查看: 5709|回复: 4
[求助] Hassio的插件商店安装插件总是404访问超时,大家都是这样吗
发表于 2020-10-22 22:21:51 | 显示全部楼层 |阅读模式
发表于 2020-10-22 22:49:38 | 显示全部楼层
插件商店访问需要梯子的吧
发表于 2020-10-23 19:45:17 | 显示全部楼层
这个内容的网站,也需要梯子啊,为啥啊
发表于 2020-10-28 21:15:51 | 显示全部楼层
我有梯子不会啊
发表于 2021-1-17 23:05:00 | 显示全部楼层
是不是不支持N1 U盘启动的系统?以前EMMC启动的安装成功。先知U盘的,都没进入选择菜单就停了
root@aml:~# ./install.sh
Start script create MBR and filesystem
Start backup u-boot default
4+0 records in
4+0 records out
4194304 bytes (4.2 MB, 4.0 MiB) copied, 0.119517 s, 35.1 MB/s
Start create MBR and partittion
Start restore u-boot
442+0 records in
442+0 records out
442 bytes copied, 0.00272667 s, 162 kB/s
8191+0 records in
8191+0 records out
4193792 bytes (4.2 MB, 4.0 MiB) copied, 0.367764 s, 11.4 MB/s
Done
Start copy system for eMMC.
Formatting BOOT partition...mkfs.fat 4.1 (2017-01-24)
done.
Cppying BOOT...done.
Edit init config...done.
Formatting ROOT partition...
/dev/mmcblk1p2 contains a ext4 file system labelled 'ROOT_EMMC'
        last mounted on /ddbr/install on Mon Apr  1 23:18:05 2019
e2fsck 1.43.4 (31-Jan-2017)
ROOT_EMMC: clean, 11/427392 files, 50723/1706240 blocks
done.
Copying ROOTFS.
Copy BIN
Create DEV
Copy ETC
tar: etc/apt/sources.list: time stamp 2021-01-17 22:57:15 is 56762156.297010564 s in the future
Copy HOME
Copy LIB
Create MEDIA
Create MNT
Copy OPT
Create PROC
Copy ROOT
Create RUN
Copy SBIN
Copy SELINUX
Copy SRV
Create SYS
Create TMP
Copy USR
Copy VAR
Copy fstab
Complete copy OS to eMMC
root@aml:~#
GMT+8, 2025-12-22 23:13 , Processed in 0.236648 second(s), 8 queries , MemCached On.
