查看: 5964|回复: 3
[求助] yeelight在升级0.116后在HA中找不到
发表于 2020-10-10 19:14:57 | 显示全部楼层 |阅读模式
日志如下,有没有同样情况的,
Logger: homeassistant.config_entries
Source: components/yeelight/light.py:140
First occurred: 下午6:17:53 (1 occurrences)
Last logged: 下午6:17:53
Error setting up entry Mi-Light for light
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 231, in async_setup
    result = await component.async_setup_entry(hass, self)  # type: ignore
  File "/usr/src/homeassistant/homeassistant/components/light/__init__.py", line 287, in async_setup_entry
    return await hass.data[DOMAIN].async_setup_entry(entry)
  File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 140, in async_setup_entry
    platform = await async_prepare_setup_platform(
  File "/usr/src/homeassistant/homeassistant/setup.py", line 298, in async_prepare_setup_platform
    platform = integration.get_platform(domain)
  File "/usr/src/homeassistant/homeassistant/loader.py", line 401, in get_platform
    cache[full_name] = importlib.import_module(
  File "/usr/local/lib/python3.8/importlib/__init__.py", line 127, in import_module
    return _bootstrap._gcd_import(name[level:], package, level)
  File "<frozen importlib._bootstrap>", line 1014, in _gcd_import
  File "<frozen importlib._bootstrap>", line 991, in _find_and_load
  File "<frozen importlib._bootstrap>", line 975, in _find_and_load_unlocked
  File "<frozen importlib._bootstrap>", line 671, in _load_unlocked
  File "<frozen importlib._bootstrap_external>", line 783, in exec_module
  File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
  File "/usr/src/homeassistant/homeassistant/components/yeelight/light.py", line 140, in <module>
    EFFECT_RANDOM_LOOP: yee_transitions.randomloop,
AttributeError: module 'yeelight.transitions' has no attribute 'randomloop'
发表于 2020-10-10 19:49:32 | 显示全部楼层
HA更新为0.116.2
发表于 2020-10-10 20:51:16 | 显示全部楼层
0.116.2已修复bug
 楼主| 发表于 2020-10-11 12:30:09 | 显示全部楼层
感谢两位,升级后搞定。
GMT+8, 2025-12-16 19:55 , Processed in 0.336817 second(s), 9 queries , MemCached On.
