查看: 19584|回复: 15
[求助] 升级0.115提升空间不足?
发表于 2020-9-20 11:13:16 | 显示全部楼层 |阅读模式
20-09-20 00:51:07 INFO (MainThread) [supervisor.homeassistant.core] Update Home Assistant to version 0.115.2
20-09-20 00:51:07 INFO (SyncWorker_3) [supervisor.docker.interface] Update image homeassistant/raspberrypi3-homeassistant:0.114.3 to homeassistant/raspberrypi3-homeassistant:0.115.2
20-09-20 00:51:07 INFO (SyncWorker_3) [supervisor.docker.interface] Pull image homeassistant/raspberrypi3-homeassistant tag 0.115.2.
20-09-20 01:23:48 INFO (MainThread) [supervisor.updater] Fetch update data from https://version.home-assistant.io/stable.json
20-09-20 02:10:35 INFO (MainThread) [supervisor.host.info] Update local host information
20-09-20 02:10:36 INFO (MainThread) [supervisor.host.services] Update service information
20-09-20 02:10:36 INFO (MainThread) [supervisor.host.network] Update local network information
20-09-20 02:10:37 INFO (MainThread) [supervisor.host.sound] Update PulseAudio information
20-09-20 02:24:47 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/hassio-addons/repository repository
20-09-20 02:24:47 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/home-assistant/hassio-addons repository
20-09-20 02:24:56 INFO (MainThread) [supervisor.store] Load add-ons from store: 66 all - 0 new - 0 remove
20-09-20 02:28:15 ERROR (SyncWorker_3) [supervisor.docker.interface] Can't install homeassistant/raspberrypi3-homeassistant:0.115.2 -> 404 Client Error: Not Found ("no such image: homeassistant/raspberrypi3-homeassistant:0.115.2: No such image: homeassistant/raspberrypi3-homeassistant:0.115.2").
看日志提示是空间不足,我安装环境是树莓派3B+64G卡+官方hassos,已经把home-assistant_v2.db删了,然后recorder.yaml里配置是  purge_keep_days: 10,不知怎么查看卡的剩余空间以及清理空间,以前一路升级过来都是正常的,搜索了一下也没发现别人提到这个问题,有人知道怎么解决吗?
智能家居&单板滑雪痴迷爱好者
发表于 2020-9-20 14:58:21 | 显示全部楼层
提示是404找不到,可能那会儿服务器侧有问题,你再试试应该就没问题了
 楼主| 发表于 2020-9-20 15:52:47 | 显示全部楼层
This error is often caused by not having enough disk space available.
这句不是说空间不足吗。从0.115-0.115.1-0.115.2都是这样
智能家居&单板滑雪痴迷爱好者
发表于 2020-9-20 15:59:33 | 显示全部楼层
这句不是说空间不足吗 ...
这句话的意思是空间不足通常会导致这个错误(但不能排除别的原因也会导致这个错误),显然你的空间是足够的。不要把机器想的那么聪明。关键是前面现有一个404,这个是很明确的信号,就是没找到。然后才有那个容易引起误会的错误提示。
你再试试就知道了。
我开始升级115.2也出这个提示来着,过了一会儿再试就好了。
发表于 2020-9-21 14:26:40 | 显示全部楼层
这个大多都是网络问题,因为我的之前也是经常这样,一开始是挂梯子解决,后来经大神指点,更换了国内的镜像源,一切都变得丝滑起来。
 楼主| 发表于 2020-9-21 23:25:36 | 显示全部楼层
fyanjin 发表于 2020-9-21 14:26
这个大多都是网络问题,因为我的之前也是经常这样,一开始是挂梯子解决,后来经大神指点,更换了国内的镜像 ...
我之前也是挂梯子,这次挂着梯子还是不行,索性拔卡重新刷了。可以指导下怎么换国内镜像吗
发表于 2020-9-22 10:58:53 | 显示全部楼层
hassos可以换镜像源吗
智能家居&单板滑雪痴迷爱好者
发表于 2020-9-22 11:36:08 | 显示全部楼层
chenquanhao 发表于 2020-9-21 23:25
我之前也是挂梯子,这次挂着梯子还是不行,索性拔卡重新刷了。可以指导下怎么换国内镜像吗 ...
我之前有个回帖里说过,再重复一遍吧:
登录到hassos主系统(用户名root、无密码,进入ha命令行状态),然后输入login,进入系统提示符状态。
然后用vi命令编辑/etc/docker/daemon.json文件,加入国内镜像地址即可:
{"registry-mirrors":["https://xxxx.mirror.aliyuncs.com"]}
把其中的”xxxx“换成你自己的镜像地址,网上搜到的一般都不好使,尽量自己到阿里云注册个账号。
智能家居&单板滑雪痴迷爱好者
发表于 2020-9-22 11:36:45 | 显示全部楼层
tcwj2008 发表于 2020-9-22 10:58
hassos可以换镜像源吗
见8楼,也可以ssh登录后操作
发表于 2020-9-22 11:46:13 | 显示全部楼层
XCray 发表于 2020-9-22 11:36
见8楼,也可以ssh登录后操作
记得hassos打开ssh还有点麻烦的,回头试试看,还想说hassos会提供一个更为方便的方法呢,看来是我想多了,哈哈哈哈
试了一下,回来给大家提供点思路
系统情况:
esxi6.7 + HassOS(之前一直用Hass.IO,有段时间出了点问题,重装了几次,想想好麻烦,就索性直接上esxi了)
使用esxi里的控制台,root登录后login就直接是root权限不用再ssh了
但是,试了一下hassos里,vim和nano都没有装,本着尽量不修改原系统的原则(其实是懒),所以参考了阿里云提供的方法
mkdir -p /etc/docker
tee /etc/docker/daemon.json <<-'EOF'
  "registry-mirrors": ["https://xxxxxxx.mirror.aliyuncs.com"]
EOF
也可以成功写入配置文件,果然快多了,开心,回头我再开个帖子
参与人数 1金钱 +5 收起 理由
chenquanhao + 5 我来瀚思就为看你!
GMT+8, 2025-12-23 05:38 , Processed in 0.060331 second(s), 12 queries , MemCached On.
