查看: 29447|回复: 9
[求助] 该实体没有唯一的 ID,因此无法由 UI 管理其设置。
发表于 2020-10-15 13:13:17 | 显示全部楼层 |阅读模式
刷了罗大大的开关固件,但是再配置ha的时候出现 该实体没有唯一的 ID,因此无法由 UI 管理其设置。怎么破啊 (5P7@05BC98FK[OTJ{M6%T2.png @FNHOM[WLZP4~RWIH@G_7ZU.png
发表于 2020-10-15 14:06:21 | 显示全部楼层
如果只是解决在UI编辑问题,试着在配置加一个unique_id试试. 值随意,保证唯一就行
light:
  - platform: mqtt
    command_topic: "office/rgb1/light/switch"
    unique_id: "32b33778a2614be0a3290f81afdeaba9"
 楼主| 发表于 2020-10-15 17:54:17 | 显示全部楼层
大佬,不能加unique yaml报错的,这里是我的yaml配置。
light:
  - platform: mqtt
    state_topic: "relay/relay_37a290/stat/power1"
    command_topic: "relay/relay_37a290/cmnd/power1"
    payload_on: "on"
    payload_off: "off"
    availability_topic: "relay/relay_37a290/tele/availability"
    payload_available: "online"
    payload_not_available: "offline"
    brightness_state_topic: "relay/relay_37a290/stat/brightness1"
    brightness_command_topic: "relay/relay_37a290/cmnd/brightness1"
    brightness_scale: 100
    color_temp_state_topic: "relay/relay_37a290/stat/color_temp1"
    color_temp_command_topic: "relay/relay_37a290/cmnd/color_temp1"
  - platform: mqtt
    state_topic: "relay/relay_37a290/stat/power2"
    command_topic: "relay/relay_37a290/cmnd/power2"
    payload_on: "on"
    payload_off: "off"
    brightness_state_topic: "relay/relay_37a290/stat/brightness2"
    brightness_command_topic: "relay/relay_37a290/cmnd/brightness2"
    color_temp_state_topic: "relay/relay_37a290/stat/color_temp2"
    color_temp_command_topic: "relay/relay_37a290/cmnd/color_temp2"
发表于 2020-10-16 10:47:38 | 显示全部楼层
light:
  - platform: mqtt
    payload_on: "on"
    payload_off: "off"
    unique_id: "relay_37a290_l1"
应该没问题的,报什么错?  再试试? 什么版本啊
发表于 2020-10-17 22:27:54 | 显示全部楼层
我的也是老提示么有唯一,烦得很
发表于 2020-12-12 17:24:30 | 显示全部楼层
如果只是不能自动加到仪表盘,可以手动加。
发表于 2021-5-6 04:07:11 | 显示全部楼层
如何手动加到仪表盘呢
发表于 2021-5-7 10:10:38 | 显示全部楼层
Clark 发表于 2021-5-6 04:07
如何手动加到仪表盘呢
在主面板点击右上角的三个点,然后点击编辑仪表盘,就可以手动添加了。
发表于 2023-12-16 00:21:30 | 显示全部楼层
sailor0908 发表于 2021-5-7 10:10
在主面板点击右上角的三个点,然后点击编辑仪表盘,就可以手动添加了。 ...
好像不行吧。那里只能添加名称。
发表于 2024-5-8 15:15:26 | 显示全部楼层
请问找到解决办法了吗?
GMT+8, 2025-12-16 14:07 , Processed in 1.376438 second(s), 12 queries , MemCached On.
