboot_timeout: 0s
ota:
  safe_mode: True
  password: "我是密码"
time:
  - platform: homeassistant
    timezone: Asia/Shanghai
    on_time:
      - seconds: 0
        minutes: 0
        hours: 7
        then:
      - seconds: 0
        minutes: 30
        hours: 23
        then:
web_server:
  port: 80
  auth:
    username: admin
    password: 我是密码
output:
  - platform: gpio
    pin: 14
  - platform: gpio
    pin: 13
  - platform: gpio
    pin: 15
switch:
  - platform: output
    name: "test switch86"
    output: 'testswitch86'
    inverted: true
  - platform: output
    name: "test switch55"
    output: 'testswitch55'
    inverted: true
  - platform: output
    name: "test switchbeiyong"
    output: 'testswitchbeiyong'
    inverted: true
  - platform: restart
  - platform: gpio
    pin: 14
    restore_mode: ALWAYS_ON
  - platform: gpio
    pin: 13
  - platform: gpio
    pin: 15
  - platform: wifi_signal
    update_interval: 5s
  - platform: uptime
    name: test Uptime Sensor
    update_interval: 5s
发表于 2020-10-30 17:34:04 | 显示全部楼层
好复杂,你设置一个 binary_sensor 开关
然后所有的开关开之前,都要检查这个开关是ON 还是OFF,on就执行,off 就不执行
然后用time 来触发,当时间是 7:30 就把这个 binary_sensor 设置成 on
23:30 之后就把这个 binary_sensor  设置成off 不就行了?
另外贴代码的时候记得把密码隐去,我看你密码有电话号码,保护下自己隐私,被社工就不好。
发表于 2020-10-30 17:37:43 | 显示全部楼层
关于定时,不需要全局,开写一个时间传感器就好了
time:
## +08区时间
  - platform: sntp
    servers:
      - 0.pool.ntp.org
      - 1.pool.ntp.org
      - 2.pool.ntp.org
    timezone: Asia/Shanghai  ## UTC0
    on_time:
    # Every morning on weekdays
    # 8点45执行自动化
      - seconds: 0
        minutes: 45
        hours: 20
        # days_of_week: MON-SAT
        then:
          - script.execute: timing_01
 楼主| 发表于 2020-10-30 19:34:19 | 显示全部楼层
然后所有的开关开之前,都要检查这个开关是ON 还是OFF,on就执行 ...
非常感谢将隐私去掉了,上传直接复制了,忘记修改
可是一旦模块重启不管是binary_sensor还是switch的最后状态都会丢失吧,全部恢复到初始状态
 楼主| 发表于 2020-10-30 19:36:06 | 显示全部楼层
on_time只会在经过这个时间点的时候才能起作用,如果在其他时段重启,直接恢复到打开的状态了
发表于 2020-10-30 20:28:44 | 显示全部楼层
可是一旦模块重启不管是binary_sensor还是switch的最后 ...
time 每秒执行,如果binary_sensor 不是 off 就 off 啊。
还有也可以用全局变量来做https://esphome.io/guides/automa ... -2-global-variables
restore_value
 楼主| 发表于 2020-10-30 21:11:31 | 显示全部楼层
还有也可以用全局变量来做https://esphome.io/gu ...
求加好友具体详说,不知具体的代码要如何构成
发表于 2020-10-30 22:01:09 | 显示全部楼层
范例写都很清楚吧?不行可以参考下老外的写的~
发表于 2020-10-31 08:52:16 | 显示全部楼层
tyj365888 发表于 2020-10-30 19:36
on_time只会在经过这个时间点的时候才能起作用,如果在其他时段重启,直接恢复到打开的状态了 ...
esp8266_restore_from_flash: yes
这一条就是保存状态恢复状态的,我测试过没问题,不知道你别处有问题还是不能用 true表示
 楼主| 发表于 2020-10-31 11:46:33 | 显示全部楼层
这个我试过,用yes和true都不能够恢复状态 不知道是什么原因
GMT+8, 2025-12-23 05:42 , Processed in 0.331204 second(s), 6 queries , MemCached On.
