楼主: leon_xi
[插件集成] 自定义组件 简单接入小米温湿度计2
发表于 2020-10-20 11:38:12 | 显示全部楼层
https://bbs.hassbian.com/thread-10786-1-1.html
你把这个弄好了,温湿度计大约10分钟左右会出现,我用的也是米家的温湿度计2
发表于 2020-10-20 11:46:00 | 显示全部楼层
膜拜一下!!!
 楼主| 发表于 2020-10-20 12:06:28 | 显示全部楼层
lyibai 发表于 2020-10-20 11:31
Platform error: sensor - Requirements for mitemp_bt2 not found: ['bluepy==1.1.0'].
依赖库问题,我已经按照“令狐鸣”的测试结果,修改为
"requirements": ["bluepy>=1.1.0"]
发表于 2020-10-20 12:28:27 | 显示全部楼层
修改完出现以下报错
Logger: custom_components.mitemp_bt2.sensor
Source: custom_components/mitemp_bt2/sensor.py:137
Integration: mitemp_bt2 (documentation)
First occurred: 下午12:25:39 (6 occurrences)
Last logged: 下午12:26:39
Traceback (most recent call last): File "/config/custom_components/mitemp_bt2/sensor.py", line 135, in get_info p = btle.Peripheral(mac, iface=interface) File "/usr/local/lib/python3.8/site-packages/bluepy/btle.py", line 391, in __init__ self._connect(deviceAddr, addrType, iface) File "/usr/local/lib/python3.8/site-packages/bluepy/btle.py", line 439, in _connect raise BTLEDisconnectError("Failed to connect to peripheral %s, addr type: %s" % (addr, addrType), rsp) bluepy.btle.BTLEDisconnectError: Failed to connect to peripheral A4:C1:38:F0:F4:95, addr type: public
Traceback (most recent call last): File "/config/custom_components/mitemp_bt2/sensor.py", line 135, in get_info p = btle.Peripheral(mac, iface=interface) File "/usr/local/lib/python3.8/site-packages/bluepy/btle.py", line 391, in __init__ self._connect(deviceAddr, addrType, iface) File "/usr/local/lib/python3.8/site-packages/bluepy/btle.py", line 439, in _connect raise BTLEDisconnectError("Failed to connect to peripheral %s, addr type: %s" % (addr, addrType), rsp) bluepy.btle.BTLEDisconnectError: Failed to connect to peripheral A4:C1:38:4C:89:F9, addr type: public
Traceback (most recent call last): File "/config/custom_components/mitemp_bt2/sensor.py", line 135, in get_info p = btle.Peripheral(mac, iface=interface) File "/usr/local/lib/python3.8/site-packages/bluepy/btle.py", line 391, in __init__ self._connect(deviceAddr, addrType, iface) File "/usr/local/lib/python3.8/site-packages/bluepy/btle.py", line 439, in _connect raise BTLEDisconnectError("Failed to connect to peripheral %s, addr type: %s" % (addr, addrType), rsp) bluepy.btle.BTLEDisconnectError: Failed to connect to peripheral A4:C1:38:39C:6A, addr type: public
 楼主| 发表于 2020-10-20 12:38:12 | 显示全部楼层
lyibai 发表于 2020-10-20 12:28
修改完出现以下报错
Source: custom_components/mitemp_bt ...
没有连接成功
你设置的period周期是多少?
时间设置长一点,短了会产生端口占用,连接失败
先只设置一个设备(距离最近的)测试一下
发表于 2020-10-20 13:32:45 | 显示全部楼层
leon_xi 发表于 2020-10-20 12:38
没有连接成功
你设置的period周期是多少?
翻了一下home-assistant 官方论坛好像HassOS 4.14 版本蓝牙有问题,我正在降级到4.13 看看效果。
 楼主| 发表于 2020-10-20 13:40:36 | 显示全部楼层
lyibai 发表于 2020-10-20 13:32
翻了一下home-assistant 官方论坛好像HassOS 4.14 版本蓝牙有问题,我正在降级到4.13 看看效果。 ...
我的是4.13
发表于 2020-10-20 14:11:56 | 显示全部楼层
你把这个弄好了,温湿度计大约10分钟左右会出现,我用 ...
十分感谢。
 楼主| 发表于 2020-10-21 10:08:18 | 显示全部楼层
降级后可以使用了吗
发表于 2020-10-21 12:19:06 | 显示全部楼层
leon_xi 发表于 2020-10-21 10:08
降级后可以使用了吗
没有降级成功,还没有测
GMT+8, 2025-9-15 03:23 , Processed in 0.561867 second(s), 9 queries , MemCached On.
