查看: 36009|回复: 12
[求助] 通过hass.io初装zigbee2mqtt插件,无法登录问题求教
发表于 2020-10-7 15:48:55 | 显示全部楼层 |阅读模式
安装完之后登录不了UI界面,提示502: Bad Gateway
配置看上去没什么特别的,大神帮忙看看是哪里的问题
版本是1.15.0
配置如下:
96AE0E5D-DD52-44C5-B4FD-53293DB552F5.png 6A9D5D3C-4E66-41BD-A24E-50142D410DAE.png 6D034C4E-336E-4250-9DF9-675B9A1B383C.png
 楼主| 发表于 2020-10-9 11:37:21 | 显示全部楼层
群里应该有玩zigbee的朋友吧,帮忙看看是哪里的问题,感谢!
 楼主| 发表于 2020-10-10 12:58:32 | 显示全部楼层
我的zigbee网关还没到,所以串口服务还没配,不知道是不是这的问题,看日志上有这个错误
但是我理解这个应该不会影响webui显示,大不了里面没内容……
Zigbee2MQTT:info  2020-10-10 12:56:44: Logging to console and directory: '/share/zigbee2mqtt/log/2020-10-10.12-56-44' filename: log.txt
Zigbee2MQTT:info  2020-10-10 12:56:45: Starting Zigbee2MQTT version 1.15.0 (commit #1.15.0)
Zigbee2MQTT:info  2020-10-10 12:56:45: Starting zigbee-herdsman...
Zigbee2MQTT:error 2020-10-10 12:56:45: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2020-10-10 12:56:45: Failed to start zigbee
Zigbee2MQTT:error 2020-10-10 12:56:45: Exiting...
Zigbee2MQTT:error 2020-10-10 12:56:45: Error: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM0'
    at Znp.<anonymous> (/zigbee2mqtt-1.15.0/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:136:32)
    at Generator.next (<anonymous>)
    at /zigbee2mqtt-1.15.0/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:27:71
    at new Promise (<anonymous>)
    at __awaiter (/zigbee2mqtt-1.15.0/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:23:12)
    at SerialPort.<anonymous> (/zigbee2mqtt-1.15.0/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:134:49)
    at SerialPort._error (/zigbee2mqtt-1.15.0/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:198:14)
    at /zigbee2mqtt-1.15.0/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:242:12
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm
ERR!
[email protected] start: `node index.js`
发表于 2020-11-2 08:58:08 | 显示全部楼层
但是我理解这个应 ...
ttyACM0是usb设备
 楼主| 发表于 2020-11-2 09:15:16 | 显示全部楼层
是的,已经搞定了,本来以为界面登录不依赖硬件配置,看来不是
发表于 2021-2-19 22:46:54 | 显示全部楼层
你好 我也遇到你的问题  你是怎么样解决的
发表于 2021-3-19 22:56:51 | 显示全部楼层
你好,原因是什么呢?遇到了同样的问题
发表于 2021-4-1 20:19:25 | 显示全部楼层
这个插件是怎么安装上去的?
发表于 2021-5-9 05:25:48 | 显示全部楼层
您好,我也遇到了一样的问题,所以是需要修改ttyACM0为什么么?还是不支持没有硬件?
我的报错是
Zigbee2MQTT:error 2021-05-08 23:25:16: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2021-05-08 23:25:16: Failed to start zigbee
Zigbee2MQTT:error 2021-05-08 23:25:16: Exiting...
Zigbee2MQTT:error 2021-05-08 23:25:16: Error: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM0'
发表于 2022-2-5 21:24:44 | 显示全部楼层
我也遇到了楼主相同问题,zigbee2mqtt web界面打不开 提示  502: Bad Gateway
Logger: homeassistant.components.hassio
Source: components/hassio/__init__.py:568
Integration: Home Assistant Supervisor (documentation, issues)
First occurred: 19:10:53 (21 occurrences)
Last logged: 21:21:44
Can't read Supervisor data: Container addon_45df7312_zigbee2mqtt is not running
Can't read Supervisor data: 404 Client Error for http+docker://localhost/v1.41/containers/addon_45df7312_zigbee2mqtt/json: Not Found ("No such container: addon_45df7312_zigbee2mqtt")
GMT+8, 2025-12-16 01:54 , Processed in 0.709017 second(s), 15 queries , MemCached On.
