查看: 4199|回复: 4
[技术探讨] 有关计量电表
发表于 2020-10-7 10:29:08 | 显示全部楼层 |阅读模式
这种计量电表有人做成了吗?
用tuya-convert刷进去tasmota
或者线刷
esptool.py --port COM3 --baud 74880 --after no_reset write_flash --flash_size 1MB --flash_mode dio 0x00000 tuya_backup.bin --erase-all
- platform: mqtt
    name: "Mains Consumed Energy"
    state_topic: "tele/general-meter-switch/RESULT"
    value_template: >-
      {% set message = value_json.SerialReceived %}
      {% set payload = message[6:14] %}
      {% set payload_len = (payload | length) %}
      {% set result = namespace(value='') %}
      {% for i in range(0, payload_len + 1) | reverse -%}
        {%- if i is divisibleby 2 -%}
          {%- set result.value = result.value + payload[i:i+2] -%}
        {%- endif -%}
      {%- endfor -%}
      {{ (result.value|float) / 100 }}
    unit_of_measurement: 'kWh'
  - platform: mqtt
    value_template: >-
      {% set payload = message[14:22] %}
        {%- endif -%}
      {%- endfor -%}
      {{ (result.value|float) / 10 }}
    unit_of_measurement: 'Volts'
  - platform: mqtt
    value_template: >-
      {% set payload = message[22:30] %}
        {%- endif -%}
      {%- endfor -%}
      {{ (result.value|float) / 10000 }}
    unit_of_measurement: 'Amps'
  - platform: mqtt
    name: "Mains Frequency"
    value_template: >-
      {% set payload = message[30:38] %}
        {%- endif -%}
      {%- endfor -%}
    unit_of_measurement: 'Hz'
  - platform: mqtt
    name: "Mains Active Power"
    value_template: >-
      {% set payload = message[38:46] %}
        {%- endif -%}
      {%- endfor -%}
    unit_of_measurement: 'Watts'
  - platform: mqtt
    name: "Mains Reactive Power"
    value_template: >-
      {% set payload = message[46:54] %}
        {%- endif -%}
      {%- endfor -%}
  - platform: mqtt
    name: "Mains Apparent Power"
    value_template: >-
      {% set payload = message[54:62] %}
        {%- endif -%}
      {%- endfor -%}
  - platform: mqtt
    name: "Mains Power Factor"
    value_template: >-
      {% set payload = message[62:70] %}
        {%- endif -%}
      {%- endfor -%}
    unit_of_measurement: '%'
发表于 2020-10-7 11:07:43 | 显示全部楼层
没看懂,帖子没头没尾的~
 楼主| 发表于 2020-10-7 19:46:28 | 显示全部楼层
neroxps 发表于 2020-10-7 11:07
没看懂,帖子没头没尾的~
把电表ZMAi-90接入到homeassistant
发表于 2020-10-8 09:02:45 | 显示全部楼层
哦 这个是接进去的配置是吧?
 楼主| 发表于 2020-10-10 20:23:30 | 显示全部楼层
neroxps 发表于 2020-10-8 09:02
哦 这个是接进去的配置是吧?
对的,在homeassistant里面的配置
GMT+8, 2025-12-18 15:29 , Processed in 1.334505 second(s), 10 queries , MemCached On.
